Question about Jensen Radio Communications
Tuning in to TV with wireless headphones
I having trouble tuning the headphones to any TV station. There is a lot of hum and static. I can barely hear the audio. I have tried plugging the power into a separate outlet from the Tv and VCR. But nothing helps. The tuner & reciever areĀ in the same the room with a computer, TV, VCR. What can I do?
I need more info on this. What type of tuner and receiver? Is the tuner plugged into the headphone jack on the tv? If you have a tuner for tv that tunes in channels 2,3,5,12,25,60 etc that would be an older tuner that used the older NTSC standard. Tv stations now broadcast using ATSC, channel 4,1, 4.2 etc.
Posted on Dec 26, 2017
SOURCE:
SOURCE: can not connect
Power up headset. Press and hold the + and - Volume buttons until the red and blue lights flash . Your phone should now pair with the headset. For passcode I used 1234 and this worked.
Regards
Moss
Posted on Mar 17, 2008
SOURCE: hooking up wireless headphones into the tv
u have to split the signal by having both the tv and the headphones getting the input,as you're probably only have the audio cables going to the headphones.You need an audio splitting cable (it has 4 malle connections) so you can put 2 in the tv and 2 in the headphone base.
Posted on Jun 27, 2008
Just_Bobz
  • 448 Answers
SOURCE: I can barely be heard.
May not be your headset as the problem. Check you pc for mic level or plug another mic into it. If you have found this helpful or fixya, please post as such. For more help please go live
Posted on Jan 13, 2009
SOURCE: My microphone will not work, and my computer won't recognize!
Common problem with this headset.
In short, the wiring for the mic in the left earpiece is quite shoddy, and over time will be worn away by changing the mic position or come loose with minimal effort.
Have had a over a dozen of these fail in our internet cafe due to this issue after a couple of months use.
Posted on Jul 18, 2009
SOURCE: install wireless headphones
how to change batterys in sentry ho800 headphones
Posted on Oct 07, 2009
Static noise coming from headset. The headset has been making this noise for 3 or more days.
Most headphones (wireless) have a tuning wheel that allows you to find your headphone channel pair to base set. It sounds that while checking your foam ear piece you may have moved this dial / wheel. After locating (probably near volume) the control for tune, place headphones on and slowly move control for tuning. You should hear something move control to strongest signal.
your base also has settings switch for channel helpful if you have more then one pair in house, on different TV. Play with both to find best volume.
Sep 04, 2016 | Jabra GN9330 Wireless Headset
Tip
Sony wireless headphones
i had a problem with too must static noise lots of hiss, i moved the headphone amp away from my x box as that was makin the problem. NOTE that ur tv can make a problem too or pc wot ever but problem shoved.
on Aug 14, 2007 | Sony Camcorder/Audio/Video 900MHz Wireless...
Sennheiser RS 120 headphones won't work, only hear static
Adjust the tuning wheel on the side of the headphones so it picks it up.
Mar 20, 2014 | Sennheiser RS 120 Consumer Headphones
No audio from TV through Wireless Headphone
Unfortunately, this product has a reputation for unreliable operation. Many Amazon users report that they can't get it to work with their TVs. To isolate the problem, try plugging a good set of wired headphones into your television; if you hear nothing, then the TV is at fault. Otherwise, try plugging a different, known-good adapter cable into the TV. If you still don't get sound, then the Genica is broken.
Dec 26, 2013 | Genica MH2001 5-in-1 Hi-Fi S-XBS Wireless...
I own two SAVV VAC-IR14 wireless headsets that I use with my SAVV video DVD car player. I am no longer able to hear anything through the headsets. I've replaced the batteries but no sound. Any...
Try checking the base-station and the frequency they're tuned to.
If they both all of a sudden didn't work it must be an issue with the player or the base-station.
Hope this helps!
Jul 04, 2011 | Savv VACIR 22 Wireless Headphones
How can i activate these headphones??
Is there a tuning swith on the unit? if yes, then turn on audio source you are looking to use. if tv then turn on tv
now you need to use the tuning switch like a radio to tune until you hear the audio.
Thanks
Good luck
Apr 16, 2011 | Farenheit HP900S Wireless Headphones
Static while listening to a dvd through the radio or wireless headset
have you tried changing the radio station. I had this problem and just changed the station on the radio remote and the radio itself.
Apr 27, 2008 | Myron & Davis AD-212 Car DVD Player
Acoustic research aw722
No need to plug into the back jacks on the TV or change the out put of the tv audio source to the Front jacks
Dec 29, 2007 | Acoustic Research AW-721 Consumer...
Headphones for tv
Roy, easy way to do that is go to wally mart, K-mart sears etc. and get a set of "rca wireless headphones" they are inexpensive and the headphones have a volume control built into them so you can have it as loud as YOU want, and the wife can set the volume on the tv where she wants, bought a set for my father-in-law and he loves them, (he`s very hard -of -hearing) you can even walk out of the room with them on and still hear the program, buy them for yourself as a christmas present, enjoy, BMW Rider
Dec 07, 2007 | Televison & Video
No sound, only static
Hi I had the same problem and just emailed Sennheiser.Go to the menu on your TV and change the variable audio output to fixed. I use the headphones through the home theatre so the volume must be max on the home theatre and then you can adjust your headphone volume. It absolutely worked and I don't get anywhere near the static noise when I go to another room with the headphones on that I got previously. Also be sure your audio cable is plugged into the fixed audio output socket. I did not have to do anything with that.
Oct 18, 2007 | Sennheiser HDR 120 Consumer Headphones
Radio Communications Logo
Top Jensen Radio Communications Experts
Mike Charette
Steve F
Tom Chichester
Are you a Jensen Radio Communication Expert? Answer questions, earn points and help others
