What you are describing is the power supply failing because of bad capacitors.
Sorry, I never thanked you for your help. I tried replacing a few and then the whole board but it's still doing it but now getting worse. I re-posted all the issues that I could think of hoping someone may give me a clue lol or it is just time for a new set?
What is the exact model number?
samsung HLT6756WX/XAA
So you have replaced parts on this?http://www.shopjimmy.com/samsung-bp44-01... OR was it this?http://www.shopjimmy.com/samsung-bp47-00...
I replaced the power supply board to make sure I got all the caps, even if they looked ok. after turning on and off, going though screen freeze, plaid non moving colors and some times slow power up withdelayed pic and sound, the a great picture? ?
There is a fix for the screen plaid issue that you are talking about. IT is chip that you have to order. I am not convinced though that the inverter is ok
Is the chip that you are talking about the DLP chip? if so I replaced that already to get rid the white dots.
I may look into the inverter because it sounds like caps same symptoms, that's why I replaced the whole power supply board, maybe even a ballast issue. Something that when it gets warm it works but now from a cold start. Thanks again for your help
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
SOURCE: Numerous white spots on Smasung DLP TV
If your Mitsubishi TV has white spots in the picture , you can call Mitsubishi @ 1-800-332-2119 and request a free DLP Chip to fix the problem. They will send the New DLP Chip at no charge to a TV Tech in your area to install it for $200 flat rate. That is about a $250 savings if you had to pay for the chip . Call them with your TV's Model number and serial number and let them know when and where you bought the TV.
It saved me some hard earned money and now my TV is like New !
SOURCE: white dots on my samsung dlp tv
Samsung DLP Projection Tv white dots may caused by DLP Chip. Change a new DMD Chip 19106143W. The post show you how to replace it step by step.
Your chip should look like this:
