Question about Canon imageRUNNER 400S Copier
Canon Error Message
The message is E805 and says turn main switch off and back on.  When I turn it off the same message displays.  Does anyone know how to correct the error?
  • 2 more comments
  • Anonymous Nov 14, 2007
    E001 code is occured in IR400
  • Anonymous Oct 05, 2008
    same problem
  • Anonymous Mar 20, 2014
    when the unit is turned on the main menu is displayed then error message pops up saying to turn unit of and back on. when the unit is turned back on the same thing takes place
    whenever the unit is turned on the main menu pops up then the error message appears
  • Canon Expert
  • 270 Answers
An E805 code has to do with the failure of one of the many fans within the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
Posted on Nov 13, 2007
  • 69 Answers
Hi i m jules_09,turn the unit on and off then count 5 seconds,then reset the error in the program
Posted on Oct 15, 2007
Ir 2020 e805
E805- Fan Failure- open rear cover find PSU and check for rotation of cooling fan at power up ( spins as soon as display lights up)
If it isnt spinning - replace with correct part from Canon, the circuit is expecting a feed back specific value which will only be seen with the correct fan.
Jan 16, 2014 | Office Equipment & Supplies
Canon ImageRunner 330s Error E805, Can't Enter Service Mode
FM1 Heat discharge fan Cools fixing unit.E805 0000 Fan failure
only one in this copier>
The fan is faulty. -
Check the fan connector.
- Replace the fan.
- Replace the DC controller PCB.
Switching between full-speed rotation and half-speed rotation is controlled as described below.
1) Full-speed control
When the CPU on the DC controller outputs a fan full speed signal (FAN_FULL), the fan drive voltage switching circuit supplies a +24 V fan drive voltage to turn
the heat exhaust fan at the full speed.
2) Half-speed control
When the CPU on the engine controller outputs a fan half speed signal (FAN_HALF), the fan drive voltage switching circuit supplies a +16 V fan drive voltage to
turn the heat exhaust fan at the half speed.
E805-0000 (Main body fan error)
When the cooling fan of the main body starts, the fan lock detection signal (FAN_LOCK) has been held at the "H" level for longer than the prescribed time.
also check your low-voltage power supply
Apr 22, 2012 | Office Equipment & Supplies
Canon ir 3100 cn E805 003
E805 fan error
Description
With the ITB fan in operation, the machine does not detect a lock state for 5 sec continuously.
Remedy
Turn off the main power, and check the DC controller PCB; then, turn the power back on.
Remarks
Disconnected fan connector; absence of lock signal because of fault in fan.
Nov 09, 2010 | Canon Office Equipment & Supplies
My canon copier IR2016 has functional error E805
there could be a problem with the main fan and or the dc controller could be bad.
May 19, 2010 | Canon imageRUNNER 2000 Copier
System Error E805 in Canon iR2018
E805 is Fan failure
The fan is faulty. - Check the fan connector.
- Replace the fan.
Jan 08, 2010 | Office Equipment & Supplies
E000732-0001 Error Message
E732 Error code details
  Main cause
 The cable connector has poor connection. The reader controller PCB is faulty.
Condition
 0001 The main controller PCB detects a fault in the communication between the reader controller PCB and the main controller PCB. Connectors
1) Connect the cable [1] for the environment heater.
ir7200-f04-309-01_e.png 2) As needed, connect the reader unit anticondensation heater cable [1].
ir7200-f04-309-02_e.png PLS RATE ME!!!!!!!THANKS MATE.
Sep 23, 2009 | Canon imageRUNNER 8500 Copier
I have a Canon laser class 700 and it has a E805 error message. Can anyone help me?
E805 error code refers to a fan failure. Either the fan is locked up or unplugged.
Sep 02, 2009 | Canon Office Equipment & Supplies
My imagerunner 1023iF is displaying error message E805
Check if the exhaust fan near the fixing unit is working,this error indicate problem on exhaust fan,could be stuck up or dirty
Jul 01, 2009 | Canon imageRUNNER 1023iF Black and White...
This is called low temperature check environment around copier or replace fuse in DC Controller
Nov 23, 2008 | Canon imageRUNNER 400S Copier
this is due to an open circuit or fuse on your dc controler board
Canon imageRUNNER 400S Copier Logo
569 people viewed this question
old marine
old marine
