Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Thank you for answer to gas cap in tank. It was a small white plastic cap that fell in. I tried topping tank to see if it would float to top where I could see it, but I never saw it. It has been over a year now and no sign of it. It hasn't affected my JD 755 diesel yet, but will it
  • 246 Answers
Hello barbinthebar:
If the Cap was Small, then it May Simply Degrade and Turn to a Liquid and be Burn with the Gas.
>>I had a Customer have this Happen a Few Years Ago and by the Time the Shop was Told and Tried to Locate it in the Tank it was Gone.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
Water is not coming out on the top of the fill tube that connects to the overflow tube
It doesn't usually have water coming out. If it fills the tank, it is ok. The water is coming out at the bottom anyway. However, the adjustment on the tube is off and not allowing water in .
Feb 16, 2013 | Kohler Toilet - One Piece with Ingenium...
Po422 trouble code for 2001 dodge ram
There is a leak some where , check the lines where they have rubber on them check for cracks, the dodge is known for broken rubber boots on the end off plastic lines going to purge valve, the other problem is the top of the tank, the ring that holds pump unit in tank may have a leak.
The best way is to smoke test the system for leaks. and last is the filler neck rusts out and may have small hole
Oct 06, 2012 | 2001 Dodge Ram 1500 Truck 2WD
Need to replace the fuel pump in 2005 kia sedona
The fuel pump is in the gas tank and access in inside the van between the first row and second row of seats. The access is covered with a carpeted cover and then another metal cover which screws into the gas tank. Then there is a cover top of the assembly.
You must use a brush and clean off all the areas before removing the pump or the dirt will get into the gas tank. Disconnect three electrical connectors and two fuel lines. Mark the fuel lines so you are not confused to put in the new one. The electrical conectoers are individually different from each other.
2005's do not screw into the tank, they have clips. The clips have tabs imbedded into the top so you know where they are located to disengage them.
The tank lifts out and the float mechanism requires you to live it up and then tilt and shift it to get the float mechanism clear of the gas tank hole.
Jul 13, 2012 | 2005 Kia Sedona
I pulled the top off and found a very small white piece of plastic on top of optical reader that was scratching my dvd I think it was a lense but the small end of it was broken Please help me with this...
If it is the lens cap, it should be clear and not white.
White is usually part of the gear system mechanism for
the DVD tray. Try ejecting and closing the tray. It should
be running smooth with little hesitation.
DVD burners are now so affordable, I'd really question if
it is worth to fix it.
Jul 18, 2011 | Computers & Internet
Finding brajke fluid reservoir
It is in the engine compartment, directly above the steering shaft in front of the driver-look for a white plastic tank (small) with a black cap on top.
Jun 30, 2011 | 1996 Toyota Celica
Will gas cap from can corrode in my tank?
Hello
The Cap can Corrode or even be Pulled Over the Outlet of the Tank and Restrict the Gas Flow to the Carburetor.
If the Cap is Metal, then use a Telescoping Magnet (avaliable at your Local Auto Parts Retailer for less then $10.00) to bring it to the Surface and then Needle Nose Plyers to Remve it from the Tank.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Fill watertank message will not go away
This happened on my unit. There is a magnetic float in the tank that rises when the tank is filled. On my unit, the float (which is supposed to be sealed) took on some water, and stopped being bouyant. I had to break off the clear plastic cap that keeps the float in place, remove the float, and ***** a tiny hole in the float and squeeze out the water. Now (since I have a hole) I have to do this repeatedly - every week or so - though its easy to remove the cap now. Still looking for a replacement part.
Dec 30, 2008 | Gaggia Titanium Espresso Machine
I was putting gas from a gas can in my Honda CRV 2001 and the plastic nozzle on the gas can popped off and fell into my gas tank.
this should not cause you any problems it will just float around in tank. you can try and pull off filler neck to remove it may not have gone in tank.
Oct 22, 2008 | Honda CR-V Cars & Trucks
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
70 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
