Can bad T-Con board cause Samsung TV to flicker off and on?
I think an LED problem is more likely. The LED strips are usually powered by a driver circuit on the power supply board. You can check this with a bright flashlight shining on the front of the display at about a 20° angle from parallel to the display. If you can see the picture or the menu with the flashlight beam during the "dark" period, the problem is NOT likely to be the T-Con board.
You can also look at the back of the set with the cover removed - most sets have a number of vent holes in the back plate through which the backlight can be seen when it is on. If these holes go dark when the TV goes black, the backlight is being turned off.
When the screen is lit, take a picture quickly and look for dark spots. Maybe one of the LEDs has a partial short that shuts down the LED power and triggers a retry cycle. If so, after a while it will burn out and then the entire LED strip will be inoperative.
