Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
PFN_LIST_CORRUPT - Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
  • ikkenom May 11, 2010
    When do you get this error message, during power-on of your computer, or when starting Windows, or when using a specific program?
Sir bluestaks is not installing in hp 2133 mini laptop ,Sfn : CNU8241BMT,pfn : FH48gPA#ACJ,because there is no graphic card. Then how to install bluestaks.
The netbook hardware is not sufficient to support Bluestaks and with no decent graphics card it will never work, I am afraid you will have to forget the idea or try installing on laptop or desktop PC.
Oct 01, 2013 | Computers & Internet
Error42126rar archive is corrupted
RAR archives Corrupt is a troublesome problem frustrates most WinRAR users. This guide lists the common reasons for RAR corrupt and how to repair damaged RAR Files.
Jul 10, 2012 | Computers & Internet
HP Pavilion DV6 1108 notebook - Blue screen
Yes get and install the latest Video card drivers for you card & operating system, this may help, but FIRST, simply try going into Device manager, and Uninstalling the Driver for the Video card, reboot and let windows install the driver, it may install the "Generic" version,and that may fix your problem. as an aside sometimes it is the RAM on the Video card that goes faulty? Hopefully it will not be that.
Feb 24, 2010 | HP Pavilion dv6000z Notebook
Uncaught exception: java.lang.nullpo inter exception note keeps coming up
Hi, you get this error message when attempting to access a corrupt contact list database on the BlackBerry smartphone, BlackBerry Device Software or software application component has failed, or there is corrupt data from a wired or wireless synchronization.
Isolate the corrupt data by turning on advanced logging for Intellisync
1) Turn on advanced logging for Intellisync.
2) Once the corrupt data entry has been isolated, delete it from the desktop email client and the BlackBerry smartphone.
3) Synchronize again.
Clear the contact list database on the BlackBerry smartphone.
1) Open BlackBerry Desktop Manager.
2) Click Backup and Restore, and then select Advanced.
3) From the Device Databases list, select Address Book, and then click Clear.
4) Return to the BlackBerry Desktop Manager window.
5) Synchronize the contact list with the correct translator in Intellisync.
I hope this information will help you
Nov 17, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
I have a compaq nc6400 gives me blue screen of pfn lis corrupt and irql not less or equal i look up irql not less or equal and it's telling me that it's overheating and that maybe the ram is bad. help me,...
usually blue screen errors are related with the ram memory issues or ...corrupt (bad status) Hdd, but in your case probably one of the coolers doesnt work and it is overheating and forced to shut down suddenly ..,solution is to verify the ram memory ...and check the bios for any temperature limitations...and best is to restore the optimal defaults settings ...( factory defaults ) ...and also try to reinstall the operating system cause it might just have so issues ....also ...try to remove and replace the ram unit in its slot ..to be sure that its all ok ...
there is whatever the possibility that overheating damaged the ram memory already ,.and in this case it should be replaced... but this case its rare ...and ram memory if its not touched by hand ...usually has a life time exploitation period...
so ....either unlimited the maximum cpu temp allowed ..from bios...or find a way to install extra cooler fan...and reinstall for to be sure its all Ok...
Sep 04, 2009 | HP Compaq nc6400 (GJ982US) PC Notebook
Error code 0x0000004E PFN LIST_LIST_CORRUPT
Did you check the CD you used when you installed Windows XP or Vista? A cause of a PFN_LIST_CORRUPT error is a badly copied or scratched installation CD.To work around this, install Windows XP or Vista again - this time using a clean CD and preferably, a genuine Windows CD.Annoying you with a pfn_list_corrupt error is one reason why Windows installation CDs cost quite a sum - its because they see to it that their CDs are free from errors.
PFN_LIST_CORRUPT error and a bad case of memory If you are done installing Windows XP or Vista again, and a PFN_LIST_CORRUPT error shows up when you start up your PC, the problem might lie on bad memory module.
Here’s what you’d do… Try re-seating your memory stick to another slot on your motherboard and restart your computer. If a PFN_LIST_CORRUPT error is still there, then try swapping a memory stick that you know is OK.
When all else fails… If a PFN_LIST_CORRUPT error still keeps on showing up after trying the solutions I mentioned, I’m sorry, those are the two solutions I know that you can do for free. The other choices would be either to buy a new memory module to try out or buy a third party software that tried to fix the problem for you.
Jul 01, 2009 | Edirol Virtual Sound Canvas Multi Pack...
Blue Screen with various STOP error messages appearing.
This is a tough one to troubleshoot since there are several issues which can result in this error. Let me start by listing known causes.
Corrupt pagefile.sys file
Corrupt or wrong drivers for system devices. printer, camera, ect.
Corrupt program drivers, adobe elements, capture card software.
Bad System Ram Modules.
You didn't specify if you installed anything new, hardware or software but to trouble shoot this issue begin by download Memtest86. This will test your system boards memory for errors.
If your ram passes the test you might try removing other devices such as printers and its software. Testing the issue after each uninstall.
Last you can try replacing system files or performing a system repair using your operating system cd. If you need to run the repair option and need help just post back here.
Hope this helps.
Apr 07, 2009 | Dell Computers & Internet
PFN LIST CORRUPT
go in touch with HP customer help and support and they will tell u what to do to solve ur problem....it could be just a setting .....
Mar 12, 2009 | HP Pavilion a620n (PC028A) PC Desktop
Why dose my tom tom stop on a test run half way through the journey
When on test or demo , the tomtom runs on a demo menue list loaded onto the sd card. if the data file on this list is corrupted the tomtom will only complete the demo journey up to the corrupted point in the list. I would suggest that you reload your backup onto your SD card . ( Hopefully you did make a backup to your PC ? ). Other than that , you could try contacting tomtom and ask them which file you need to replace on your SD card in order to replace the corrupted file. You could then either download it from tomtom website or copy it from someone elses tomtom SD card.
Dec 21, 2007 | Tomtom GO 300 GPS Receiver
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
393 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
