Question about Acer Aspire AS6930-6560 NoteBook Intel Core 2 Duo T5800 16' Wide XGA 4GB Memory 320GB HDD D...
Can not reboot from dvd back up disc
Keep geting error code 000000000 bin into my f2 setings r ok just will not re-boot can any one help
Will not record and also keep geting error nodisk
Did you try a disc cleaner? Maybe the lens is just dirty.
Jan 03, 2008 | Televison & Video
How to restore to new seting
Welcome to FixYa! I believe you're having problem with the Operating System on your computer. Unfortunately, Lenovo will not provide a product key for the Operating System since the an OEM version. What you can do is reinstall the Operating System using the One Key Recovery Sofware or the Recovery Disc that came with the computer. Follow these steps for you to be able to reinstall the Operating System using the One Key Recovery.
1. Turn off the computer.
2. Press the little button near the power button, it usually do have a drawing of an icon that looks like a horse shoe or a headset.
3. There will be a window that will appear which do have three option, One Key Antivirus, One Key Recovery and System Setup. Choose One key Recovery.
4. There will be another window that will appear which do have two option, Restore from initial backup and Restore from user backup,Choose Restore from initial back up
5. It will asked you if you want to continue, Just click on OK or YES.
6. Once done, Reboot the computer.
For Recovery Disc,
1. Insert the disc inside the drive.
2. Turn off the computer then turn it back on and keep on tapping F12
3. There will a window that will appear which do have three options, HDD,ODD/DVD/CD, and NAT, choose ODD/DVD/CD
4. It will asked you to press any key immediately, you will need to press any key immediately so that it will boot from ODD.
5. It will asked you to choose a partition, choose Disc 0 partition 1
6. Reboot computer once done.
I hope this information will be helpful. Thank you for using FixYa...
Apr 03, 2011 | Lenovo Computers & Internet
How do i get back to factory setings keep geting
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT.
Click Restart when prompted.
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
Hope this helps don't forget to vote
Feb 21, 2011 | Gateway Computers & Internet
How to use a recovery disc for presario cq 60 206us
Set your 1st boot to CD/DVD from your Bios Setting or use the hp Boot utility when you restart your computer.
Insert your Recovery disc into the CD/DVD Rom and reboot your computer. Just follow the installation wizard to install your system back to default/original settings. All of your data will be lost.
**Note
When you use the Recovery disc all the setings will be reverted back to the original settings. Back up or save your data before you use the Recovery disc.
Hope it helps.
Oct 19, 2010 | Computers & Internet
I keep geting a dns error code 80710102 on my ps3 what is this
Hi Sir
80710102 PS3 Cannot connect to the router with current IP information - Try rebooting your router
May 19, 2010 | Sony Playstation 3 (PS3) Console
My Viao wont get past the Viao logo and tells me that no operations system can be found & the recovery utility won't load
put recovery disc in to drive reboot press F2 to go into boot options, set cd/dvd rom to first boot save and exit reboot.when all done F2 again and then Press F9 set to default.
hope this helps.
Apr 29, 2010 | Sony VAIO VGN-NR120E/S Notebook
How do I do a factory reset?
reload from disc or recovery drive, i think recovery is F11button not sure.
to reload from disc go into bios F2 AND SET CD OR DVD drive to boot first save changes then reboot put disc in then reboot again.
hope this helps.
Apr 27, 2010 | Xplore Technologies Xplore iX104C2 Tablet...
Non system disk or desk error
When the system is booting up, go into the bios see if it "sees" the hard drive. If it does then exit and listen to the computer to see if you can hear the hard drive spin up..If not then you need to replace the hard drive.
Feb 25, 2010 | HP Compaq nc6120 Notebook
Pc keeps rebooting and wont even go to safe mode
the os on the harddrive is not recognising the hardware and could be caused by change in bios settings or bad os.
Jan 24, 2010 | Dell Dimension 8200 PC Desktop
Acer Aspire AS6930-6560 NoteBook Intel Core 2 Duo T5800 16' Wide XGA 4GB Memory 320GB HDD D...  Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
