Question about Coleman Electrical Supplies
How do I hook up a battery and what voltage do I need for the electric start on my coleman 5000w generator
    Scholar:
  • 79 Answers
If a starter is supplied with the genset then you will need a 12 Vdc lawn mower battery.
Posted on May 12, 2009
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Generator sat unused 2 years. whatshould be done before using for long periods
Change the oil and you will probably have to rebuild the carb. If it has a starting battery, that will need to be replaced as well.
Aug 10, 2014 | Coleman Powermate Powermate 5000W...
We just bought a coleman powermate 5,000-6250 gen and it runs great but will not produce electricity. i hooked a 75 watt bulb up to each plug in and it would just barely come on the fade out. but would...
Your generator produces proper voltage and 60 cycles at 3600 rpm. Use meter to adjust voltage/engine rpm. If after adjusting rpm setting and gen. does not have proper power, remove cover to generator and examine brushes and commutator rings for wear and voltage regulator/rectifier for burned components swolen or leaking capacitor and replace parts as necessary. Parts are available www.jackssmallengine.com Good luck
Sep 09, 2010 | Coleman Powermate Powermate 5000W...
Generator runs but does not generate any electric
hi, what i need u to do for me in order to help u is, get a multi meter and tell me what is the voltage on the live and neutrueal.
should be about 60 volts. let me know.
Jul 11, 2009 | Coleman Powermate Powermate 5000W...
Coleman PM0433500 Brushless Generator will not make power
Bad capacitor. They cost 13 bucks. Call 800-445-1805 to buy one.
May 31, 2009 | Coleman Powermate Powermate 5000W...
Do you excite generator while it is running ?
Yes! The generater must be running. Only apply voltage for one or two seconds when exciting then check for ac voltage with a meter. You can try again if no voltage. Note: if exciting the field does not work your problem may be something else.
Mar 30, 2009 | Coleman Powermate Powermate 5000W...
Colman powermate 5000 no putting out any electric
If you are getting some power, even if it only 2vac then you may have to flash the excitor circuit. If nothing then take the end cap off the generator and clip your meter to the metal portion of the brush holders or exposed wire from them. Start the generator and see if any voltage is coming from the brushes. Even if there is nothing try flashing the excitor.
To flash the excitor circuit on a coleman ( the generator is built by generac) you need a 12 volt battery. You quickly apply 12 volts via your 120vac recepticals. NO MORE THAN ONE OR TWO SECONDS! Then check you ac voltage.
Give this a few attempts and if this does not do it, I would say the winding repair did not work. Buy another generator and use the engine for a go cart or backup engine since this generator is so cheap.
Mar 17, 2009 | Coleman Powermate Powermate 5000W...
No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Dec 18, 2008 | Coleman Powermate Powermate 5000W...
Replacing eletric portion of Coleman PMA525500
my voltage meter shows 300volts instead of 230-240 and continues to trip generator breaker. What is my problem?
Sep 06, 2008 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
51 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
