Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster 1/2 hp won't open
When i hit the wall switch or the remote i hear a single click. on the back of the ceiling unit there is a green button with a green LED by it. when attempting to open door the green LED begins to flash..i reset it by pushing the button but when attempting to open i hear the one click and the LED begins to flash again
  • 2 more comments
  • blacklabguy May 12, 2009
    5 flashes then a pause then repeat....I took the cover off and can turn the horizontal (worm gear?) by hand and it engages the gear with the vertical shaft and it will raise and lower the door. i have also released the lever and the door raises and lowers by hand with ease..thanks
    if i turn the gears by hand and lower the door that way (say a foot or two) then push the wall controller the door will raise and the motor drive stops as normal...but push the wall controller again and it clicks and nothing
  • blacklabguy May 14, 2009
    I've turned the up limit (down) so the door does not clear the 7' opening to no avail.
  • Don Maggard May 11, 2010
    The green button is not a reset. It is used to program the remotes. Watch the LED for a bit and see if it is sending a code. Any number of flashes followed by a pause and then repeating. You also need to remove the cover and look at the white nylon drive gear just in front of the motor. It may be stripped.
    President:
  • 3,197 Answers
Turn the gears again by hand like you did and lower the door a couple feet. Now find the 'up limit' on the side of the motor unit and using a small screwdriver turn this about 3 turns in the opposite direction of the arrow printed on the cover. Now you can go ahead and operate the door.
Posted on May 13, 2009
  • Don Maggard May 14, 2009
    You may have a bad RPM sensor board which is the small printed circuit board just in front of the motor. This will cause the door to stop on the way up and to reverse to the open position when it is going down.
I have the door bell style wall button-how do I unlock the unit so the remotes can be synched? I have pressed green button on back of unit with remotes but they won't operate the door.
You don't unlock anything to program the opener for the remotes. If everything is working you do this:
Press and hold the button down on the remote while you press and immediately release the smart/learn button. Do this for each remote.
Jul 11, 2012 | Sears Craftsman LiftMaster Chamberlain...
Older Model Hampton Bay Ceiling Fan: The Redington II w/Remote Control
sounds like the radio signal amp is blown..that is a full replacement deal..that would explain this, and the power
#glitch could certainly cause this problem..
Oct 26, 2008 | Hampton Bay 52 In. White Redington...
Our garage door is not opening with the wall unit or remotes. When I push the wall unit I hear a click from the ceiling unit. The door operates fine manually. The green light on the ceiling unit (the SRT...
The green light on the motor unit is an LED and random flickering is normal. Your problem is most likely caused by an electrical storm or power surge. You will need to remove the logic board from the motor unit and check for burnt or missing traces on the printed circuit board especially around the small transformer. Your holding that button in will most likely have erased the memory of the unit and all your remotes will need to be programmed once you find your problem. I really suggest you call an technician at this point.
Oct 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: when i push the wall unit i hear a click from the ...
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor. It may be going bad.
May 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Hunter remote 85752 does not work
You probably need to re-sync the remote to the fan. To do this, turn the power off to the fan; and within ten seconds, hit the "3" button, then the "2", and then hold the 1 button until you hear a click. This should fix it. Good luck!
May 06, 2010 | Hunter 27185 Remote Control
No response to remote on Liftmaster 1/3 HP model # 1245R
It has probablly lost sync.
Follow the procedure to reload the codes. One usually has to hit a reset button on the head and then follow a sequence to sync your remote to the head.
Sep 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a 1995 Sear garage door opener that stopped working
The trolley (the part that moves back and forth and is connected to your door) of your opener is most likely jammed against the bolt just in front of the motor unit. You can remove the bolt or loosen the chain until your unit will run. Once the door is closed find the 'up limit' on the side of the motor unit and turn it about 3 turns in the opposite direction of the arrow printed on the cover. Now replace the bolt or tighten the chain. Whichever you first did.
May 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener Clicks only and LED blinking 5 times
Just fixed this problem tonight. Had the 5 blink/flash thing. Opened it up and saw that the motor wasn't spinning so it wasn't a bad rpm sensor. Jumped the red to black and then the blue to black to verify motor worked. At that point assumed it was the logic board not telling the motor to start, but I could hear the click of the relay. Pulled the logic board out and noticed a solder joint that had failed directly behind one of the relays. Resoldered that joint and the garage door opener worked again like a dream. Hope that helps someone else.
Feb 28, 2009 | Building Materials
I push wall button and hear clicking but won't open
Try unplugging the operator. This may reset any problems you had.
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
483 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
