Question about Fellowes Powershred 420-2HS High Security Confetti Cut Paper Shredder
The paper will not go through my shredder
My shredder works, moves the cutters, but they do not cut the paper, and the paper does not go through the machine either.
  • 328 Answers
Can you actually see the cutter blades rotating? I have seen gears broken and you can hear the motor running but no blade movement. Remove the screws lift the top off carefully because their is a short ribbon cable connected to the main board and can easily be damaged. Of course unplug from power outlet first.
Gears and motor can be puurchased.
Posted on May 15, 2009
How can I dis-assemble the cutting area to un-jam this shredder?
unless you are mechanically minded then forget it
run it backwards to start with to remove any paper that will move.
the jammed paper can be pulled out
the control is a small lever between the two centre cutters and any small bit of paper will hold this in the off position or on position
Jul 23, 2015 | Royal HG140MX Shredder
1600mx wont run in forward over load light comes on
Most common reason is that there is paper would around the cutters, imposing an additional load on the machine. You will need to access the cutter assembly (disconnect all power) and manually remove all of the paper that has impinged between the cutters.
If you have run any labels or paper with gummed strips through the cutters, you may wish to consider throwing this one away and buying new. (In all fairness, it "can" be cleaned, but it is going to be a real dickens of a job to do).
If you decide to keep your shredder and clean the cutter assembly, remember to oil it on a regular basis per the instruction manual.
As for me, I use Fellows shredder oil
Fellowes Shredder Oil 12 oz Bottle with Extension Nozzle 35250
and oil my machine every time I dump the cuttings. I run a bead of oil in a serpentine pattern over a sheet of paper and then just shred it. (If you have never oiled the cutters, it may be too late to do so now. Something you need to do on an on-going basis).
Jan 23, 2015 | Royal 150MX Cross-Cut Shredder
How do I stop shredder from spitting documents in and out?
Try cleaning the cutters well. This will require you UNPLUGGING the shredder. Turning it (the top feeding-cutting) part upside down and removing ALL paper and if you see paper clips or staples-REMOVE THEM! You will need to start the motor several times to move the cutting blades around for a complete cycle to make sure you have removed all debris from the cutting blades.
If this does not work you may have an electrical problem you will not be able to solve. Look for your shredder number in the link provided below and download.
Fellowes Shredder Manuals
Sep 12, 2014 | Fellowes Powershred SB-87Cs Shredder
My Ativa HD Pro 1800 will not power on
First check the power point is still working - plug in another appliance, like a table lamp. If OK check the fuse in the shredder cable plug.
The commonest reason for a shredder stopping is a paper jam, or running the shredder for too long. By 'too long', many shredders will cut-out after 5 minutes continuous working, and the sensor may take 15 minutes to cool down! Read the manual.
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and/or long nosed pliers to poke at any compressed paper wrapped around the blades - can take a while.
It may be that the sensors are dirty - use a cotton bud dipped in rubbing alcohol to clean the sensor light(s) and heads
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
May 21, 2014 | Ativa HDM PRO 8000 8-Sheet Micro-Cut...
Its not working and shredder wont turn on
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and poke at any compressed paper wrapped around the blades - can take a while. Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
Feb 27, 2014 | Aurora Electronics AS1010TX Cross-cut...
Royal 85x crosscut shredder stopped working
Some shredders aren't designed to shred anything more than paper. Credit cards, staples, paper clips and the like could have jammed it up. Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 25, 2010 | Royal 85X Shredder
Motor and cutter do not rotate - strip cut model
Soak the clog with dishwashing detergent and a little bit of water overnight. This should dissolve the paper.
Jan 07, 2010 | Fellowes Manufacturing C220 (Strip-Cut)...
How do I remove excess EXCESS oil from my shredder? It won't shred.
Asking why you should keep your shredder lubricated is no different than asking why you should change the oil in your car every 3,000 miles. Not only is proper maintenance a requirement to maintain an active warranty, but all mechanical parts need a little oil to help them turn smoothly and to keep them clean. Applying shredder oil to the cutting heads inside a shredder lubricates them so that they efficiently destroy documents sheet after sheet. Fortunately, you will find that taking good care of your shredder is less expensive, faster and easier than caring for your car.
Every time you shred a sheet of paper a fine dust made of tiny paper particles is produced. This dust collects in the cutting assembly of a paper shredder. If allowed to build up, this dust will compact until it completely blocks the smooth turning of the cutting head. Shredder oil will actually break up the compacted dust lodged in the cutting assembly, allowing the parts to move and push out the softened dust.
Shredder oil is specially formulated to eliminate oil residue on the cutting head. Other oils, like WD-40, will attract dust, further clogging the cutters. When lubricating your paper shredder, only use oil specifically designated for shredder use or risk voiding your warranty and further clogging your shredder.
The frequency with which you should oil your shredder depends on several factors: frequency of use, shredder capacity, cut size and type of paper. Your shredder will need more oil the more you use it, the more paper you shred at once and the thicker the paper is that you shred. Also, shredders with smaller shred sizes require extra oil. A 1/4" strip cut shredder used only one to two hours per week will only require a weekly oiling. A cross cut shredder, on the other hand, requires oil after every half hour of use. If you remember to oil your shredder every time you change the bag you'll be in good shape.
There are two fast, easy ways to oil a paper shredder:
The first method involves applying the oil directly to the cutting head. Shredder oil is packaged either in plastic squeeze bottles or aerosol cans, designed for easy application. No tools are required, just aim the bottle directly at the cutting head, through the paper entry point, and apply a fine stream of oil from one end of the cutter to the other. Run the machine in reverse for 10-15 seconds until the entire cutting mechanism is coated. Finally, shred a few pieces of paper to remove any excess oil from the cutters.
The alternative method requires streaming oil onto a piece of paper. Do not soak the sheet in oil, but cover it evenly from edge to edge. Shred the oiled sheet of paper and then run the shredder in reverse for 10-15 seconds to allow the oil to coat the entire cutting mechanism. Finally, shred a few sheets of paper to remove any excess oil from the cutters. In any case, run a couple of sheets of paper through the shredder after oiling to remove excess oil. procedure may be repeated up to three times to ensure proper lubrication.
If you take a few seconds once a week or every time you change your shredder bag to oil the cutting mechanism in your paper shredder, you'll maintain your warranties and keep your shredder running smoothly and efficiently document after document.
click this link directly for more detailed help
---- http://www.howtocleanstuff.net/house/appliances-and-fixtures/how-to-clean-a-shredder/ --------
thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 22, 2009 | Royal 1280MX Shredder
Royal 10x Crosscut Paper Shredder (PCUA: 29054E) paper jams.
Try soaking the cutters with soapy water, yes it works. Oil after you are done.
Aug 02, 2009 | Royal VF1012mx Shredder
Aurora AS1010TX Will run forward for 1/3 of paper then into reverse.
I'm going to say it needs oiling. Try oiling the gears and cutting blades. You can buy paper shredder oil at Office Depot or Office Max.
Jul 10, 2007 | Aurora Electronics AS1010TX Cross-cut...
Fellowes Powershred 420-2HS High Security Confetti Cut Paper Shredder Logo
237 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
