Question about GE 24 in. GSD5500G - Multiple Color Built-in Dishwasher
Hello: I have a ge gsd5500 dishwasher. I want to remove the pump connect which is leaking. Key 455 This connects the pump to the main tub in the middle. How do you remove it? Thanks
Remove dishwasher from under the cabinet. Turn dishwasher on it's side. Loosen the clamp holding the motor/pump from the pump connect. Loosen the clamp holding the motor to the sump. Carefully remove the motor from the sump and pump connect. Turn the rubber connect counterclockwise several turns till it is disconnected from the bottom of the tub. Mine had a small crack right along the top. You needed to bend the connect to see it.
Posted on May 13, 2009
My GE triton dishwasher has water standing in the
The GE GSD5500 has a check valve in the rear of the unit under the FILTER FRAME that screws in. GE part WD24X10018.
The white rubber stopper wears out and lets water return to the tub!
Remove filter frame (4 screws) and unscrew the check valve to replace. Try appliancepartspros.com for part # AP2617344.
Nov 30, 2009 | GE Dishwashers
I have water leaking under my dishwasher (probably right in the middle). I put a paper plate underneath to catch the water during the cycle. There seems to be some "soap scum" on the bottom where it is...
Hello there
Here is several ideas that will help you
also (fyi) type in search engine how things work and once it opens just enter dishwasher and it will bring you to the dishwasher section ok?
here it is
Dishwasher is leaking water
  • Inspect the seals for the main tub, float, heating element and blower diffuser
  • Check for overfilling
  • Inspect the water and drain hoses
  • Inspect the door gaskets
  • Check the water inlet valve
  • Check the pump
Water or soap leaks around the door
  • Make certain that your detergent is intended for dishwashers. Do not use liquid dish soap.
  • Inspect the door seal gasket
  • Check the door latch
  • Inspect the door hinges
  • Inspect the spray arms for damage
Water drains through the air gap into the sink
Sep 16, 2009 | GE Nautilus 24" Built-in Dishwasher
My clients unit is leaking substaintial water in
Check the drainage hose to see if its connected properly. it is located under the unit. it may be loose or, not connected correctly. if the drainage hose is connected properly, this will be a faulty water valve. replace if found to be faulty.
Jun 16, 2009 | Dishwashers
My GE Profile dishwasher is leaking under the tub. Its not a small leak, the water comes out as soon as it starts to fill. What may be the problem?
You have one of two problems here. First of all remove the lower front panel on the dishwasher and get down there with a flash light and check it all over. The water leak is either where the water line is connected to the machine, or around the motor/pump seal. Close the door and turn on the machine. Now you will see exactly where the leak is. IF if is the motor/pump seal you may want to call a technician. If it is where the hot water feeds the dishwasher you may be able to tighten up the connection.
Apr 20, 2009 | Dishwashers
We have a GE Dishwasher Model # GSD 2000 Z02AD - water leaks
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Jan 06, 2009 | GE 24 in. GSD2230Z Built-in Dishwasher
Dishwasher leaks when jet dry rinse is added everytime.
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
1. Lower rack
2. Spray arm
Door gasket or seal
Water-inlet valve
Hoses
Nov 27, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
Leak from a black module, where an arm connects
if your dishwasher leaks check out this: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Oct 11, 2008 | GE Nautilus 24" Built-in Dishwasher
Ge nautilus leak left side
If your dishwasher leaks, check these: Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
  • Lower rack
  • Spray arm
  • Spray arm support
Oct 05, 2008 | GE Nautilus 24" Built-in Dishwasher
Leaking from rear in cabinet
  • Lower rack
  • Spray arm
  • Spray arm support
Sep 30, 2008 | GE Nautilus 24" Built-in Dishwasher
Leaking water
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Jun 30, 2008 | GE GSD1180X Dishwasher
GE 24 in. GSD5500G - Multiple Color Built-in Dishwasher Logo
150 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
