Question about Panasonic NV-GS230 Mini DV Digital Camcorder
Ho much capacity memory card SD for NV-GS230 - Panasonic NV-GS230 Mini DV Digital Camcorder
  • 4 Answers
2g sd card is the max
Posted on May 12, 2009
What is the maximum size sd card (Gigabites)?
speed class choices.
about compatibility with host devices before choosing your card, it is important that you understand how to use your memory card to it greatest ability. sdxc memory cards and devices (digital cameras, video cameras, laptops, etc.) are now available. learn how to use your new sdxc memory card to optimize its performance.
confirm compatibility before inserting your sdxc memory card, confirm the device is compatible with the sdxc standard by locating an sdxc logo on the device or referring to the device's user manual or manufacturer information.
understanding backwards compatibility
  • sdxc memory cards must only be used with sdxc devices.
  • sdxc devices can use sd memory cards, sdhc memory cards and sdxc memory cards.
  • sdhc memory cards can be used with sdhc devices and sdxc devices.
  • sdhc devices can use both sd memory cards and sdhc memory cards.
  • sd devices can only use sd memory cards.
http://www.tomshardware.com/charts/memory-cards,39.html
the link above has several chart on sd cards.
Jan 20, 2015 | Cameras
Why card error when i put in the card
What type and size memory card? The NV-GS70 works with SD cards, 2GB and smaller. It will not work with higher-capacity SDHC cards.
Jul 16, 2014 | Panasonic NV-GS70 Mini DV Digital...
Have a 4Gb memory card but when I put it in SD slot to take pictures, it always indicates CARD ERROR even whe the card is unlocked.
From what I see of the specifications for the NV-GS25, it uses SD cards. Your 4GB card is actually an SDHC card, which is electronically incompatible and will not work in devices not designed for SDHC cards. You need to use SD cards, 2GB and smaller.
Dec 15, 2012 | Panasonic NV-GS25 Mini DV Digital...
When I use different SD cards it says Card Error or Incorrect Operation? Tried to format or delet the files of the card but couldn't. It's a cam recorder nv-gs50
Check with the instruction manual for the camcorder which type and capacity SD cards it will "support" and use only the specified cards. The camera will reject any card with a greater Gb capacity than it's system can support.
The more recent your camera the greater card memory capacity will be supported.
Sep 20, 2011 | Panasonic NV-GS50 Mini DV Digital...
Please can you tell me if an SD card called SD Ultra 11 66X 2GB will be read by a standard SD card reader
Yes, i t should be unless it is a SDHC Card which it should not be as SDHC cards have minimum 4 GB capacity. For more info:
The older SD (secure digital) cards had a maximum capacity of 2GB. The SDHC (secure digital high capacity) cards can go to 32GB. Devices that support SDHC will say so in their specs and they will also read older SD card. Older devices that use SD cards will NOT use SDHC.
"SDHC (Secure Digital High-Capacity) cards are flash memory cards with a minimum capacity of 4GB (gigabytes). SDHC cards provide removable memory for compatible digital devices including cameras, camcorders, PDAs, MP3 players and more.
Dec 14, 2009 | Audio Players & Recorders
My new computer has windows 7, i cant find any program who will work with my panasonic nv-gs230.
try using windows XP mode to run an older program (you can download windows xp mode from microsoft.com)
Nov 28, 2009 | Panasonic NV-GS230 Mini DV Digital...
How can i change my panasonic nv-gs230 mini dv
Best
1. Copy the video to your computer with WinDV. No "capturing" involved. The video resolution and PAL/NTSC format will be the same as the source.
2. Then convert to whatever format you like.
You could also use something that copy and converts the video directly from the DV, like convert to dvd with Ulead DVD Workshop.
DV is a fixed standard and comes in 50Hz and 60Hz versions.
50Hz ("PAL" 625/50) 720x576, 25fps interlace (aka 576i)
4:2:0 components, 25Mb/s Video Rate
LPCM audio 2ch 16bit 48KHz or 4ch 12bit 32kHz
60Hz ("NTSC" 525/60) 720x480, 29.97fps interlace (aka 480i)
4:1:1 components, 25Mb/s Video Rate
Meaning, You cannot change the camera. It is either a pal camera or a ntsc camera. Othewise you will have to by a firmware update from the manufacture's website.
Oct 14, 2009 | Panasonic NV-GS230 Mini DV Digital...
Need Driver for Panasonic nv-gs230 Camcorder Software to download
You should be able to just plug a USB into the camera connect it to your computer.
The camcorder should come up as an drive in "MY computer"
Try renaming any video that are named *.moi to *.mpg
if they wont play.
Hope this helps.
Sketchlab.com
Mugshot Collection
May 15, 2009 | Panasonic NV-GS230 Mini DV Digital...
USER MANUAL
just go for google...
you can find english manual & drivers @ panasonic australia
http://panasonic.com.au/products/details.cfm?objectID=3696
scroll the page down to the end,
there you go
Sep 27, 2007 | Panasonic NV-GS230 Mini DV Digital...
Panasonic NV-GS230 Mini DV Digital Camcorder Logo
140 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
