Question about Hardware & Accessories
Trying to install a dayton electric mfg timer and need clear instructions on how to wire it
  • 5,245 Answers
Open following link for drawings showing Dayton timer wiring.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Posted on May 29, 2012
  • 460 Answers
I need the serial# please  to better assist you
Thank you
Posted on May 14, 2009
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
I am wanting to energize a relay for 3 min. then off, whether the power stay's on to coil or not! what I want to do is when a door rises and hits a switch I want to energize a coil for 3 min. whether...
You want 3 minute 'off delay' timer.
When timer is energized with push button or momentary electrical signal, circuit remains ON for set amount of time, and then turns OFF.
Aug 15, 2011 Dayton/ Grainger website is offline
Most delay timers have 1 amp capacity rating, so circuit needs fast acting 1 amp fuse, and timer controls separate relay or contactor unless Load is equal to 100 watt light bulb.
3-minute off delay pin timer
Omron shows 120Volt 8-pin M-series-(minute) 3 minute delay timer
Part number H3CR-H8L 120volt M
http://waterheatertimer.org/pdf/Omron-timers.pdf
Example 240Volt timer showing timer and base.
http://www.sourcingmap.com/ah33-220v-030-minutes-delay-timer-relay-socket-p-119441.html
Wiring diagram shows on side of timer.
Aug 15, 2011 | Amperite Dayton Solid State Timer On Delay...
I need to know what to set my dials/sttings on 1EJE8 Dayton Timer. What I am trying to do is sound an alarm when I hit reset the timer shuts off the alarm for twenty min before resounding
Question is unclear.
Help me break it down.
You want to push a button and sound alarm?
And then you want alarm to sound until you push button again?
And then you want timer to delay 20 minutes before sounding alarm again for an unknown amount of time?
What is the reset?
Add a comment and say what control you have wired to the timer and a clear 1-2-3 sequence of events and times for possible help.
1EJE8 is 10-function timer, and no manual appears on the internet July2011.
Magnecraft has same-similar timer, the 820 series.
Open following link for detailed manual with illustrations.
http://www.serelays.com/library/section5/105A_820_Series.pdf
Jul 14, 2011 | Amperite Dayton Solid State Timer On Delay...
To palaboy: when you talk about a switch on the left most terminals, you mean with this switch im enable the timer???
Question is not clear.
You posted about Dayton on-delay timer?
This timer has two contacts, and wires similar to a light switch.
Connect 120V power to terminal 1
Connect wire going to load to terminal 3
Maximum Load is 1 amp so this timer should be wire to a contactor/relay and not directly to Load.
If you have Dayton off-delay timer, open following link for wiring diagram, and to see examples of contactors:
If you have a different timer, then add a comment with clear description of timer or in-focus photo of timer posted on Flickr
Jul 11, 2011 | Amperite Dayton Solid State Timer On Delay...
On terminals 6 & 7 do you need to apply a power source? is terminal 2 the hot from breaker and #3 the neutral terminal?
Following page has Dayton timer wiring:
Terminals 6 and 7 are wired with 120Volt power as shown.
The push button gives momentary impulse of electricity to timer.
Timer activates when impulse of electricity ends.
Timer activation turns Load ON and begins countdown.
When countdown expires, timer turns Load OFF.
Terminal 2 is 125V Hot from breaker.
Terminal 3 is Neutral.
Terminal 1 goes to Load.
Load cannot exceed 1 amp.
So Dayton timer can only control single 100 watt light bulb, or it can control 120Volt coil on contactor.
Contactor turns on Load with any voltage: 120, 240, 277, etc or 3 phase contactor.
Suggest busman in-line 1 amp fuse between terminal 1 and Load to protect timer.
Jan 05, 2011 | Dayton Audio Dayton 6a857 Solid State...
Dries but timer does not turn dryer off.
Malfunctioning Timer...replace your timer.
If your ging to do the job yourself, be sure to get the same mfg of timer that is in your dryer.
Also only disconnect and reconnect one wire at a time.
If you do not get the same timer as came with the dryer you will have to follow the instructions on how to wire the timer,that comes with the timer.
Rate me Please
Oct 03, 2010 | Maytag Neptune MDE4000 Electric Dryer
I got a dayton welding maching model 5756 i need a manual
icon1.gif I got the following from a post regarding Dayton Welding Machines 5756: I have a Dayton 6Z935C welder with manual. It's probably 10+ years old. The address on the back of the manual is
Dayton Electric Mfg. Co.
5959 W. Howard Street
Niles, IL 60714
Sorry, no phone number is supplied.
An attached list of US Authorized Factory Service Centers lists:
EMR (Electric Motor Repair)
2010 North 4th St.
Minneapolis, MN 55411
800-345-0198
612-522-3318
An insert with the manual also says you can call 800-328-2921 for the most current list of Authorized Service Centers.
Hope this helps. __________________
Thanks!
Charlie
Jul 16, 2010 | Garden
Where do i connect load wires to 240 volt baseboard heater
Do you have the installation instructions, they will tell you exactly where to attach your high voltage.
Oct 27, 2009 | Heating & Cooling
Hardware & Accessories Logo
276 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
