Question about Soundstream SPL 15 Car Subwoofer
Holes There's almost a whole in my 15" sub! Is there any way I can fix it?
  • brink722001 May 11, 2010
    the last posting is incorrect. If the cone is loose, cracked or crushed you can suffer in sound quality. The imperfection causes acustic distortion which in turn, if at high enough volume, can cause the voice coil to drag on the magnet pole, buzzing in the speaker, or just poor sound. There are many epoxies out there that will handle the task. I suggest one that requires a cloth mesh then epoxy.
  • brandon damron May 11, 2010
    if the whole is not onthe cone but on the dust cover then you hve nothinto worry about
  • 232 Answers
Why does my spa 500 amp blow a fuse every time I hook up my 15" lanzar sub to it
Because it's drawing more power than the fuse can handle get a fuse with a higher rating. A 100 app fuse worked great for main power with my setup 760w amp a 15"sub 2 10"subs and a 12" sub. Also my amp had 2 30amp fuses on it one for each channel but I ran everything out of one channel.
Aug 02, 2016 | Lanzar Car Audio & Video
How to put geometric sequence in this calculator?
Are you trying to find a particular term in the geometric sequence?
For example, in the geometric sequence 2,4,8,16 to find the 15th term we would use the formula a sub n = a sub 1 x r ^(n-1), where a sub n is the nth term of the geometric sequence
a sub 1 is the 1st term of the geometric sequence
r is common ratio between successive terms
n is the term you are looking for
In our example, a sub 1 is 2, r is 2 and n is 15.
a sub 15 = 2x 2(15-1)
a sub 15 = 2 ^ 15
a sub 15 = 32,768
On your calculator, you use the key to the right of x^2 to do x to the nth power.
Good luck.
Paul
Geometric Sequences and Series
casio fx 300es manual Google Search
Jan 12, 2016 | Casio fx-300ES Calculator
Missing adapter or plug in connection to 15 balance mointor model 2015
The Balance CM2015 monitor uses a VGA connector,
http://www.ebay.com/ctg/Balance-CM2015-15-LCD-Monitor-Black-/52125929
(The above is for reference only. Not advertising)
A VGA connector is also referred to as a 15-pin D-Sub connector,
http://en.wikipedia.org/wiki/VGA_connector
This is information on a DVI cable, and DVI connector,
http://en.wikipedia.org/wiki/Digital_Visual_Interface
If this is the monitor cable you have, you need this type of adapter,
http://www.directron.com/dviadapter.html
Now LOOK closely.
This adapter has male pins that stick out, and go into a female VGA connector on the monitor. The DVI side of this adapter has socket holes, for a male DVI cable.
IF, your monitor has a male VGA connector on it, and the DVI cable you have has socket holes, you need this adapter,
http://www.directron.com/dvitovga.html
If your monitor cable is not a DVI cable, post back with the style it is.
If nothing else post how many pins are in the connector on the cable, and how they are arranged.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 27, 2012 | Computers & Internet
My shaving head came apart and I can not re assemble it, kindly give me instructions
Wife cleaned bathroom shelf dropping the Arcitec. One of 3 heads was not aligned properly, when I tried to re-seat it, this head came apart. To put it back together takes some finesse and patience. Take a coil of stamps, or some other small opening to rest the outer plastic shell head, then insert the metal screen which has notches (2 small, 1 large) and fit it in the plastic shell head. Next put the metal blade assembly on the screen. Next align this on the metal (thin) pivot. When the outer plastic head, and the metal pivot are aligned (small peg holes), you can place the thin inner plastic piece on and gently press your sub assembly and the backing plastic together, It will snap together and hold. Don't FORCE it, the holes must be aligned on the outer plastic, the metal pivot frame, with blades resting on the screen. It does snap together. Work with fairly bright light to see what you are doing. If this fails, invest in a new head assembly for about 15% of the cost of the whole razor.
Jun 10, 2011 | Norelco Arcitec Electric Shaver -...
2 15" and a 10" sub
10" subs need 1 cubic feet. 15" subs need 2.5 cubic feet. install them on its own volume of the box...
Jul 17, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
Transformer fried need to know where can i purchase another one
I looked up velodyne acoustics inc, on line. found the info to contact velodyne direct. they were very helpful, and set me up with what i needed to fix my sub.
Apr 12, 2009 | Velodyne CHT-15 Subwoofer
Box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Feb 14, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
Th-m505 jvc help with no sound
Well i had exactly the same problem, my sub turned off right away when i turned the whole thing on. Well i opened the subwoofer and was trying to find out something unusual, i took out, i believe, internal amp, well, whatever that thing is, under the lid. Which one is screwed with 6 copper screws, so you unscrew those screws, lift that lid and that whole board comes out. On that board i find something like burn around one of the parts.
http://www.flickr.com/photos/28004328@N04/3333561417/in/photostream/
you can see it in the pick, the part q2902, then i contacted JVC. At the beginning they said i need to take the whole thing to service center and so on. But later i made them to tell me what kind of part that is, so here :http://www.jvcservice.com/store/ProductDetail.asp?Part=KTC3199/GL/-T
bought soldering gun in home depot for $15, returned after i was done. And that is it, just have to replace it, but total cost only $12 ($5 part +$7 shipping)
Jan 26, 2009 | JVC TH-M505 System
Knocking noise with my kicker compvr 15"
comp VR 15s are rated @ 500W RMS 1000Peak.
The lanzar vibe amplifier is 2 x 600W RMS at 4 OHMS 2 x 1200W MAX at 4 OHMS 1 x 2400W MAX at 4 OHMS Bridged 2 x 1000W at 2 OHMS RMS.
Your subs are single 4 ohm subs.
If your subs are wired stereo, they both are seeing 600W. (more than the rated RMS)
Chances are, you have them wired parallel to a 2 ohm mono load - of which that amplifier is not rated. In theory, it will produce about 2000W @ 2 ohm mono for a short period of time.
Your amplifier is too powerful for your subs. Turn down the gain setting to 3/4 or purchase better subs. Also be sur the subs are inthe proper enclosure. It sounds as if they are excurting past their linear x-max and colliding with the rear bump plate. This will cause damage down the road if left as is.
Nov 26, 2008 | Kicker CompVR 05CVR84 Car Subwoofer
I plugged int he rca's but he the lowest sounding bass possibe
kicker subs arnt ment to hit the lowest bass, unless you go spend a **** load of money, im talking 3000 wat amp, ant some 15' or bigger subs. the most commen kickers are 12' subs, so im asuming you have 12' subs, if not, this (said lightly) should work. try turning the bass boost screw on the amp to the middle of its turning range. this will offer the greatest balance between high and low bass. if you want more low bass, turn it past half. if you want more high bass, turn it down. i have mine set to mid range, but i also recently purchased 2 18' kickers. with every new set of subs, you should spend at least 15 min tuning the amp to get the best performance. every sub is different. hope this helps, good luck.
Jun 27, 2008 | Kicker KX800.2 Car Audio Amplifier
Soundstream SPL 15 Car Subwoofer Logo
67 people viewed this question
Top Soundstream Car Audio & Video Experts
Matthew Spark
Matthew Spark
Electro Med Services...
Are you a Soundstream Car Audio and Video Expert? Answer questions, earn points and help others
