Question about Hitachi RAS-09UH Air Conditioner
Goodman split not responding to remote
Have a Goodman split in my place. Turned on for some heat this morning, and then went to turn it off about 40 minutes later, no beep, no turning off. Got back this afternoon, tried new batteries in remote, no response from unit.
Tried holding remote directly up to IR eye, no response.
Have no manual, appears to be no way to turn off on the unit, Goodman apparently does not have downloadable manuals.
Other symptom, remote changes back to Celcius frequently, apparently on its own.
  • olsh_2000 Jun 30, 2008
    Have the same problem with a Hitachi RAS-18J . cannot get unit to work. changed batteries , twice. Checked power .
    Reset remote. no response
    Do you know of any other options ?
  • 4,655 Answers
First turn the main power off to the unit at the breaker, wait about five min. and switch the breaker back on, then see if this solves the problem. In the instalation manual that came with the unit on the last page you will see a code of the red blinking light, this will tell you the most likely problem if not solved by switching the breaker on again.............Hope this helps
Posted on Oct 21, 2007
  • 3 Answers
Buy a new remote. hvacguyy.tripod.com to change to f or c hold in complete up and down menu button
Posted on Dec 01, 2010
My Goodman split unit has bumping/knocking noise sometimes (not everyday) when heat first kicks on in the mornings only. What could this be? Also in defrost mode should the unit blow cold air?
May be the fan in the external unit is ruined or the internal pump is comming loose. But note that the pump also make much effort until the gas flows smoothly through the pipes .
Feb 27, 2015 | Goodman Heating & Cooling
Goodman Model # GMC070-4b
is the thermostat set for heat and you have power going to the unit correct
Jun 05, 2017 | Goodman GMS90703BXA Heater
Goodman Heat Pump laing heat and loud noise
Taking a little bit of time for heat is normal but the "pressure" thing you are referring to leads me to believe that the reversing valve is getting stuck. You will here that "pressure release" noise with a reversing valve but it should not be happening 5 minutes after start up.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 06, 2017 | Goodman Heating & Cooling
LED LIGHT BLINKING OF HITACHI SPLIT AIR CONDITIONER
Did you figure out why the ac wasn't responding to the remote? I am having the same problem. I just cleaned out the filters but it's still not responding to the remote. I have already tried reset button in the remote, which didn't help. I am pretty sure that the remote is not out of battery.
Jun 18, 2012 | Hitachi Heating & Cooling
Our older model amana wall unit is in the garage and worked fine until we programmed a new remote control garage door opener in there this morning. The ac unit was not on at the time but we went to turn it...
If it says E0 then what this usually means is that the unit was unplugged or power was cut to the unit while the unit was on. It then needs to be programmed again. If its the amana/goodman RSKP0009, you need to hold temp up and down arrows down together for two seconds then press off twice. It will take you into the programming mode. Settings are different for heat pump and electric heat models. If you just need a quick fix to get it to cool, I think you can get away with pushing the heat button a few times and then off. If you did it right the display should go off and the light by the off button will turn on. Press cool and it should work.
Aug 14, 2011 | Amana Heating & Cooling
Have an LG split system air conditioner. No way to turn it on or off on system. Remote only and it is not working. Did this a week ago and changed batteries, took a while before new batteries worked as...
Before buying new one, try with this step. Remove batteries from your remote and reset it after 5 minutes. And also remove DC wires plugged to indoor sensor display, and after 5 minutes re set it again. Now start your unit. Sometimes it will work out. Thanks.
Feb 02, 2011 | LG LSC121PMA Split System Air Conditioner
Intermittent pefrormance of GDT070-3A
It probably went thru the 3 cycles and shut downed. To reset it you have to kill power and restart it, sound like loose connection .
Dec 19, 2009 | Heating & Cooling
Hitachi RAS-09UH Air Conditioner Logo
1,021 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Marvin
Marvin
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
