Question about Minolta Di3510f Bizhub Copier
Gray plastic piece that holds the black clips that holds the door shut is cracked
The component that holds the door closed (long metal bar w/ black plastic clips on either end w/a spring, when you close the door, these black clips hold the door shut...well the plastic gray piece that holds the black clip in, is cracked on one side so the door won't stay shut,and therefore won't work.....
  • Minolta Master
  • 6,161 Answers
You tape the door shut just make sure tape does not cover and vents. check web sites for parts?
Posted on Jul 19, 2009
Sharp r520kst door wont stay shut
If the door will not stay closed it is the spring inside door, or the small plastic piece that holds the spring which is attached to the $80.00 piece called outer door.
To fix it, it is EASY and you do not have to even take the inside cover all the way off. Just remove the three sides of cover by gently slipping a plastic putty knife around rim to release the clips. Then attach the spring to the small hole below where the plastic piece used to be, which is located in the metal on the glass frame piece, use tweezers, hold the other end of spring as you place spring onto plastic door latch and set into place!
Snap the inside cover back on and YAY! FINI!
Mar 23, 2013 | Sharp R-520KST Countertop Microwave Oven...
Sharp r520kst door won't stay shut
Aug 20, 2012 | Sharp Microwave Ovens
How do I install a new Handle/Latch assembly on the door of a Whirlpool LHW0050PQ 4 Wash Machine...have to remove present one as broken---pull handle door catch does not release---have to release putting a...
I had to replace part No 8182408 - the washing machine door handle. There is a plastic bar in the middle of the assembly that broke because the door was opened too hard.
There are two springs, the latch, and the plastic piece that brings it all together. The smaller spring is the key, call it the L spring. It is shaped like an L and goes around the ends of the latch. The other spring is the larger and straight and goes around the tops of the plastic piece. The straight spring goes in with the crossbar facing on the outside of the washer. The latch with the L spring fits in between the plastic crossbar with the U shaped end pressing against the latches inside bar. The antenna of the L spring needs to wrap around the plastic bar and fit inside the straight spring bar. This applies pressure on the latch to stay closed. When the handle is pulled, it releases the pressure and allows you to open the door. The Metal bar is used to hold all the pieces together and once you have the alignment right, put it back into the door with the straight spring antenna tucked in the spots on the door, as well as the metal bar ends. Screw in the two spots that holds the assembly in place and you will be set. The door should open and shut easily.
Apr 22, 2011 | Whirlpool Washing Machines
My 2000 e46 bmw heater blower not working, i've checked the fuse
The E46 blower resistor is harder to remove than the E39 .
Open the Glove box.
Remove the three phillips screws across the top of the open box. Remove the two phillip screws that are deeper in on the sides of the open box(nine and three o'clock). Hard to see, use your flashlight. With these five screw removed remove the glove box. Disconnect the flashlight charger plug, and the glove box light connector. Pay attention to the wire routing. Remove plastic cover behind glove box. Locate motor and metal link to one of the a/c doors. Remove the metal arm from the plastic clip. Slide motor out and disconnect. There is an odd shaped black plastic piece with two T-20 or 25 Torx screws that need to be removed.Remove plastic piece. The Final stage is located behind the metal arm for the a/c door.R emove the floor heater duct for more room. You may or may not feel the need. If you wish pull on the leather extension to the center console outward until you hear a loud plastic cracking. Stop. Take a deep breath and know that you have broken nothing important Remove heater duct careful not to break the blend air door cam (white) and the lever connected to it (black).
You can pull that black lever out if you are patient. Back to the final stage now that you have more room. It is the component with the 5 0r 6 large gauge wires on the connector. Push back the black plastic clamp while pulling/wiggling on the connector.
The final stage should come out, then disconnect the connector. Reinstall all. Make sure the heater duct is installed properly if you removed it.
Sep 08, 2009 | 2001 BMW 325
Freezer door won't close - plastic piece that goes under door is raised up and blocking door from closing
There are several type of attachments, so pick the one best suited to you....
