Hitachi projection tv c43-fd5000 standby light no screen no sound
Str f 6656 faulty l have change but still no screen and no sound.there are 4 green led light which are blinking
thank you for your help.
tlm931
  • 273 Answers
SOURCE: TV PIcture and Sound Shut Down
it would appear its shutting down in a protect mode
its possible its a convergence circuit problem or something on the deflection bd
but it most likley will require some assistance from a tech that is used to working on this type of set
if you noticed when it does come on that the colors are all off line then suspect convergence circuit trouble the the green leds tell you what source is still alive there is a chart in the cabinet that will correspond with each source voltage that can lead you to tracking it down if you know what to look for and have the tools to do so
Posted on Jan 21, 2009
  • 239 Answers
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
Posted on Mar 04, 2009
rustym62
  • 201 Answers
SOURCE: I have a similar problem with the Sony 60
I believe 4 blinks is fan error. You can take back off and watch fans in particular the fan for the lamp (this one goes out the most) The TV has a sensor so it knows if the fan turns.You can take a pencil and use it to spin fan sometimes that will jump start it (not a permanent fix just a test). You can try cleaning dust off fan and replugging the connector on the wires coming from fan.Might fix it if not fan will need replacement.
Posted on Apr 28, 2009
Angel Petter
  • 114 Answers
SOURCE: replacing lamp
try this to see if it works!
If you replace the DLP lamp out of your Zenith or LG, you will need to reset the
counter…Otherwise you may get an annoying reminder every few days if you’re
surpassed the predetermined hour mark.
Ensure the TV is powered on.
Press and hold the MENU button on the TV
Press and hold the MENU button on your REMOTE
(hold both these until the service menu pops up 5-10 secs max.)
Let go of the REMOTE button first, then release the button on the TV
Press and hold the ENTER (or OK) button on the TV
Press and hold the MUTE button on the REMOTE
(hold both until the LAMP LIFE HOURS appears on the screen)
We suggest writing your lamp hours on a peice of masking tape and taping it to the back the TV for future reference
To reset the lamp counter, press SELECT (or the button in the middle of the direction arrove buttons). Hit SELECT a second time to confirm clearing the lamp counter
For certain models, you might have to tweak these steps slightly… offer your inputs!
Posted on Mar 24, 2010
tvtek
  • 1284 Answers
SOURCE: I have a Sony 50"
A four flash error sometimes means one of the fans is bad or clogged so much it won't rotate. You probably will have to remove the back and visually see if the fans that are visible are rotating. There is also the main lamp fan that is located in the housing to the left as you take the back off. This fan is not easy to get to at all as it requires a bit of a tear down to get to.
Posted on Sep 16, 2010
My tv has no picture
Maybe the projecter needs replaced.
Jul 13, 2012 | Hitachi Televison & Video
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
My C43-F500 bought in 2002 has now started to show red, blue, greenish ghosting on objects / people within about 2 inches of the left edge of the screen. What is wrong? how much does it cost to repair? Am...
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2010 | Hitachi C43-F500 43" Rear Projection...
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
42 inch hitachi plasma
the more the tv remains on the picture gets out of focus mainly in the midle of screen. Sure sounds like tv needs some light engine repair or replacement.
Aug 11, 2009 | Hitachi 60V500 60" Rear Projection...
I have problem on my hitachi prjection television
My father in law had a similar problem it was the bulb to the projector caused the colors to seperate out... like $1500 to replace so he upgraded to a new TV
Nov 29, 2008 | Hitachi C43-F500 43" Rear Projection...
Hitachi, Projection Color TV,C43-F550,C43-F550p,C50-F550p
what do you mean when you say resistors look like they were dry??
did you try fixing the wires? i would do that first and see if anything else is bad.
Jan 07, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
Electro Med Services...
