Question about Sonic Sultan Healthcare Ultrasonic Unit Pro-sonic 300 W/timer Ea - Model 0061028f
Does not power up lose wire fuse blowed
I need to find the wireing dyegarm for the wires thank you sultan pro sonic 600
    Scholar:
  • 192 Answers
The website is offering it.... I just checked and it is free..
Posted on Sep 06, 2010
Honda Hornet keep blowing dash fuses
Check for a short in the wiring. Sounds like after bumping along on a ride an exposed wire grounds and blows the fuses.
Apr 13, 2015 | 2001 Honda CB 600 Hornet S
Kitchenaid Dishwasher thermal fuse keeps blowing
if your fuse is blowing often i would suggest you to move your washer to a different place and try a different plug point.
there may be some fault with your power.
try to sort it out step by step.
thank you
Sep 17, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
1997 Harley Ultra Classic 30 amp main breaker pops while riding. Also blows 10 radio power fuse
Hi Anonymous, you have a hard/dead short that should be easy to find generally they are the easiest. Time to get out your test light and start tracking the wire from the power side of the switch, circuit breaker or the blown fuse receiver, when the test light quits lighting you are very close to your short. For a free wiring diagram please visit the website below and good luck.
Harley Davidson Wiring Diagrams and Schematics
Jul 19, 2012 | Harley Davidson FLHTCUI Electra Glide...
2006 Suzuki GSX-R 600 wiring diagram
Hi, Anonymous before diagnosing your blown fuse issue, check the bottom of your seat, if it's metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) You are going to need a wiring diagram from your service manual, a test light, an ohmmeter and plenty of extra fuses.
If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
If you driving down the road for 30 minutes or 15 miles and blow a fuse you have soft/flying short and may take some time and patience to find.
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with an ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2006 Suzuki GSX 600 wiring diagram Google Search
Suzuki Motorcycle Wiring Diagrams
Suzuki GSX R600 Manual
OEM parts for Suzuki
Suzuki GSX R600 2003 Owner Manual
Sep 22, 2017 | 2006 Suzuki GSX-R 600
Fuse blows when I turn on the right turn signal.
whichi fuse? only when right turn signal. not left. ?
Aug 27, 2011 | Honda VT 1100 C Shadow Motorcycles
Amp keeps blowing the fuses
Serious short circuit on your output transistors, need replacing.
Sep 28, 2009 | JVC KSAX4504 MOSFET 600-Watt Amplifiers...
Gsxr 600 1999 keeps blowing main fuses.
My guess is the wiring around the headstock pivot are shorted out, and you will need to need to do a check with a meter. This manual should explain clearer....
http://www.carlsalter.com/download.asp?fileid=083117122117107105095071083088045082054048048095039057055045048048095083101114118105099101095077097110117097108046112100102
Rate me if I helped
Thanks.
May 21, 2009 | 1999 Suzuki GSX-R 600
The headlight flashes and the turn signal goes out i wired the negative and earth together.If i wire the earth and positive,all works fine until I turn off the signal and the fuse blows
Hi and welcome to FixYa,
It would seem that some wires have crossed. You can verify connection by following the wiring diagram.
Good luck and thank you for using Fixya.
May 09, 2009 | 1999 Honda CBR 600 F(4)X
Kawasai z750, keeps blowing main fuse
To my knowledge, there are no onboard electrical/electronic components capable of shorting and blowing the fuse with out blowing any of the secondary fuse. The main fuse could possibly blow due to a short in the wiring or an exposed/frayed wire touching the body. The three most likely areas would be:
  • wire harness leading to the regulator;
  • wire harness leading to the fusebox; and/or
  • wire harness leading to the ignition switch.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 19, 2008 | 2005 kawasaki EL 125 Eliminator
Sonic Sultan Healthcare Ultrasonic Unit Pro-sonic 300 W/timer Ea - Model 0061028f Logo
119 people viewed this question
Top Sonic Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Sonic Hardware and Accessory Expert? Answer questions, earn points and help others
