Question about GE Monogram ZISS480DRSS Stainless Steel
Water in the freezer
Water come from top of freezer.
  • Anonymous May 02, 2008
    I have the exact same problem. Where is the drain that needs to be cleaned. Thanks in advanced.
My appliance guy said that the tube carrying water to evaporator gets clogged when water in tube freezes up. water then has nowhere to go so drips down sides of freezer compartment. Easiest solution is to turn refrigerator off and allow to defrost for 2 days, doors open. Ice in the hose will melt and hose will dry out and hopefully this will buy us another year or more. It's a hassle to move and store food but cheaper than paying for a repair. he says GE Monogram is NOT repair-friendly (in terms of design); at $95 an hour too expensive to do this repair. Needs a "drain heater" to prevent this from happening. also says this is a design flaw that is well known. GE gives the runaround on the 800 number to discourage consumers. GE does not stand behind their products. We are defrosting now and I hope it works!!
Posted on Jul 12, 2008
Greetings......easy, but time consuming. Did a lot of research on-line with almost zero help. Called GE, also zero help. Did get that the drain hose might be was. If you have one of these GE Monogram fridge's, the drain hose is a clear, large hose that you can see if you remove the cover just above each door. Look on the left side compartment and you will see the hose. It drains into the right hand compartment into a shallow pan, then it evaporated. If it is clogged.....shut down power to freezer side. Take out all the shelves, to make it easier. Might want to remove light bulb so you do not spill water on it and shatter it. With a Phillips Head screw driver remove the ise maker. It just unplugs, then remove the back panel, it too just unplugs. The upper shelve/cover has 6 or 8 screws. Once you remove the cover it might be iced over. Let thaw. There is a layer of foam/instillation that is directly over the coils. This too might need to thaw. Lots of water dripping from the ice melting. You can lower the left hand side of the tray where the water is gathered prior to it going into the clear tube, then evaporated. I got a small 1/4" tube and feed it into the larger clear tube and charged it with air from my compressor. The clog exited in a real hurry into the right hand compartment. Put the freezer back together and good to go. Make sure you get the foam insulation back together properly, screws all back in place and you are back in business. All of this for FREE.
Posted on Jun 08, 2008
Drain needs be clean, Easy to say but is some work to do.
Posted on Oct 25, 2007
Maytag mtb2156de freezer leaking through the top of the frig. The freezer is keeping things frozen, but water is running onto the floor.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Aug 28, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Water is leaking onto top shelf of fridge. It is a top freezer.
Sounds like you have a frozen drain in the freezer. You can remove the back panel of the freezer and take a turkey baster and run hot water down the drain line to clear it. Once its cleared you will want to dump an additional cup of water down to make sure that its clear. This will stop the defrost tray from overflowing when the unit goes into defrost. This is where the water is coming from.
Hope this helps _MJ_
Feb 16, 2010 | KitchenAid KSRA25ILSS Side by Side...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water is leaking on the top shelves in my kenmore refriderator water is leaking on the top shelves in my kenmore
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
May 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Water dripping into refrigerator from freezer
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 12, 2009 | Whirlpool ET1FTKXK Top Freezer...
GE Monogram ZISS480DRSS Stainless Steel Logo
451 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
