Question about RCA Universal Remote Control
RCA video out to 2.5mm AV in mini jack wiring
I want to build a cable to connect my laptop that has an RCA video out connector to a LAWMATE wireless transmitter that has an AV in 2.5mm mini jack socket. The socket is labeled "AV in + 5mv out". I don't care about the "5mv out" part. What would be the correct wiring ? Thank you very much Nikos Andritsakis
3 Suggested Answers
  • 119 Answers
SOURCE: audio output jacks
If I remember this tv correctly, check under the audio setting in the menu, most tv's including this on have variable output for the audio o/p. meaning the the o/p vol. is adjusted as the tv speaker vol. changes. some tv's will put out a fixed audio o/p to the rca jacks, but will only do this when the speakers are shut off in the menu (not muted, but off). I have run into this problem many times & have yet to find a better solution to getting a steady sound sound out of the o/p jacks.
Posted on Nov 03, 2006
  • 4234 Answers
SOURCE: RCA VHS-C screen for sculpture
The resistance of hte wire is not the major problem. While it will degrade the signal somewhat, the main problem will be outside interference. You would be better off trying to hide the camera closer to where the screen must reside and usinga ribbon cable only a few inches longer. You will need to find a service manual for that model to get the pinout of the cable.
Good luck.
Dan
Posted on Jun 06, 2008
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Oct 26, 2015 | RCA Televison & Video
I nedd to play my computer on this tv i need help
This being a CRT style projection set is not really designed to work with a computer/laptop.
If your computer has a composite video output, it should be able to work. This is a analog video output and would be a RCA connector. Most computers have a audio output and most of the time it is a stereo mini jack. So if you have a RCA video jack output on your computer you can hook it to the yellow video in of video1. If you have a stereo mini jack cable that has 2 RCA connectors at the other end, you would plug the mini jack in the audio out of the computer and plug the RCA Jacks into the red and white connectors of video1. Some computers will have a key you will need to press to activate the video output instead of the monitor output.
I hope this is clear enough.
Skyassoc
Nov 25, 2010 | RCA HD52W59 HDTV Projection Television
Just bought a stereo mini to rca cable. i have a macbook and a 32" dynex tv. I dont know where to insert the cables on the tv.
you need a mini to two rca plugs cable; once you have this: connect the red rca plug to the left TV stereo rca connector and, the white rca plug to the right TV stereo connector
and, the mini stereo plug to your speaker jack on the macbook You will now have sound.
then: connect the video to you macbook using another either s-video or, vga cable to the TV
Aug 03, 2010 | Televison & Video
I WOULD LIKE TO CONNECT MY LAP TOP TO TV WHAT CABLE AND HOW WOULD YOU DO IT ?
You will need
  • a PC or Mac laptop computer
  • a digital TV
  • a VGA 15-pin connector cable; or an S-Video cable and mini to RCA audio cable;
  • or a wireless converter
More information you can visit:http://www.videojug.com/film/how-to-connect-your-laptop-to-your-television.
If you need laptop accessories, such as Dell Latitude D620 Keyboard, toshiba a45 keyboard, gateway 450rog keyboard etc, you can visit www.udtek.com.
Apr 12, 2010 | Acer Aspire One AOA110-1588 Notebook
I want to connect my pc to a leowe tv for streaming. Want to know what connections and cables i need. It is a normal tv not lcd. Thanks
wired solution: (one of many)
You have to use your s-video out for the video, get a s-video to rca cable (for example this one http://www.amazon.com/gp/product/B000HDKZT6/ref=olp_product_details?ie=UTF8&me=&seller ). For sound use your audio out (or phone jack) and get another jack to rca converter or cable (for example : http://www.amazon.com/3-5mm-Stereo-Plug-Dual-Adapter/dp/B0002KR5Q0/ref=pd_bxgy_e_img_b )
Buy a rca to scart, plug the yellow (svideo to rca) in the yellow pin, the red and white ones are for audio.
or
get one of these : http://www.dgtale.ch/hs500/scart_rca.jpg
and a svideo to rca (http://www.esteshareia.com/Computer%20products/B%20Svideo%20RCA.jpg)
and to connect this a female to female rca http://www.zzounds.com/item--HOSGRA101
wireless:
First off all, buy a decent (they are pricey!!) AV transmitter
they useally come with scart to rca. and buy the above mentioned cable (svideo to rca and jack to rca) and you are ready to go.
Hope this helped.
Dec 21, 2009 | Televison & Video
Hooking up an external audio source (IPOD) to the Denon AVR 3803
Yes it is.  You will need to pick up a mini plug to stereo rca adapter.
Jan 07, 2009 | Denon AVR-3803 Receiver
Analogic AV out don't works
try to configure the option menu on your camcorder.if not, then try to buy a new cable jack it must be the problem. hope that helps you.
CHARCOIS
Jul 07, 2008 | Panasonic NV-GS50 Mini DV Digital...
DVI to RCA3 AV OUT
DVI to Composite Video (yellow) adapters are available in many online stores for mail order. You will need to get a separate mini-RCA jack to stereo RCA adapter to hook the audio output from the computer to the stereo audio (red and white) connections of the cable.
Search google for DVI to composite video adapter, and the mini-RCA adapter can be found at most home entertainment or electronics stores (Best Buy, Circuit City, etc)
Jun 10, 2008 | Dell XPS 200 PC Desktop
Want to watch thru tv
Hi
Check and see if you have A/V out jacks on the unit. If you do, they will be yellow, red, and white.
They are called RCA jacks, and if you have them, and the TV has the same type of jacks, then you just need the cable that goes in between. The DVD player normally comes with them, but if not, you can purchase them at any Circuit City, or even Walmart.
Jan 14, 2008 | Mintek MDP-1815 Portable DVD Player
Televison & Video Logo
497 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
