Question about Microsoft Xbox 360 Elite Console
Car Ac Adpator does not work with Xbox
I've bought 2 Car Ac Adaptor to play Xbox in My Car. None worked. It seems not enough power. Then I place a Car Battery and the game last for 10 minutes. Is There any way to be able to play XBOX in the car ????????
  • jrobertox May 13, 2009
    It seems that XBOX takes all the power from the ac adaptor and turns if off. I even turned off the Air conditiner from the car which gave a little longer power, but at certain point the Xbox would shutt off.
  • Terry Vaughan May 11, 2010
    Not a good idea. Hard on the Xbox disc. Hard on the car's battery. How about a handheld for trips ? DS ?
  • 58 Answers
You need a power inverter you can probably find one at any auto store or electronic store or even Walmart. It takes power from your car battery and has an outlet on it so you can plug your video game system into it. Other than that you just need to hook up the plugs to the right av jacks and you should be good to go just have to make sure that the tv is on the right channel. i would also give your battery a charge especially if its old.
Posted on Jun 05, 2009
My Microsoft Xbox 360 Pro's power brick wont turn
You can try to Reset the AC adapter by following steps below.
1. Unplug the xbox 360 AC adapter at both ends (from the back of the system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
If this doesn't work it's probably fried from the power surge.
Jul 31, 2012 | Microsoft Xbox 360 Console
I've got one single 12000 btu ac unit and one double 24000 btu unit and three wall units controled by 3 remote controls.Recently one of the remotes stoped to work.I've changed the batteries(were...
Taking apart the hand held remote won't serve any real purpose as none of the parts inside are replaceable. Since you have 3 different units, with 3 different hand held remote. I'm wondering, if perhaps, you're using the wrong remote on that one unit. As each one has a different remote code.
In addition, I have learned from experience, that if the display screen on the hand held works, the problem is not in the hand held. Now, that's not to say, Operator Error can't play a role in it. But, most times, it's the receiver in the unit,that may be causing the problem. Or the hand held is to far away or something is blocking the signal in between.
Almost every appliance we sell, has a radio frequency remote control. The most problems we incur is with weak or dead batteries or operator error. The problem with batteries is that you don't now how long they sat in a warehouse, before making to a retail outlet and then how long they sat on the shelves there, before they were sold. They may have enough power to activate the handheld remote, but not enough to transmit a strong signal. So, check the strength of the new batteries you installed.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | LG LS-K1830CL Cool Mini Split Air...
Trying to connect the kinect
First off make sure you have at least 190 mb of space in your HDD before trying to set up your kinect.
Setup:
Step 1: Make sure your xbox 360 is properly connected to the television with the AV cables and power cable to an outlet.
Step 2: Place sensor under or on top of your television on a stable flat surface.
Step 3: Depending on your xbox the sensor has two different connections. If you have the new slim xbox 360 then you do not need the extra add on connection you simply connect it to a special port for it on the back of your xbox 360 slim. If it is a older version xbox then you will need the extra power adaptor since it will not work without it.(Cable with power connection)
Step 4; (ONLY FOR OLDER VERSION XBOX 360): If you have a wireless connection adaptor unplug it from the usb port in the back of the xbox 360 and connect the kinect sensor's power adaptor into the port you took the wireless connection adaptor off of. There should be a special cable that will act as an extension for the wireless connection adaptor you unplugged this is so you can connect it directly to the usb ports in the front of the xbox 360. Then plug the end with the power outlet connector of the kinect sensor power adaptor into the wall socket.
Step 5: Turn on the xbox 360 and the kinect sensor should move up and down to adjust.
Step 6: Put kinect game in and it will guide you through kinect settings and your on your way to start playing! Have Fun!
Feb 26, 2011 | Microsoft Xbox 360 Console
I already replaced my charger once. This is the second time it just wont charge my laptop and it hasn't even been a year since I replaced the last one. What is wrong?
guess the problem is with your laptop battery....chargers normaly dont crack soon.....
charging the battery....is not OK
to sort out the issue
do this...
1 remove the battery from the battery bay....(hope u know how to do that)
2 now connect the adaptor and check if the notebook works....(without the battery in the bay)
3 now remove the adpator and install the battery...check if it now works with just the battery....
4 now connect the adpator to notrbook with the battery in it's bay...start the notebook.....and let it work for some 3 - 5 hrs
5 remove the adaptor...check if the battery immediatly takes over...if not then battery is the issue
Feb 17, 2011 | Compaq Presario CQ60215DX Laptop Charger...
My xbox 360 works fine playing the games that are demos
there might be a short.
other then that i might just think that your power adapter is failing and you need another one.
Dec 01, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
My ac adaptors light is orange and my x-box is not coming on
Send it back to microsoft the Motherboard is broken mate.
xbox.com/support
Aug 22, 2009 | Microsoft Xbox 360 Console
360 dance pad not working on xbox
try plugging your usb connector into the usb port located in the back of your xbox 360 next to the power cable coneccion
Mar 31, 2009 | Konami Dance Revolution DDR Original Dance...
No Power : Dell Inspiron 6400
the very first thing that u can try is that try with the different ac adaptor and the battery if u have and if it doesnt the same thing then definately u have to replace the motherboard and if the other ac adaptor and the battery works then replace the ac adaptor and the battery but what i suggest u is that u should replace the ac adaptor and the motherboard both at a time and it will be fine and for that u dont have to worry about ur data in the computer cause replacing the motherboard will bot loose ur data.......
Jan 25, 2009 | Dell Inspiron 6400 Notebook
Microsoft Xbox 360 Elite Console Logo
124 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
