Question about Sony Televison & Video
Sony Trinitron - Model KV35S66
The cable on this TV won't work, just shows 'fuzzies' all over, but when you put it on Video 1 for the DVD player, it works just fine and has the clearest picture ever! What do I need to do to make the cable work? (And yes, I have gone through the setup menu and set the cable to 'ON'). PLEASE HELP!
    President:
  • 2,992 Answers
The tuners in many Sony sets often develop bad solder connections that can cause this kind of tuning trouble. The tuner can be replaced to fix the problem, and it's also often possible to repair it. To repair the tuner, it needs to be removed from the board in the set, the cover removed, and all the connections from the tuner circuit board to the metal shield can need to be resoldered. The metal can is used as the ground connection for many places on the tuner, and the connections develop cracks and become intermittent or fail completely. When you use the video input, you bypass the tuner so you have the nice clear picture.
This repair should be handled by a technician who's experienced with soldering on small circuit boards. Improperly done, this repair can do more damage to the small, closely-spaced circuit board traces. Many technicians would rather simply replace the tuner than do the repair. Depending on the price of the part and how labor is charged, it may cost the same either way.
Posted on May 12, 2009
Fuzzy picture
Sounds like an AGC [Automatic Gain Control] problem with its video IF stage circuit. Contact any service technician, or service center. This is not a user repairable fault.
Gopakumar Gopalan Google
Feb 09, 2014 | Sony FD Trinitron WEGA KV-27FS100 27" TV
SONY TRINITRON Model KV2197PF2 have no audio video is ok.
only a few things to check here:
First is does it work when a DVD player is hooked via the audio and video jacks?
Look in audio menu in the set to see if speakers are turned OFF or ON.
Look on the set and a cable or sat box if used that volume is not down or muted.
failing all these the set has a audio problem.
Apr 24, 2012 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
I own an iview 2600hd dvd player and im trying to hook it up to my sony trinitron tv...however, no matter how i switch my cables, the dvd player just won't show any picture or audio on my tv...and when...
Try new cables. RCA cables have a tendency to have bad connections internally. Also, triple check that you're on the right input and the wires are properly connected to the DVD player. If all that fails, try the DVD player on a different T.V. and something that uses RCA cables on your T.V, such as a cable box to make sure the input jacks on the T.V. aren't bad, and the DVD player isn't bad.
Through out all of this troubleshooting, you should manage to get the DVD player hooked up.
Jun 20, 2011 | Televison & Video
I DON'T KNOW WHERE TO PLUG MY DVD CABLE IN TO MY KV SONY TRINITRON- THERE DOESN'T SEEM TO BE ANY PLUGHOLES
Hello
You can connect the DVD player ot your Sony TV in two ways. One way is via AV cable, and the other is S-Video cable. If you use AV cabel, connect the cable's one side ends to output sockets of the DVD player, marked as Audio-L, Audio-R and Video. Connect the other side of the cable's respective ends ot TV's respective sockets, marked as Audio_L, Audio-R and Video. This socket can be located at the back of your TV. If you expects a beetter picture quality, you can connect the TV-DVD by S-Video cable. If you connect it via Audio Video cabe, switch the TV to get AV-1, AV-2 etc, by input selector option. If you connect S-Video cable, Select TV' to recive S-video input via its input selector option. You can do these selections by the help of TVs remote control. OK.
Feb 23, 2011 | Sony KV-36XBR200 36" TV
No sound on my DVD. Using S connector or jacks. Swapped DVD player, checked the cable connections, went through the menus on both the player and the TV. Never was a problem before.
hi,
if you are connected the S video output of ur dvd to ur tvs s video input , the u should connect another two RCA cable fo audio.S video connection is only for video input. connect the audio out put of ur dvd to the corresponding S video audio input, using a stereo RCA chord.
ok.
Dec 21, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I have a 5 year old KLH DVD player. I had it hooked up through AV cable to a 6 year old SONY Trinitron 37" TV & it worked fine. I am now trying to hook it up to a new Westinghouse flat screen TV...
double check the wires are in the correct connections on both the tv and dvd player also the KHL dvd player may need to be put in progressive scan. Usually the red wire for video and the one for audio get plugged into the wrong input and causes this issue
Dec 10, 2010 | Televison & Video
CONNECTING THE PANASONIC SC HT680 TO A SONY TRINITRON COLOR TV AND CABLE BOX
audio/video OUT from the cable box to the aux IN on the panasonic right? So you can see the output from the cable box but only sound from dvd. Are you changing the input on the tv when you go from watching the cable box to watching the DVD? the panasonic handles audio, but the video from each goes to two different inputs on the sony. I hope none of this sounds condescending.
Jan 27, 2008 | Panasonic SC-HT680 System
Trinitron KV20FV12 sony
check the video cable first / next try using a s-video or hdmi cable some dvd players you have to select the way the picture is sent from the dvd player
Dec 10, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony Trinitron KV35S66
Dear EDKELL,
Before you buy that HD flat panel. Try this; disconnect the cable going in to your cable box and connect it directly to your set's cable RF connector at the back of the TV set, then try changing channels with the TV's remote, you may need to do an Auto Program first. Also make sure you select the correct tuner, that is tuner A, or B.
Hope that does it!
Toprol
Oct 30, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Oct 16, 2006 | Sony KV-32S25 32" TV
Televison & Video Logo
73 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
