How do i stop picture rolling when I put in a video
    Sergeant:
  • 273 Answers
Most likely thing would be your tracking on the video head is out, most video players have controls to adjust the tracking
Posted on May 12, 2009
How to stop pic rolling on slave monitor
hi i really don't understand what you mean, and here it is only for cameras !
Dec 31, 2014 | Sony Video Cameras
Picture rolls when view finder is fully open. When partially closed it stops rolling. Sometime it stops rolling when view finder is slowly opened to full position.
Most likely a ribbon cable with a bad connection on one or more of it's conductors. It requires dismantling the camera to expose both ends of the cable to check the plastic clamp connectors to this cable on both ends. Another possibility is a partially damaged ribbon cable making intermittent contact. If it's the cable, it requires a replacement. Do you feel you are capable of this level of service? If unsure, then best to leave to those who are comfortable with this type of work. Nimsgame
Feb 19, 2011 | Sony Handycam DCR-SR42 Camcorder
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
The picture rolls and seldom stops which makes it difficult to take pictures.
In most cases the flex cable to the flip out panel fails and needs replacement. I repair these for $200 including ship back to you if your in the lower 48 states. Larry's Electronics ledstiles@hotmail.com 916-362-8708
Apr 21, 2010 | Sony Handycam DCR-SR82 Camcorder
VHS Video Tape - Picture Roll.
Picture roll is caused by the frame rate being out of sync with the play back device. If the tape was recorded at say 25 f/m and is being played back at 26f/m. If you can, adjust the frame rate until the picture stands still.
Mar 30, 2010 | Philips VRX242AT VCR
Picture on tv rolls when dvd player is on.
Radio Frequency Interference (RFI) being generated by you rDVD Player.
That, or you have the DVDs settings on PAL instead of NTSC.
Mar 13, 2009 | Prosonic PD-007 DVD Player
Can't figure out how to get s-video conections to work
to use s-video have to switch tv/video to video input
May 03, 2008 | Durabrand DWT2704 TV
Picture rolls
Same as sherpi here, player was fine, and all of sudden started rolling and never stops. Rolls with or without a disc in it...seems to play the discs fine, but never quits rolling.
Mar 08, 2008 | Spectroniq PD-1100 DVD Player
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Akai DHT300 screen rolling
The picture is rolling because there is no sync signal in the composite output. Are you using the RCA jack or the S-video output? Is there another small TV you could hook up for a test to see if the problem appears there? If it does, then the Akai has the issue and needs to be examined further. If not, the TV input may have an issue. You didn't say what the TV is but there is the possibility the video input is looking for external sync from the DVD but that's a bit of a stretch. Can you feed a different source into the video input of the TV to see if you get the same result? Hope this helps.
Nov 01, 2006 | Akai DHT300 System
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Electro Med Services...
