Question about HP Photosmart C5180 All-In-One InkJet Printer
My photosmart c5180 gives me the error code 0xc19a0021 and says ink system has failed. if i unplug it and restart it it will print for a few minutes until the error comes up again
  • 413 Answers
The kind of error you are getting is due to fault in the ink and print section so you can clean the print head with soft tissue and install the cartridge properly and check the vent of it and now reset the printer by turning on and disconnecting by pressing power button for 20 seconds
and hopefully everything will work out it the problem persists then you might have to replace the print head
Thanks And Regards
Posted on May 12, 2009
  • shankar anand jha
    shankar anand jha May 12, 2009
    sometimes it is due to tampered cartridge so check the cartridge carefully and no leaks are there
How do i fix ink system has failed error code on my hp photosmart c5180 printer?
try master rest for hp C 5180
Master Reset:
Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. . This sorted it.
Jul 26, 2014 | HP Photosmart C5180 All-In-One InkJet...
I have a HP C5180, receiving error message 0xc18a0206 Ink System Has Failed. I have replaced all cartridges, unplugged power supply and USB cable for reset and am still receiving error message. Help! ...
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Mar 09, 2011 | HP Photosmart C5180 All-In-One InkJet...
Ink system has failed. Unable to print. Refer to printer documentation Error: 0xc18a0201
I have a HP photosmart C5180 all in one. It has an error message that says....Ink system failed unable to print refer to printer documentation error OXCa0501. By chance would you know what to do to fix it? Thanks
May 25, 2010 | HP Photosmart C5180 All-In-One InkJet...
Ink system failed
Jan 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
All i did was change black ink. hp photosmart C5180 it says error 0xc18a026 error INK SYSTEM HAS FAILED UNABLE TO PRINT. REFER TO PRINTER DOCUMENTATION ERROR 0xc18a026 PLEASE HELP!!
disconnect from power (unplug) and let sit for 1/2 hour. Then give it a shot.
Also, you might want to make sure that you've got that new cartridge set in there correctly.
Nov 07, 2009 | Refrigerators
Oxc18a0201 ink system failure. Apparently failed due to using non HP ink. HP recomends buying a refurbished replacement. The printer is HP photosmart C5180
1.-press key * # 2.-enter code 123 and select a Hardware faliure status 3.- Press clear OK and finish cancel for end restart print
May 23, 2009 | HP Photosmart C5180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Wait two minutes.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
I have a Ink System Failure.
Wait two minutes.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
3,114 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
