Question about Sony SLV-D300P DVD Player/VCR
Dvd troubles dvd player will not read dvd and will not let us get to menu or even open
  • Genevieve Grasso-Kurk Apr 12, 2008
    I have a samsung flat screen tv. Best buy hooked to my dvd/vcr and now I can't get dvd to play. What do I do?
If it's a DVD/VCR machine, put a videocassette in the VHS slot after you have already put a DVD in the DVD slot. Switch your remote control temporarily from DVD to VCR and press "Play". The videocassette will start playing. Then, without stopping the cassette, switch the remote back to DVD. The menu should now be on the screen. This always works for me.
Posted on Oct 19, 2007
Same problems with my unit.  But, try this... I think it worked.  First, you can not get to the setup screen for the unit with a DVD in the player.  So, remove the DVD first:  Unplug the unit, wait a few seconds, plug it back in.  Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play.  At the Sony Blue DVD screen, select Setup on the remote control.  Select DVD setup and get to Parental control.  Set a password.  This will then take you to a "rating" screen.  By setting the rating very high (I set mine for #8) any movie should play without needing the password.  With no password set, you can not change the "rating" and hence mine was set at #1 (kids).  It seems to have worked for now anyway.  Good luck.
Posted on Oct 15, 2007
What could be the problem if a dvd won't play on my dvd player.
For a start, try to read the DVD on a computer. Press on CD/DVD on right button's contextual menu for exlpore. If the computer can open and list the DVD, try to play it with VLC player.
If you have problem reading the DVD disk, it's it. If you can read, it's your player
Feb 20, 2015 | Sony Televison & Video
Trouble with Dvd player in Dell Inspiron 530
Find the small pin hole on DVD player and use a straightened paper clip to manually eject in case there is a stuck disc.
Use system restore to roll back your system. Look for a restore point longer than the three days.
I don't see a correlation between the two because the system should work even you don't have an optical drive (CD\DVD).
Aug 30, 2012 | Dell Inspiron 530s Desktop Computer
Sony Blu Ray DVD won't open, but disc inside is playing
hold on to open boton but it might take a while to open or the rubber that open and close the door is little bit slack that why its giving that type of prob, try and change it .
May 30, 2010 | Sony Blu-ray/dvd player BDP-S1
The player will not work and I can't open the door?
Grab a screw driver , remove the case of the dvd player, remove teh DVD, then junk teh DVD player.
Aug 25, 2009 | Sanyo DWM400 DVD Player
My phillips dvd player (model DVP5990) is not reading disc at all no matter the format. any ideas?
This could be several problems. You should first try to clean the laser head with a cleaning disc. If this does not work you can try resetting the dvd player to the factory settings. This function is found in the settings section under preferences. Use you remote control to open the settings menu and use the up and down arrows to highlight the preferences section. Press ok to enter the sub-menu. Use the up and down arrows to highlight the default setting.Press ok. You have now reset the dvd player to the factory settings. Press the menu button again to escape the menu. All this information is in the owners manual on page (47). Try a dvd to see if the dvd player is working properly. If not you may have other problems that will require you to open the dvd player up to find the problem. These problems could be a laser lens that is not functioning properly or a problem with the transport that is use to set the dvd up for reading by the laser lens. For these problems it is best to have a qualified technician to troubleshoot the problem.You can call phillips customer support at this telephone number 1-800-744-5477. Tell them the model number of your dvd player and the problem you are having with disc player not reading discs. They will be able to help you get service for the dvd player.I hope this information helps you with your problem.
Apr 12, 2009 | Philips DVP5990 DVD Player
Philips DVD player DVP5980 reads Region 2 only - need an Unlock Code in order to read Region 1 discs.
1) Open the tray of your DVD Player
2) go to Preferences in the Setup Menu and enter 138931 with your RC
3) Options appear: Chose region 0 in order to play all DVD's
Aug 31, 2008 | Televison & Video
Can't copy disc's
There might be a problem with lens of your dvd drive..so get cd lens cleaner to clean that lens..or use nero to make a image of that dvd because if nero fails to copy that dvd you will not be able to copy the disc.....
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
May 01, 2008 | GoVideo R6530 DVD Recorder
4805 blank screen
My first guess would be that the projector can't sync to the DVD player after the reading stage. If correct, you should be able to change the settings on the output of the DVD player.
Feb 25, 2008 | InFocus ScreenPlay 4805 Multimedia...
Won't play ANY movies
separate the plug on the other appliance,check if the trouble is dvd or tv by connect other input device like game console or dvd.
Feb 11, 2008 | RCA DRC8052N DVD Recorder
Plays CDs but not DVDs
I had the same problem, don't try to hard it won't solve the problem. Just buy a new cheap one and it even will read more formats.
Mar 12, 2007 | Panasonic DVD-RV31 DVD Player
Sony SLV-D300P DVD Player/VCR Logo
574 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