1. (most likely) With the door open, pull on the plastic panel. If it is held on by clips, it will pull straight off. Look carefully at the clips on the panel. Usually, they bend out of position after being forced back on. Adjust the clips, and gently press back into place. If they are damaged, the clips can be reattached with a 2 part epoxy. I prefer JB weld epoxy.
2. Locate the screws that holds the plastic piece on, and loosen them. Adjust the piece. Tighten the screws.
Best regards, --W/D-- please feel free to rate this solution! thanx!
Aug 01, 2009 | GE Freezers
Spacebar on IBM Lenovo ThinkPad X61 came off.
I took mine off to clean under it and had a similar problem. After a bit of struggling I figured it out. I will try to explain it as best as I can, but forgive the non-technical language:
There are two gray plastic pieces on the space bar that must be that must be latched to the two white plastic pieces on the computer. The gray pieces pop off the space bar easily. Take them and put them on the white pieces on the computer so that the white arms lay across (and snap into) the top and bottom of the gray piece. The middle of the gray piece will sit in between the two arms that are not "holding" the gray piece. Then take the space bar and put the metal part into the hole on one side (outside of the plastic pieces) and then push it over so you can put the opposite metal part into the other side. Then push the space bar straight down and it will snap into place.
Apr 12, 2009 | IBM Lenovo ThinkPad T61 Notebook
Exterior rear door handle on Honda Accord 2001
To Remove Door Panel on 2001 Honda Accord:
A: To remove the plastic piece with the door lock button and door handle connected to it:
1- Remove the screw in the middle located behind a plastic cover button
2- Push (slide) the whole assembly Forward (toward front of car)
Besides the screw, it is held in place by 3 hooks on the backside that hook into holes in the metal door frame
3- Now unhook handle from small metal bar going through door by pushing (toward door) plastic clip (blue?) off of the bar, then the bar will come out of the clip hole, thus releasing the handle.
4- Depress little grey button /bar (purple painted on it)on elec. connector to seperate connector, thus releasing door lock switch
Now the whole assembly (metal handle, door lock switch, and plastic piece) will come off door panel
B: The door is held on by 2-screws, 7-plastic snaps/plugs, and 1-plastic plug.
The screws are located: bottom of hand hold and the other behind the handle, both covered by little covers that have to be pryed off to access the screws.(hint: the screw with the built in spacer goes behind the handle when you are trying to reinstall)
The 7-plastic snaps: 3 across bottom and 2 on each side. Not visible, they are mounted to the inside of the panel.
The 1-plastic plug is visible at the upper front of the panel and is the same color as the surrounding trim
C: Take off the big plastic triangle piece above the door panel and behind the mirror. Pull/pry off. It has 2 snaps holding it on. one near bottom and one near the front.
D: Light lens prys off from bottom. Unscrew (1/4 turn) the light assembly with bulb still intact from backside of panel
E: Remove the Hand-Hold/window switch assembly:
Jan 14, 2009 | 1997 Toyota Camry
Kithchenaid Microwave
You'll notice there are small clips holding the stainless outer door to the black metal inner door. Get a bunch of putty knives (butter knives work too) and work a knife into about every other clip. I did it on the bottom. Once you're sure all the bottom clips are free, and you've removed the three screws on the side of the door, you'll be able to gently pull the stainless outer door away from the black inner door and get to the handle screws.
I bent both doors in this process, and tore the black plastic liner into a few pieces while I was getting everything out, so I had to buy a new door ($200). Be careful.
Sep 09, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Rear power window will not roll up and can not get door pane off to service, located right rear door
To take panel off you.
1.Unscrew door lock knob.
2.Open door, look where it latches,Take the little black piece off.
3.There is a U-shaped plastic piece at the top of the handle you close the door with,Carefully pry it out.
4.Take the 10mm bolt out.
5.The black plastic piece that holds the chrome handle you open the door with,Slide it to the right.
6.Lift the whole panel straight up.
7.Unplug window switch.
If you pull out the door clips will pull off, You can glue they back on with some 2 part apoxy.
Good Luck
Jul 26, 2008 | 1989 Mercedes-Benz 190
HQ7825 Head retaining clip
The clip that holds the head closed and on broke. It is a small gray plastic piece. model speed - XL
Oct 21, 2007 | Philips Health & Beauty
41 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
