Question about Gateway GT4010 (RBGT4010) PC Desktop
Gt4010 I bought a gt4010 about a 18 months ago.  It started changing colors on the screen to a green shade briefly.  Then it became longer and longer.  Sometimes it will go weeks between incidents.  Then they became more frequent.  Then  it would not boot past the BIOS screen ( press f2 for boot order and press f10  for bios )This screen was not stable. 3  Vertical small white lines unsteady run on the screen.  I  reformatted and reinstalled.  The color change is still evident.  Ran everest on it and the tempature of the processor was steady 40 degrees C. I tried to replace the video card and the Geeks told me something was wrong with the PCI-E slot because they could not get an add on video card to work.This machine has a total of 3 G ram.  Vista.I installed a 600 watt power supply and nothing changed.Because of the steady  processor temp, I do not feel the processor is bad, but I cannot explain the failure to boot.  Please help.  I do not know if I should get the same Motherboard and reuse the processor and memory, or throw it all away
  • 2 more comments
  • robsdad Nov 06, 2007
    my pci e video card stop working then the on board video stop the the computer would power up but hte hard drive would not power up
  • Michael Tso Mar 05, 2008
    I tried to add the PCI-E video card. I also goto windows xp and disable the on-board video driver. Doesn't help. It still uses the on-board video. If I disable the frame buffer size. The machine won't boot at all. However, the PCI video card will work fine.
    PS: For some reasons, I am able to use the PCI-E video card once. However, when I switch to the other PCI-E video card, it fails again. : (
  • Anonymous Oct 19, 2008
    I have the same exact problem. When I first installed a pci-e card worked well, automatically disabled on-board video then. A year and a half later I try to install a new card and nothing. pc comes on no video, hdd doesn't go through the motions.
  • Michael Tso Dec 10, 2008
    I still have the same problem. Now, I am using the on-board video. BTW, does anyone have the restore CD/DVD? I still have the 4G partition, but I don't have the startup media to create the restore CD.
  • 47 Answers
Get a new  Motherboard. See if that works, seems like you've checked everything else.  Good Luck!
Posted on Oct 14, 2007
My sceptre lcd tv is displaying really bright pink and green colors
I had a similar problem with blacks showing up as green. Turning up the brightness a bit fixed it for me. Not a permanent fix, but something to try if you want to make it last a bit longer until you can get a new one or fix it.
Mar 24, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
I purchased my Acer monitor only a few months ago. I opened a very large file (pdf) of artwork for new label design......it hung up my computer due to the large size. However since then my monitor is a...
When you start your computer, if before Windows starts up it's a shade of green, it could be as a result of the screen cable not plugged in properly at some point. If not or if that doesn't work, it could be the software or hardware but I don't know how a pdf can do that??
Feb 04, 2011 | Acer 22" X223w LCD Monitor
Green shadows appear on new visio SV470VT. Very
It maybe a circuit control board for the screen. Last thing you want to do is void the warranty by opening up the TV.
Best to use the warranty at this point. Here's info to get you started.
Phone Numbers
Technical Support or To Place an Order
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
techsupport@vizio.com
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
Jun 28, 2009 | Vizio VO47L 47 in. LCD TV
Green shade color on screen over tyhe program that is been broadcast
its a loose connections to you color amplifier RGB. cold solder in that board section.
May 30, 2009 | Samsung HL-R6167W 61" HDTV
Some green color patch in the middle of the screen
Looks like you have an LCD. I was guessing it may be magnetic related in which case I would recommend you degaussed your display using the degauss function but your monitor won't have it since it's not a CRT by the looks of it. I would recommend contacting your dealer or where you purchased the monitor at a retail store. Since it's only 8 months old, you may be able to return it under warranty. If your retail store doesn't let you do that, talk to View Sonic directly and see if you can RMA your product for returning to the manufacturer and receiving a new or repaired unit.
Check out Viewsonic's website for more information.
Mar 24, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Hi. i have an LG 42inch plasma, approx 18 months old. about 2 months ago, a green stripe developed down the right hand side of the screen, approx 1.5 inches wide. last week a 2nd stripe the same width...
Sadly, the plasma screen is failing. The green strip is no longer functioning properly and the failures will continue to progress.
If still under warranty, get it exchanged.
Jun 12, 2008 | Computers & Internet
Blue screen
I would suggest getting another optical block from the repair man. Apparently even some replacement blocks have had issues...
Jun 06, 2008 | Sony KDSR50XBR1 50" Projection HDTV
57xbr2....tv turns on briefly...solid color screen for a second...then blank?
I had the same problem about a 8 months ago. I searched online and found that there is a problem with one of the color guns. They need to be replaced. I don't remember where I found the information, but there is a number or something to call for this problem. I think that my authorized sony repair man knew of the problem, there are other models that have the same problem. Anyway, sony replaced all three guns in my tv FREE of charge, and my tv was no longer under warranty. They did all repairs and fixed my tv.
Aug 25, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Gateway GT4010 (RBGT4010) PC Desktop Logo
122 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
