Question about Whirlpool CGM2761KQ Gas Commercial Dryer
No heat with new element and coils
Will not fire i replaced the element and the coils the colis do not magentise when running what else can i check
  • Whirlpool Master
  • 8,220 Answers
Check the fuse:
no heat with new element and coils - 4d909cc.jpgThe dryer will run if the fuse is blown on a gas model.
Posted on May 14, 2009
Pulled out heating element both black wires connecting heating element are burned is this mean its a faulty heating element
Hi franklin bai
Yes the element is faulty...replace it...but also check some other things...see below
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks.
If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the
wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed
component. The switch is inside the dryer main housing near the door frame.
Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Check for continuity you should have none with door open, and should have a reading when closed.
If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause
heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the
thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape
or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged
with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's
plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace an element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Apr 16, 2011 | Amana NDE2335AY Electric Dryer
My dryer quit heating. put in new element but still wont heat. is there something that im missing?
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape and running the dryer to check to see if the element is red or not,
or with an ohm meter check the two terminals of the thermostat/thermister
after you have removed the wires, the thermostat/thermistor should have/show continuity across the terminals.
If the coil heats up, or the thermostat/thermistor shows an open circut
then replace the thermostat/thermistor as it is defective.
If it overheats the dryer will not operate properly.
It cannot be reset. A vent clogged with lint can cause it to overheat.
You can test it with an Ohm meter/continuity checker, if no continuity,
replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
For video and pictures on how to replace an element go to the following website, it will give you an idea what you are in for:
Jan 13, 2011 | Kenmore 63942 Dryer
Kenmore Elite Dryer, runs but doesn't get hot and dry clothes...What part to do I need to swap out?
Check your Wiring
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
For video and pictures on how to replace the an element go to the following website, it will give you an idea what you are in for:
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
Dryer has new heating element run but will not heat
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
For video and pictures on how to replace the element go to the following website:
Dec 31, 2010 | Dryers
Dryer doesn't heat up
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
For further instructions on how to replace the element go to the following website:
Oct 02, 2010 | Whirlpool Dryers
We have no heat in the dryer. It runs great but no heat. What can we do?
Oct 02, 2010 | Whirlpool GEW9250 Electric Dryer
No heat
Oct 02, 2010 | Roper Dryers
Everything seems to work fine, but dryer does not heat
Oct 01, 2010 | Kenmore 62062 Electric Dryer
How to replace a heating element for a kenmore
Hello there
i am posting instruction for this dryer below
(For some help with that, and before buying an element you might not need, please see my article entitled 'The No-Heat Dryer'). Note: Always check airflow out the vent before firing up your dryer with its new element. A partially clogged vent can burn out an element - even a brand new one - fast! Just run the dryer on the 'no-heat' or 'fluff' setting, then go outside and check for a good strong flow of air from the vent hood. If there's any doubt, Whirlpool makes a cool little airflow test kit for their dryers that will tell you for sure, from inside.
There are basically 3 styles of heating elements in use for these dryers.
1) Most common is the 'long' one, part number 4391960, accessed from the back of the dryer, and which looks like this:
wpl%204391960%20el.jpg To replace this one, power down and pull the dryer out and remove the back cover. You'll see a long, vertical 'can' on the right side, with the element coil inside. To remove this can, simply pull the element wires (can be hard to remove; I use a long-nosed pliers), the limit thermostat wires just above them, and the thermal fuse wires if equipped (this is a little device mounted high on the side of the can, with two wires attached). One 5/16" hex screw at the top and a little strap holds the can in place. Remove this screw (You can look through the small hole that lines up with it, originally to poke a long screwdriver through), tip the can rearward, and lift it off its two bottom hooks. Once the can's out, one screw holds the element inside. Remove it, and the old element coil will slide out. Slide the new one in, reverse this process, and you're done!
Nov 13, 2009 | Kenmore Dryers
Dometic w/hp installed,has 115ac @12dc thermostatworks sends signal but won't fire
hi! there, as you mention since source was 115 voltwas initialized and thermostat detected was functioning but heater won't fire, check if there's incoming source on your heating element using multitester on voltmeter set up,if there's source 115 volt,check your heating element resistance be sure to switch off your ac before checking resistance of your heater (your tester may damage upon testing resistance when ac source was on takenote),set your tester to ohmmeter R10 test rod at both end on terminal take reading if no deflection,you have busted heating element,replaced heating element,If there's relay holding supply on heating element on circcuit board try to check it out.if source 115 volt is acquired,also check the resistance coil of relay,iif defective replaced one...have a nice they.
Mar 29, 2009 | Dometic Heating & Cooling
Whirlpool CGM2761KQ Gas Commercial Dryer Logo
63 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
