Question about Insignia LCDTV26 26 in. Television
Unknown input timing
Ok. i have my Insignia ns-lcd26a hooked up to my ps3 via hdmi cable. it was working fine one day but i had to go to work. i shut it off and now the tv displays no signal then freezes. after it freezes it starts like turning white and spreading all over the place, i've never seen it before and dont know what to do. first thing i did was eliminate the ps3 as the problem. i hooked it up to the tv with the old cables and did the video reset. it worked. (the most crappy graphics ive seen in a LONG time lol) so, out of curiousity, i hooked up the hdmi cable, did the video reset sequence again, it came up and asked if i would like to use the hdmi for video. i said yes, obviously, then it asked if i would like to use the optimal settings, i said yes. the display went blank and now displays no signal for a minute then comes up with unknown input timing. anyone know whats going on?
  • 2 more comments
  • mefredd May 12, 2009
    ok, i just hooked it up via the hdmi cable but didnt choose the automatically select optimal settings thing. i went through and found that the tv works great using 480p, BS for graphics compared to what im used to but it works, sound works right and everything. i tried switching it to 720p and it did the whole unknown input timing thing again. not sure what to do
  • mefredd May 15, 2009
    also, my bose 321 system is hooked up to the tv with an optical cable. the tv no longer sends a signal to the bose. i tried hooking another tv up to my bose with the optical cable and it worked fine.
    somebody anybody gimme some help here. im dying to know whats up with my tv and if i need to buy a new something (proove to the wife without any doubt that i need a new one and i get a sharp aquos 42 inch 1080p:D)
  • stoneheaded May 11, 2010
    NEWS from CPSC
    U.S. Consumer Product Safety Commission
    Office of Information and Public Affairs
    Washington, DC 20207
    FOR IMMEDIATE RELEASE
    April 2, 2009
    Release #09-183
    Firm's Recall Hotline: (800) 233-0462
    CPSC Recall Hotline: (800) 638-2772
    CPSC Media Contact: (301) 504-7908
    Best Buy Announces the Recall of Certain Insignia 26-Inch Flat-Panel LCD Televisions Due to Fire Hazard
    WASHINGTON,
    D.C. - The U.S. Consumer Product Safety Commission, in cooperation with
    the firm named below, today announced a voluntary recall of the
    following consumer product. Consumers should stop using recalled
    products immediately unless otherwise instructed. Name of Product: Insignia 26-inch flat-panel LCD model IS-LCDTV26 televisions
    Units: About 13,300
    Importer: Best Buy Co. Inc., of Richfield, Minn.
    Hazard: The television’s power supply can fail, posing a fire and burn hazard to consumers.
    Incidents/Injuries: Best
    Buy has received two reports of fires that included damage to the
    television and wall. One consumer reported minor burns to the hands.
    Description: This
    recall involves Insignia 26-inch flat-panel LCD televisions, model
    number IS-LCDTV26. The model number is printed on the back of the
    television and the word “INSIGNIA” is printed on the bottom front. No
    other Insignia model televisions are involved in this recall.
    Sold exclusively at: Best
    Buy stores nationwide, at www.bestbuy.com, and
    www.bestbuyforbusiness.com from August 2005 through June 2006 for about
    $800.
    Manufactured in: China
    Remedy: Consumers
    should immediately stop using the recalled televisions and contact the
    Best Buy hotline to receive a gift card for the value of a replacement
    television.
    Consumer Contact: For
    additional information, contact Best Buy at (800) 233-0462 between 9
    a.m. and 9 p.m. CT daily, or visit the firm’s Web site at www.bestbuy.com
How do you hook up cable box using coaxial in hdmi out
If your cable box has an HDMI OUT connector you simply connect the HDMI cable to the TV and the coaxial cable from the cable company to the coaxial input on the cable box. Then select the HDMI input on the TV that matches the number of the HDMI input port you chose on the back of the TV.
Mar 03, 2016 | Insignia NS-LCD32 LCD TV
Playstation 3 works fine useing the av hook up but won;t work with hdmi cable hook up.
First, make sure your TV is on the appropriate input for the plugged in HDMI cable. Once this is completed, turn your ps3 on. If the screen comes on and is black, turn the ps3 to standby (red light is on) and hold the front power button until the console beeps a second time. This will usually force the ps3 to recognize the hdmi input and will bring up the menu to configure the AV settings.
Aug 13, 2014 | Sony Playstation 3 (PS3) Console
I have a Toshiba 40"
ok if you go to your ps3 video settings you can change the out put from coaxial to hdmi. and you have to have both wires conected at the same time . go to ps3 video sttings change the settings to hdmi then on your tv change the input to the hdmi port you are using then confirm the change and save.. i hope that helps :)
Sep 20, 2011 | Televison & Video
Need base for Insignia NS-LCD26A
Parts for Insignia TVs can be ordered by visiting BestBuy.partsearch.com or calling 1-888-237-8289.
Apr 07, 2010 | Insignia LCDTV26 26 in. Television
Insignia (ns-lcd26a) picture problems
ns-lcd26a
Hi,I fixed my here's issues i had and the fix i did..
ns-lcd26a
Every now and then i would get snow and a pink picture.
Then tv stop turning on .
To fix i seen on main board capacitor cp25 and cp28 near the heat sink was bad
They were both 470uf 35v...
on the power board i seen c531 47uf 50v was bad.
i also heated up the heat sink on the main board to resit the chip ,,
and tv now works
I didnt bother putting the huge shield back on main board i figure it was a issue to over heating the cpu instead take the hit to the brain from the fcc radio wave lol
First do the 3 caps and see if it works if not then do the blow dryer to the heat sink on main board
Aug 20, 2009 | Televison & Video
Powers on - no output to TV
Ok, this is general hardware failure. This will need to be repaired by a Sony tech asap. the central board is malfunctioning at this time. Contact Sony asap.
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
Does the Insignia ns-2brdvd digital opt. output work with HDMI
Below is what your manual says abour it. From hardware perspective, when you have a disc in there the optical audio driver is active and so is the HDMI audio. To verify, lift the lid on the optical interface and you will see a red or blue light on the inside. Don't look directly at it! View from the side.Plug that into your home theater system, select that input on your home theater and you should be good to go.
Insignia NS-BRDVD Blu-ray Disc Player
www.insignia-products.com
Connecting a digital audio optical system
To connect a digital audio optical system:
1Make sure that your player and the TV are
turned off.
2Connect one end of a digital audio optical
cable (not provided) to the DIGITAL OUT
(PCM/BITSTREAM) OPTICAL jack on the
back of your player.
3Connect the other end of the cable to the
DIGITAL AUDIO OPTICAL INPUT jack on
the digital audio system.
Aug 11, 2017 | Televison & Video
Cascading white craziness
First thing you should try is using the regular old AV cables. That way we know if it's an hdmi problem or a video problem with the PS3. Hook them up, do the manual video reset ( hold down the power button until you hear a second beep, quickly release) and then post back here with the results.
May 11, 2009 | Sony Playstation 3 (PS3) Console
Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Jul 23, 2008 | Televison & Video
Insignia LCDTV26 26 in. Television Logo
987 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
