Question about Linksys BEFSX41 Router (DHBEFSX41)
3 PC's networked to BEFSX41 very slow accessing internet
Have 3 PC's (2 x Vista, 1 x XP connected to a Linksys BEFSX41 Router; each network connection says running 100Mbits. PC to PC seems (?) to be OK but Internet access is SLOOOWWWWW! Connecting one PC direct to Internet Modem and runs at 85-90% of contracted speed.  Running thru the router getting limp-a-long speeds (per ISP speed test) of 100kbps to 3xx kbps.
Not a router guru but PC/Network savvy.  Any suggestions???
Thanks!
  • clreece Oct 14, 2007
    Please read my original post carefully - connecting one PC direct to the modem and get 85-90% of max speed. Actually I worked with Linksys last nite, they recommended upgrade formware -- did so, hosed the router - now it dont work - their only comment was "Out of warrantee"!  It is several years old.
  • 101 Answers
Sounds like your internet access is the slow down, not the router. You don't say if you have DSL or CABLE or what.  I'd check there. Make sure you are getting a strong signal.  Hook up one system directly, without the router and check the speed.
Posted on Oct 14, 2007
  • Debra V
    Debra V Oct 14, 2007
    call your internet provider, tell THEM your connection isn't up to what you expected.  Then go out and buy a new router.
Wireless g router network set-up
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
thanks for choosing fixya.com and kindly rate this post.
Jan 03, 2012 | Linksys Wireless-G WRT54G Router
Trying to connect my pc to wifi asks for a device ownership password what should i do?
Please try the following:
XP:
1. Go to control panel. open network connections. Right click on wireless network connection and click on properties.
2. click on wireless network tab. in the preffered network tab remove all the networks and click on ok
3. try to connect.
vista:
1. Go to control panel and open network and sharing center.
2. On the left hand click on manage wireless network connection.
3. Select your network and click on remove on the top.
4. Try to connect.
It should solve the issue. If you face the same issue then access the router web interface and change the SSID (wireless network name) and try to connect.
Please let me know if it works for you.
Rashish
Aug 09, 2010 | Linksys Wireless-G WRT54G Router
I have problem connecting new computer to befsx41
1.Unplug the router for 1 minute then plug it back into the AC . Wait........ 30 second to see if you have acquired a signal
2. Confirmed that you have connectivity with the ISP ( internet service provider)
a.Check your wireless setup and see if the wireless is on.
b. do ipconfig / all
c. test the router by setting up the router by MAC address..
Jun 19, 2010 | Linksys BEFSX41 Router (DHBEFSX41)
Cannot maintain wireless connection
Try manually add the network. If the problems continue, I would turn the laptop in for repair/replacement (if it under warranty).
May 15, 2008 | HP Pavilion dv9730us Notebook
Replaced Linksys Wireless-B 2.4GHz 807.11b Router and Wireless B 2.4GHz 802.11b Wireless-B Notebook Adapter with Linksys-N Ultra Range Plus Wireless-N Gigabit Router, and Wireless N Ultra Range plus Dual...
Try resetting your IP address:
The laptop may be trying to use the IP address from the old router.
1) Click Start (assuming Windows 2000, XP, or Vista)
2) Click Run
3) Type in CMD
This will take you to a black command box
4) Type in: ipconfig/release
The chart should show your IP address as 0.0.0.0
Once this has happened, proceed to step 5
5) Type in: ipconfig/renew
You should now see a new IP address listed.
Also note that you need to set up your network key (assuming that you are using one) on both the router and laptop.
Make sure that your router is set up to perform as DHCP server.
FW
Apr 30, 2008 | Computers & Internet
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
Linksys BEFSX41 Router (DHBEFSX41) Logo
370 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
