Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Lamp/other I've had my 62525 about 4-5 years. The lamp has burned out a number of times; at first I bought the mitsu replacement lamp for $225, but the last time I bought one for $130. The screw on top of the lamp was different, but I was able to make it work. It has worked for 3-4x as long as the more expensive lamp bulbs, although the yellow light came on quite a while ago, telling me to replace bulb. Yesterday- the tv would power up, gave me a blue screen with a green spot (consisting of a number of horizontal lines), that fluctuated as tv picture changed ( i had a second tv hooked up that I could see). The device menu would come up, and I tried switching devices around to see if I could get anything different, but no. When I plugged cable line directly into "ANT-1" or "ANT-2", the entire screen was green, with white spots. This too fluctuated as picture changed. No sound. Any help would be greatly appreciated.
  • 2 more comments
  • thatguyflint May 12, 2009
    The main board is very expensive, I would imagine. It hasn't been 3-4 years with this lamp, maybe about a year.
    The TV was turned off overnight, already.
  • thatguyflint May 13, 2009
    Thank you for your reply.
    Where might I find the IRC cable. Is it the large black cable with a white connector?
  • thatguyflint May 22, 2009
    OK, have replaced lamp, and now the picture is rolling up and down, I get white noise, and no picture w/cable directly into Main or ANT2. Still don't know where the "LVDS" cable is.........
    Thank you in advance for any help.
  • Mitsubishi Master
  • 3,866 Answers
Well, the last thing to try here if your lamps are giving out is to test the volts the psu is giving them and make sure its regulated and that there is no capcitors that are bulging or even exploited in the unit itself and if so repace them will indeed increase the life of the lamp itself
Posted on May 14, 2009
    Genius:
  • 1,239 Answers
Hi I am Abhishek,welcome to fixya,
I think this is not the problem of lamp,when lamp burnt out it seem to be indifferent,,,,it is the problem with your multiwire cable (LVDS).
When you open your tv there is a multiwire cable (LVDS) which connects main board to LCD controller.Most of the time it is the problem...your tv picture will come back as soon as this cable is unplugged and plugged again from both ends......
if this doesnt solve the problem change the cable,,,,,,my another doubt is colour wheel....but this is the common problem
try it and reply me back,,,,,,,,,,,,(one thing check the incomming voltage also)
thank u,,,,,,,,,,,,
Posted on May 12, 2009
  • 749 Answers
It seems like there may be a incompatibility with the replaced lamp you have had it working for 3/4 years but within time this may have damaged your main boards causing a malfunction, you will have to get your tv's main board replaced.
  • Muzzammil Ishfaq
    Muzzammil Ishfaq May 12, 2009
    yes the main board IS expensive but the $130 was not designed for your tv, and now the tv is showing sighns of malfunction, try to plug your tv for 30mins and try again and if the problem persists it means that your tv main board has permanent malfunction.
WD-62525 wont turn on after replacing lamp
After replacing the lamp, the lamp time should be reset. Do this.
Jan 29, 2013 | Mitsubishi WD-62525 62" Rear Projection...
Replace the lamp and turned it on. Once the timer stopped blinking, I turned the set on. No picture, but got sound. Then after a minute or so it shut down with the red lamp light on.
Pull the lamp out and then back in again. That model mitsu can be very hard getting the lamp in just right. It sounds like it is not getting plugged into the ballast all the way. And make sure you put the door back on, because it has a safety switch that will trigger a bad lamp light as well.
May 04, 2011 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525 went dead. Can a burned out lamp cause this?
No, a burned lamp would cause the power source of the tv to go in reduced mode and that would be clearly identifiable by the blinking lights on the status and lamp indicators.
If the tv is dead (no lights whatsoever)it means that the power source has failed completely - this is a big defect, that must be investigated by a pro: the origin of the failure must be found and the faulty part replaced replaced or any new part you just put in blindly will be instantly fried. At least the power source board will have to be replaced and that will cost you around $250.
Jan 03, 2011 | Mitsubishi WD-62525 62" Rear Projection...
My 62 inch dlp tv came on and was working then with out any noise or notice the picture went to black and a steady red light came on under the word "lamp". We looked at the bulb and it does not look burned...
The tv lamp was replaced when? The tv on about 4 or 5 hours a day right?The lamp was replaced about a year or a year an a half ago?The projection lamp is dead,the life span is over.Must replaced with a new lamp.
Jul 01, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsu WD62525 - replaced lamp & after startup, lamp light is solid red. Anything else I can do?
Try the V26 Power pwb repair kit at www.tvrepairworld.com that will usually repair the issue. The kit contains the parts and the CD with instructions
Nov 05, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replacement Mitsubishi lamp busted again in less a year!
A Halogen lamp is a Halogen lamp. They are designed to last between 3000 to 5000 hrs.
You got a much longer life than expected on
the original lamp.
Jul 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Red light stays on after lamp replacement and reset
if the lamp light still remains solid red its most likely needing the capacitors on the power pwb replaced very common problem with the V26 Chassis DLP. You can get the V26 power pwb repair kit at the following link which contains the replacement capacitors and step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Feb 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Screen is black
Mine just went out today......1 year and 7 days after purchase.
Nov 12, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
124 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
