Question about Philips Magnavox 27MS343S 27" TV
Our TV reset itsself to sales pitch
Our TV has suddenly reverted I guess you'd say to showing us all of the reasons you should "Buy this TV".  We can't change the channel, turn it off (without unplugging it) or anything. We don't have a remote for it and we'd bought a universal remote but it won't work on this TV. My serial # is 41099039 And my email is V_Bolin@yahoo.com
I've unplugged the TV and let it sit for a while thinking it might reset itself but it hasn't.
  • Anonymous Nov 06, 2007
    My magnavox tv has reverted to the sales pitch, but it won't let me into
    the menu screen, None of the buttons will work!
  • Anonymous Nov 07, 2007
    I have the same problem, but I can not get into menu mode, with the buttons on the tv or with the remote
We were having the same problem. Read on a different email to hold the Vol UP & Chan UP for 4 seconds and it will reset. It worked on ours.
Posted on Nov 08, 2007
  • 105 Answers
Youll have to go into the tvs menu and turn the demo mode off.
Posted on Oct 14, 2007
2 Suggested Answers
SOURCE: Our TV reset itsself to sales pitch
thanks , the solution you gave about the closed-caption option turning it off , worked .
Posted on May 25, 2008
Should I fix my TV or buy anew one?
Before you buy a new TV go through all the TV menu options to see if it has automatic dimming depending on the amount of light in the room. If it does it may be malfunctioning and turning that feature off may fix the problem.
May 29, 2016 | Samsung 6030 Series UN46FH6030 46" LED TV...
Internally change channel 3 to 4 on VCR
Hi, In most VCRs, as you have posted, there is a switch at the back where you can select the output to either Ch 3 or 4. In some cases, the switch is deep inside and you have to remove a small squarish rubber covering to expose the hole. It is normally close to the antenna input/output. More often than not it is a simple sliding 2 position switch. You would need any tool that can reach and sturdy enough to slide the switch. Internally program output channel selector is very possible, I would guess that its selectable via the menu set-up tabs. A question pls, How did you "I tried to manually change the channel to 4, but the VCR reverted back to channel 3..." Hope this be of some help to you. Pls post again how things turn up or further information. Good luck and kind regards.
Aug 01, 2007 | Quasar VHQ401 VHS VCR
TV doesn't respond to remote controller suddenly. I changed batteries of the controller and checked it. The controller is not a problem. I tried manual buttons on TV but it didn't work. TV turns on and...
This is caused by radio frequency and what i mean by that isyour tv unit is gettng confused with the crystals that control the connection between the tv and remote.The solution to this is to go to wal mart and buy a new universal remote and in the package should be an instruction manual to set the remote to the tv , First find your tv name in the pamplet,second there will show a code of the remote type it in and enjoy.
May 18, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Shows canceled?
Make sure u have signal on both tuners on the DVR ( check it in your set-up screen). both tuners should have the same siganl strength. Directv's DVRs, if installed correctly, give u the option of recording one channel and watch another, or recording 2 seperate channels( 2 tuners). If you are recording 2 seperate shows and u change the channel one of your recordings will cancel .
Sep 13, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Suddenly all of a sudden
I have a JVC AV48WPT4 48 Inches. Have perfect picture but fine retrace lines on the screen.
Can you tell me what could cause it?
Thank you.
Apr 21, 2008 | JVC AV-48WP74 48" Rear Projection...
1) Demo mode clears by holding vol up & chan up at the same time at the set front buttons. Or try menu & power.......
2) Black box is called a text box = part of closed-caption option.
Select CC to turn text box off.........
Note:Always provide Model # , Chassis # and age......
serial # not needed / helpful..........T.
Nov 05, 2007 | Televison & Video
Channel memory
this t5v is a piece of ****
Oct 20, 2007 | Niko OTP-2613W 26 in. LCD Television
Magnavox tv
Hold both vol up & chan up on front of set for at least four seconds.THen demo mode will release.
Oct 03, 2007 | Philips Magnavox 27MS343S 27" TV
Panasonic DMR-ES20
For the remote to work, make sure "video" is selected (instead of "tv"). It's the little button on the remote under the red button at the top that turns on the TV ("TV/Video")
As for the split screen, I've had that happen numerous times (when I lose power or revert to default settings). YOu have to go to Setup, Display, and select 4:3.
I hope I have helped you. I'm having other problems - with the audio. Some channels have no audio (maybe 3 or 4) and 2 channels are in SPANISH!!! (??) Weird that it's not uniform. I even tried reverting to default settings (and got that split screen!), but didn't help. It "jumped" a few times to the input type screen. I'm thinking some chip got fried or something. I've had it almost 2 years, and guess that's the "built-in" obsolescence!! :-)
Sep 26, 2007 | Panasonic DMR-ES20EG DVD Recorder
Philips Magnavox 27MS343S 27" TV Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
