Question about Briggs Garden
Engine on chpper/shredder by Gen. Power equip.Co won't start.
At beginning the engine ran some seconds, then stopped & would not start. At that point the spark plug was wet with gas & dirty. So I supposed it out of gas & got some. Now it has gas. I cleaned spark plug. 5 o 6 tries with choke on full, & throttle ditto brought no combustion. Examining the spark plug, I found it not wet with gas. What should I do next. I have no manual..
  • cpst202 May 12, 2009
    I get a thin spark when the plug is exposed & lying on the engine top. How fat should a spark be, & what gap is usual? Can gas vapor is the cylinder kill a weak spark?
    Can the magneto be helped by disassembly & cleaning?
    How many times should try starting & get a flooded engine? I'm wondering if the gas line is plugged.
    Top Expert:
  • Briggs Master
  • 75,822 Answers
U will need to see if it has spark to the plug, i suspect it u will find it doesn't, if this is the case u will need to check the magneto and the connection to it.
Posted on May 12, 2009
  • yadayada
    yadayada May 12, 2009
    sounds like u have a very weak spark, the pressure in the cylinder will kill the spark, the higher the cylinder pressure the harder it is for the spark to jump the plug gap, u may have a defective Magneto, if u have points check them and see if they are pitted or burned..
Engine turns over, car won't start
Engine Cranks But Wont Start - Professional Mechanics ...
www.2carpros.com/articles/car-cranks-but-wont-startJul 15, 2015 - Step 1 - A fuel pump operation failure will cause the engine to not startdue to ... The power distribution center of a vehicle houses fuses which .... Works atCVS ... I have a 1991 ford f150 the motor turn over fine but it won't start.
Car won't start - check VSC light - Club Lexus Forums
www.clublexus.com/.../is.../519132-car-won-t-start-check-vsc-light.html
Aug 13, 2010 - Car won't start - check VSC light IS - 2nd Gen (2006-2013) ... Carmakes an exaggerated version of the engine startup noise. Hard to describe the noise, but the one that sounds like .... It stopped accelerating, the VSC check & check enginelights came on. I immediately pulled over. Waited a few minutes.
Nov 22, 2015 | Cars & Trucks
Why won't it start?
as with any gasoline engine, you need, fuel, spark & air, take a moment to follow the progression of each of them, you will figure it out: example, test your ignition switch, clean, new fuel, getting spark to the plug? do you have a fuel stop solenoid attached to the carburetor?
Sep 11, 2015 | Lincoln Electric Welding Tools
Shredder Green light won't come on and won't shredd. won't go in reverse either.
I had the same problem with the same shredder. The unit uses mains voltage which is rectified to DC and eventually feeds two 12V zener diodes wired in series for a 24Vdc supply. These are 1N4742A (Radio Shack 276-0563), 1W parts. They overheat and will short, which you can verify with a VOM. I reassembled the unit, but recall they are away from the relays at the tail end of the large white colored power resistors, side by side in the same direction. I think Z1 and Z5. After replacing these parts, green LED and reverse, etc. will work.
Apr 14, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
MANTIS TILLER WITH HONDA GX25 ENGINE STARTS FINE BUT WHEN GIVEN THROTTLE DIES OUT. ALSO A LITTLE WHILE BACK OIL WAS COMING OUT OF CARB BUT THIS HAS NOW STOPPED. THIS IS A 4 STROKE ENGINE WITH APPROX 4...
I also have Mantis tiller for 2 years. From the very beginning I had a problems. I was referred by Mantis to the repair store and was charged $90.00 for oil drainage. The second time I was waiting for handle replacement for ~ 1 month. This tiller can't handle even little jobs and the warranty doesn't worth a dime. Maybe I will be more successful using it in my living room . I have an equipment with Briggs and Stratton engines and I never had a problem.
To me Mantis mean big advertisement and waste of money.
Feb 20, 2011 | Honda Hmantis Mantis Garden Tiller with...
I PICK UP A 3250 TROY-BILT GEN AND RAN IT 1 FULL TANK OF GAS OK. THAN WE GOT A SECOND STORM FILLED TANK AGAIN LET RUN FOR ABOUT 6 HOURS AND IT STOPRD. WHAN I THAUT IT RAN OUT OF GAS I REFILLED AND TRYED TO...
pull plug and try to pull start if moves than it was vapor locked clean plug and try to start if no movement with plug out than internal engine or pull cord jammed
Mar 03, 2010 | Troy-Bilt® Briggs and Stratton Chipper
Kohler confidant 4 generator will not run.
i got the same gen and with the same problem
mike
Sep 24, 2009 | Kohler Electrical Supplies
Blades rotate twice but stop-motor continues to run, both forward & reverse mode its the same. Have tried to oil, unblock, run forward & back but to no avail. Can anyone help
Is the motor just humming after the 2 rotations? If you are over oiling the unit, tha shreds will soak up the oil and start sticking to the blades and begin growing a paper tumot in side the cutter shroud, whish in turn will start to slow down and jam the cutter asm and motor. Best to take apart and thoroughly clean.
Jun 01, 2009 | Office Equipment & Supplies
Garden Logo
118 people viewed this question
Top Briggs Garden Experts
Mike
Matt Olenzek
Matt Olenzek
Are you a Briggs Garden Expert? Answer questions, earn points and help others
