Question about Nikon CoolScan V ED Film Scanner
Film stuck in SA-21 film strip adapter
The film is stuck in the SA-21 film strip adapter in my Nikon Coolscan V The green light blinks quickly at start up (though the blinking stops after several sections) The eject control is non-functional in the NikonScan Software, the buttons have "flattened out" The unit is no longer under warranty. Nikon reccomends that I send it in for repair
Nikon coolscan 5000ed, film stuck, will not eject
If you switch off the scanner you should then be able to remove the grey film holder, even though the film strip will still be inside. Then, press the small button above the film entry slit to open the front of the holder. Pull up the top cover, ease the bright metal holder strip forward then lift the metal flap that holds down the film strip. At this point you should be able to remove the film strip. Re=assemble and try again.
Good luck.
May 18, 2014 | Nikon CoolScan V ED Film Scanner
I am getting a notice saying hardware error Coolscan V ED
you must perform a p.o.s.t. reset. That is:
1) switch off the scanner
2) swithc off the PC
3) disconnect scanner from PC
5) remove the dia/film adapter
6) switch on tyhe scanner and wait untill it booted
7)insert the film/dia adapter
8) connect scanner and PC
9) switch on the PC
it should work now......
Jul 08, 2010 | Nikon CoolScan V ED Film Scanner
Nikon Super Coolscan 5000 ED
The scanner is only 24mm wide and 36 mm long, so rotate you slide by 90 degs.
May 03, 2010 | Nikon Super Coolscan 5000 ED Film Scanner
No error message displayed when film jams
Take it into nikon specialty shop for a service.
Aug 18, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
SA-21will not pull film strip into chamber
Put the film in after it is powered up. The unit needs to run through a power-up and calibrate cycle first. Once powered up, the until will feed the film in once it reaches a certain point into the machine.
The unit is supposed to kick the film back out when you close down the scanning software. If your film ever gets stuck try this to get it out. DO NOT force the SA-21 out of the machine with film stuck in it.
Aug 13, 2008 | Nikon COOLSCAN IV ED LS40
Glass neg carrier - Nikon Coolscan 9000
Not to sound rude, but are you inserting it with the arrows pointing into the scanner?  That is the first step. Afterwards makesure you have the scanner on and the green light is not blinking.
Mar 11, 2008 | Nikon CoolScan 9000 ED Film Scanner
LS 2000 w/SCSI connection
does the nikon scan sofware recognise the scanner ?
Sep 20, 2007 | Nikon LS 2000 Film Scanner
Nikon coolscan 9000
Close the scan program --turn off and unplug the scanner---plug the LS9000 back in and turn it on----reopen the scan program--this is my method on my LS-8000--It does this quite often !
Aug 30, 2007 | Nikon LS-9000 Film Scanner
Coolscan ed 4000
The scanner has a lock which locks the film adapter into the scanner when film is inserted. You probably still have film in the adapter from the last time you used it. If the adapter is pulled to remove it, the connector can become disconnected, which prevents the film from coming out, but the latch is still engaged. With the scanner off, push in the adapter to mate the internal connector. Turn the scanner on then off, the film should eject. Once the film is ejected, the adapter should be able to be removed. Refer to your manual for reference to this problem, I have experienced once before. Once you figure it out, you will not forget, I guarantee.
Aug 15, 2007 | Nikon Super Coolscan 4000 ED Film Scanner...
Nikon CoolScan V ED Film Scanner Logo
287 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Ric Donato
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
