Question about Whirlpool Dryers
What is the code F1 on my cabrio dryer? - Whirlpool Dryers
  • 460 Answers
F1 Possible Cause / Procedure *A power gitch may cause this error -Unplug washer or disconect power for 2 minutes. -weryfy CCU operation by running a Diagnostic Test or any cycle ==================PUMP DRIVE ERROR========== * Replace CCU board. ================== MAIN RELAYS ERROR =======one of the main relays is not working properly====== POSSIBLE  ====Causes=====The relay might be soldered or always open. ===== Procedure ====Replace CCU board wish a technition service must work on it. Am sorry  "Was this helpful
Posted on May 13, 2009
I have a whirlpool cabrio gas dryer that take along time to dry. It has a code of F1 stored on it.The dryer vent is clean.Is the control panel bad.
change gas valve coils. for f1 error, if dryer is running don't worry about it. in future if your dryer beeps and flash f1 error you can unplug dryer get main control board out check dry solder on motor control rely it it is dry solder you can solder and you good to go or not solder problem then you need new control board. good luck.
Jan 21, 2017 | Whirlpool Dryers
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    WHAT IS THE F1 ERROR MESSAGE
    F1 error code is a miscommunication between the control board and the rest of the machine. Check for any loose or damaged wires. If no loose or damaged wires are found, replace the control board and this should clear up your problem.
    Oct 22, 2015 | Whirlpool Cabrio 7.6 Cu. Ft. 11-Cycle...
    What does F1 mean on a whirlpool cabrio dryer
    You can google whirlpool cabrio dryer codes and find the code that you are looking for. I just looked it means your dryer is not heating.
    http://dryernotheating.net/whirlpool-cabrio-dryer-f1-error-code/
    Aug 02, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
    Dryer shows f1
    -Poosibly heater element are burn out.
    Mai
    Sep 22, 2013 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
    F1 code on my Cabrio dryer
    According to the manufacturer the "F1" error code means a primary control failure. The correction is to replace themachine control assembly. Here is the part to order.
    The part comes with a 365 day, any part, any reason return policy.
    Nov 12, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
    I have a Whirlpool Cabrio dryer, model WED6400SW, that displays an F1 code. What type of problem does the F1 code signify?
    F-1 means a power failure occurred unplug for 15 minutes,it may clear the code,if not you need to check all connection to and from the main control board for good clean connections then retry powering it up again,if this doesn't help then replace this control board
    Mar 06, 2011 | Dryers
    Dryers Logo
    834 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
