WHICH CPU? I own an acer aspire t180 with an amd sempron 3000+ its about 1.6ghz and i want to upgrade the processor to about 3ghz or more if possible can u tell me which processor will be compatible with my acer? Thanks.
  • 413 Answers
AMD Athlon 64 X2 5600+ ~ 3.20GHz
This is one of the crown jewel from AMD and is very robust
thanks and regards
Posted on May 12, 2009
  • 3 Answers
I dont believe you will be able to replace ONLY the CPU.. in order to upgrade.. you would more than likely have to upgrade the CPU as well as the motherboard... .. then upgrading motherboards... you will likely have to upgrade RAM as well.. unless you can find a motherboard that supports your current type of ram..
What type of acer aspire t180 do you have?
Here is my personal best suggestion...
buy a barebones system... and move all of your current hardware to this new system...
the reason why i suggest this.. is because.. occasionally.. companies make their towers and motherboards... so that you cannot put in another type of motherboard... they wont line up correctly.. and so on...
I just found this by searching on pricewatch
http://www.barebonekit.net/customkititems.asp?kc=DTBBFXC661P4540
then change the Ram to 2gb and it makes the total $198..
now you have a 3.2ghz Pentium 4 pc.. with 2gb of ram... and a tower... it has onboard video.. and sound i believe... so all you would need to do is move your hard drive/cdrom videocard etc over... if you need a new videocard.. search pricewatch.com... good deals there...
  • 1,959 Answers
The best you can do with a socket 754 is the Athlon 64 3700+. Its clocked at 2.4Ghz. Only way to go faster is a newer motherboard. Hope you find this answers your question and best of luck to you!
Greg
  • Greg Margossian
    Greg Margossian May 14, 2009
    Haven't heard back so assuming you found the solution to solve your problem, kindly rate the solution. Thanks very much and again, best of luck to you.
    Greg
I want to upgrade from a AMD Sempron processor 2800+ 1.6GHz 192MB to a faster AMD processor with more RAM. I have an Acer 3002LC laptop. Can you advise me what CPU will support this...
My advice to you is to purchase a faster/newer laptop.
A new processor plus labour to install the CPU will cost a substantial amount of money and the performance gain will be marginal. Also RAM bottle neck come into affect as 192mb of RAM is not going to cut it, now-days you need at least 2GB of it. I myself prefer AMD their new AMD Athlon 2 X2 CPUs perform really well.
damnor01
Dec 30, 2010 | AMD Sempron 2800+, 1.6 GHz Processor
Hi i need more help in knowing just what type of processor chip to buy i know i need to put the same type back in my problem is i dont know what type it is my pc is acer aspire t135 1.8ghz it says on my...
Hi Paul,
Correct, you have to use the same type, but you can upgrade to a faster CPU.
According to the specs for your computer it can take the following:
AMD Sempron processor 2600+ to 3300+, 333MHz FSB
AMD Athlon processor 2800+ to 3200+, 400MHz FSB
See:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireT135/AspireT135sp2.shtml
The Athlon's are better...faster Bus. The Sempron is cheaper.
The 2 processors you describe are very similar. The difference between the 2 is that the first one is capable of running 64-bit operating systems and applications. The second one is strictly for 32-bit systems.
The next question will probably be, "What do I have?" Probably a 32-bit system. You can go with the 64-bit CPU and be safe as it can run both. You can see what your old one is by the revision number on the top of the CPU. You can use the following comparison chart to see the differences:
Sempron 3100+ Comparison
I hope this has been some help. Maybe it has just caused more questions. Just ask.
Thanks for using Fixya.
Mar 24, 2010 | Computers & Internet
Yea i need to purchase a new processor chip the motherboard is a 754 socket my pc takes a 3100+ amd sempron processor my pc is 1.8ghz im just not sure what to buy some say they are 64 bit and this one is...
please purchase the processor that is compatible to your motherboard. if the motherboard can be upgrade to a higher speed of processor then purchase it. if not, stick to the required specs. if you still want to upgrade, replace the motherboard, processor and the memory.
Mar 23, 2010 | Computers & Internet
Can I upgrade my 1Ghz processor to a faster 2 or 3Ghz? I have an EliteGroup 741GX-M, socket 462 desktop with an AMD sempron
yes, it is possible, but the Front side bus will limit the functionality so much that it wouldn't be worth it.
Jan 02, 2010 | EliteGroup MB ECS 741GX-M SIS741GX 462...
Cpu Models to upgrade Compaq Presario sr1920nx
CPU/Processor
  • Socket: 939
  • Supports the following processors:
    • AMD Athlon 64 X2 up to 4800+
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
CPU/Processor
  • Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Cpu/Processor Type
Socket: 939
    • AMD Athlon 64
    • AMD Sempron
Dec 22, 2009 | HP Compaq Presario SR1920NX PC Desktop
I recently purchased a new battery for my acer Aspire 3050 and was told that it wont work if my laptop was dual core.I'm not sure what that means, is my 3050 dual core
you are in luck the answer is no its not dual core
Acer Aspire™ 3050 (LX.AV10J.037) PC Notebook The Aspire single core™ 3050 from Acer® provides performance, flexibility and value in a compact system. Featuring an AMD Sempron™ processor, wired and wireless connectivity and a stunning 14.1” WXGA display, this notebook brings productivity and entertainment to a new level.Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Acer Aspire 3050-1733 Notebook
Upgrade possibillities for Acer Aspire T180
Specifications
Product
Aspire T180 Language
English Model
Aspire T180 Specifications Specifications
Processor
AMD AM2 Athlon 64 x 2 or Athlon 64 or Sempron (940 pin)
emory
256MB DDR2 533/667/800 SDRAM expandable to 4GB
1 Ok now that i found the spec for your computer here we go you can install the amd 64 x2 but not Phenom x4 9950
2 As for the graphic card you seem to know a little about computers so you can install and pci express x 16 graphics card that only needs one slot but remember some need power and this mean you my have to upgrade your power supply.So really you can by any single slot pci express graphics card for your computer so it comes down to how much you want to spend.
3.Ok for ram your max will be 4 gbs most likely ddr2 which mean that you have 4 ram spot in your computer.
hope this help please vote for me.
Oct 26, 2008 | Acer Aspire™ T180 PC Desktop
ACER 180 (AMD 64 3800+) upgrade
any amd 64 will work. bios should be ok if you stay with just the amd 64 if this is a aspire t180 then you might want to go to a 64x2 which you will have to flash the bios. hope this helps
roduct
English Model
Processor
Oct 18, 2008 | Acer Aspire™ T180 PC Desktop
Processor upgrade
Need to look at the motherboard specs along with the processor "Socket". It will usually be a 754 or 939 depending on what your motherboard says. I wouldn't try too fast and set yourself up for disappointment. I would upgrade the RAM before the processor.
Mar 22, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
284 people viewed this question
David Payne
David Payne
