Question about Canon PIXMA MP600 all-In-One InkJet Printer
Error 5100 The carriage is stuck on the right side. I can not free it by tugging on it. Is there a way to remove the plastic top so I can access the carriage to free it? Thank you very much
  • 1 more comment
  • x3putts Oct 14, 2007
    I was able to resolve this issue.  If anyone has this problem, you can see a lever next on the left of a carriage.  By playing with this lever, I was able to free the carriage and resolve the real problem, the print head was not in the proper place.
  • Anonymous Nov 09, 2007
    simply turn the printer off..then turn it on and it should reset
  • loijovi Feb 23, 2008
    canon PIXMa
Check nothing has fallen in near where the inks go back and forth...
Posted on Dec 16, 2007
    Genius:
  • 1,601 Answers
When i try to print it says error 5100 and will not print
Error Code 5100
It can have a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. The purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 10, 2011 | Canon PIXMA iP1800 Printer
What is error message 5100 for this printer?
Code 5100 refers to a carriage that is not freely moving from side to side. Look to the far left and right for anything that would impede the carriage path.
Also, it is possible that the clear plastic encoder strip just behind the carriage path has become smudged with (most often) grease. You can clean the strip with a cotton swab dibbed in alcohol.
I hope this helps!
Mar 27, 2010 | Canon Pixma MP450 All-In-One InkJet...
I have an error 5100 on my Canon mx320 printer what do i do?
5100 says the carriage is not moving freely from side to side, or there is grease on the clear plastic encoder strip behind the carriage. You can clean the grease with a Q-tip and alcohol, but also look inside on the far right and left sides for anything like paper scraps that can stop the carriage.
Feb 25, 2010 | Office Equipment & Supplies
Cannon pixma mp510 ~ error code 5100 help
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 19, 2009 | Canon PIXMA MP510 All-In-One InkJet...
What dose error 5100 mean?
This is a carriage error.Make sure there is no paper inside the machine and that the cartridges are inserted correctly.Make sure the tape is completely removed and there is nothing blocking the carriage.If none of that works the carriage assembly needs to be replaced.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 03, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper jam when paper cross-loaded, removed paper. Now error code 5100
Hi
Thanks for using FixYa. The error 5100 means it is a Carriage Position Error. The plastic strip that runs the carriage might get some particles of paper or rust and required to be cleaned with some alcohol and swab. If still the problem persists, then it may be due to some obstruction in the print path or gears or some ink on the clear plastic encoder strip. Lubricate the sliders with some white grease, including the purge cap, which is the white sliding mechanism that the print head parks on when it's not in use. Please make sure that it is not split on the small wipers or the black caps. The mechanism can now slide more freely. To access the purge mechanism you need to remove the right panel off of the printer. There are two screws on the behind of the printer and two in front for each side panel. You can locate the front screws behind the grey front panel of the printer. Now open the top cover to see the clips which hold the front cover on.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 29, 2009 | Canon Pixma iP6600D InkJet Photo Printer
I get an error message 5100. What do I do to fix
Hi
Thanks
Rylee
Sep 04, 2009 | Canon Pixma MP450 All-In-One InkJet...
Erroe code 5100 pixma ip1800
5100 means either the carriage can't move properly from right to left, or the encoder strip behind the carriage assembly has grease or ink on it and needs to be wiped with a Q-tip. Sometimes the cleaning assembly on the right gets stuck in the up position and stops the carriage.
Jul 02, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Error 5100
Please remember to rate other users who assist you for free :)
Service error 5100 is a carriage home position error.
Turn off and unplug the printer from the power supply.
Remove any paper.
Buy a can of compressed air from an electronics shop or computer store. Use the compressed air (Not a vacuum!!!) to blast out any dust bunnies, paper particles and debris. (Don't do this with the cartridges removed as you're likely to fill the printhead with air!!)
Use isopropyl alcohol and a cotton swab (Qtip) to clean the plastic strip that runs the length of the guide rail (the metal rail that the cartridge carriage moves along), it may be contaminated with ink and debris.
Remove and reinsert the ink cartridges inside the cartridge carriage to ensure that they're connecting properly.
With the power off, carefully slide the print head (carriage) to the center of the guide rail. You should not have to force it! (There will be some light resistance but it should move quite easily by gently pushing on it with your finger.)
Close all the access doors, plug it back in, connect your USB cable and turn on the power.
As it runs through the initialization, the printer should sense that the carriage is out of position and automatically move it back to where it should be.
Good Luck.
Sep 25, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Error 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Oct 03, 2006 | Lexmark X4270 All-In-One InkJet Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
106 people viewed this question
old marine
old marine
