Question about Craftsman Garden
Dies out like it ran out of gas after 15 min. but will restart after it sits for a while
Craftsman self propelled mulching mower dies out after about 15 minutes but will restart after sitting for a short while. sounds like it runs out of gas when it is dieing out.
  • 420 Answers
The fuel is not getting into the carburetor as it should, the issue may be one of the following:
  1. Clogged or restricted fuel tank exit.
  2. Clogged or restricted fuel filter
  3. Fuel shut-off valve not open fully
  4. Float valve in carburetor maladjusted, fouled
  5. Excessive water in float bowl
This is what I do to check 1,2 and three all at once.
  1. I run the mower out of fuel after draining as much as possible into a suitable container.
  2. I remove the fuel line from the carburetor and direct it into a catch container such as a clean water or soda bottle.
  3. I add a small amount of fuel to the tank (less then the catch container you are using) and observe how quickly the gas flows from the tank to the catch container. If the fuel trickles in the issue is likely one of the three described above. If the fuel drains into the catch container quickly then the issue is internal to the carburetor which may require a trip to the local small engine shop.
  4. Once all of the fuel has drained into the catch container re-attach the fuel line to the carburetor. If the mower is equipped with a push button drain on the bottom of the carburetor press it momentarily to ensure that the float bowl is not partially full of water (common in the spring). If more than a drop or two of water came out you may have solved the problem.
  5. Place a folded shop towel or paper towel under the drain button to hold any fuel. I recommend wearing nitrile exam gloves for the next part, pour the fuel from the catch container into the fuel tank while pressing and holding the drain button on the bottom of the carburetor, under normal circumstances with items 1,2 and three testing out ok the fuel will run out of the drain button in a steady stream, if it comes out in drops then the cause is likely the needle valve or its related circuitry within the carburetor, this is best handled by those with advanced experience such as a small engine repair shop.
Posted on May 14, 2009
My lawn tractor craftsman 14.5hp IC OHV B&S stalls approx. 5 mins after starting so I restart and it can stall in another 10-15 min again and so on.
you may have some debris in your gas tank blocking the pickup tube. It will float away when the mower dies, then block the tube after it runs again.
Jan 03, 2017 | Craftsman Garden
Craftsman 22" self propelled platinum series lawnmower died while pushing it. wont restart. ????
A good place to start is taking the air filter off. Then try stArtingvit again. Often a dirty air filter will not allow a mower to stay running. If that does not help. Remove the cover under the carburetor looking for dirt in the cover. Also well the cover is off remover the small pin that holds the float in place. Pull the neddle valve out cleaning it and the other parts with a carburetor cleaner then reassemble
Jul 21, 2014 | Briggs & Stratton Garden
How does the govener and carb linkage work on a Troy-Bilt 2005 800 Series (839) self propelled mower
Have you changed springs? Likely the correct components are there unless you have changed it. Does it run properly and at correct rpm when not in tall grass? Check for proper throttle adjustment first. also check for obstructions (packed grass for instance) under the deck that could be impeding the blade. Lastly, if you have the discharge blocked with a mulch plug, remove the plug. let the tall grass discharge. then run over it again and mulch it.
May 29, 2014 | Troy Bilt 5.5hp Self Propelled Mower
22 In Craftsman Self propelled.Starts easy, runs good for about 15-20 mins. Starts missing and dies. Will start again in about 30 mins New spark plug/ air filter
Oh my, that is so annoying. There is probably dirt in the carb. or the gas tank. What I think happens is, the dirt gets sucked up into the fuel line and clogs the carb, then when the mower sits for a while the dirt goes back into the tank for another couple minutes. I have absolutely no tolerance for this when it happens.
Aug 05, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Our troy bilt self propelled lawn mower is about 8 years old and has served well. However it has developed the following problem: requires extra priming to start and then dies....will not remain started....
The float and needle need replacing. Take the carb off soak in a high octane gas or booster for 15 min. The float isn't floating in the gas bowl, which rises the needle to let more fuel in. When you prime the carb, you are directly shooting gas to the carb, this is why it will start and then shut down because the float can't keep gas flowing in. A kit cost about $5-7 and easy to replace.
Apr 19, 2010 | Troy Bilt 5.5hp Self Propelled Mower
2 year old craftsman 42" deck tractor runs fine for 15 minutes then sputters and dies. Will start, run 2-3 minutes, die again. Leave sit will run for 20 minutes.
if it restarts immediately, check the vent in the gas cap for restriction. also, the solenoid on the bottom of the carburetor may be sticking or getting weak. if you have to let it sit for awhile before it retarts, the ignition module may be breaking down when it heats up. i'd bet on the gas cap or solenoid though
Sep 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lawn mower died while mowing and won't restart
check the carb and air filter... also make sure its not gas from last season and make sure the oil is good.
Aug 16, 2009 | Garden
Self-Propelled Model Starts, then dies after about 15 seconds
I posted same problem as this couple days ago. Took mower to shop. The governor spring (located just under the air filter) had come off. So glad it was something so minor!
Jul 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Craftsman 6.75hp self propelled mower starts and turns off
I think that this is a 4stroke engine and runs on neat petrol.Have you been putting oil in with the petrol like a 2 stroke engine needs because this would account for the smoking.If not the check that you havn't overfilled the gearbox oil.
Jun 12, 2009 | Craftsman Garden
Garden Logo
191 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
