No picture, and flashing orange LED for 1-2mins and then 2 red?
With power on standby it the LED is red. But as soon as i turn the TV on. That same LED is flashing orange constantly for 1-2mins and then a clicking sound is heard from the TV and then 2 of the bulbs turn Red. And then stays that way with no picture..... Any ideas as to what this fault is?
welcomejee
  • 10594 Answers
SOURCE: KDS-60A3000 new bulb gets 6 flashes of red led
Please put back lamp (bulb) cover properly and check as lamp cover is open/ not fixed or improper fix is also cause of LED flashing.
Posted on Jan 08, 2009
SOURCE: standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Posted on Jan 18, 2009
ripleymojica
  • 643 Answers
SOURCE: sony kf-50we610 power led flashes red 5 times
Needs new lamp or the fan is out.
Posted on Jun 02, 2009
  • 13 Answers
SOURCE: tv wont turnon afterstandby
LG will sell you a new lamp. It may resolve the problem but just as likely it's the contacts where the lamp unit plugs to the TV. There's a few types of connectors. The early ones are dodgy and cause the problem you describe. A faulty lamp can also cause it though.
Posted on Jun 05, 2009
  • 668 Answers
SOURCE: sound went out, tv turned off, red light flashing...
The Lamp being bad as well as one of the three fans in the unit not turning could also cause the problem.
Hope this helps,
Skyassoc
Posted on Jul 25, 2009
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
Sony KDL-40S4100 Bravia LCD will turn on for like 2 seconds with picture and green power led, and then goes to flashing red standby led twice for a bit. Then I hear a
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Mar 28, 2011 | Sony Televison & Video
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
Akai pdp 4294 wont turn on
The power supply board needs to be replaced or repair. No other quick fix is available. Thanks
Nov 26, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Standby LED flashes red 4 times with pause then 4 times
You either have a bad fan or one of the rotation sensors mounted on one of the fans has failed. Take the back off the set and see it the main fan slightly right of center is rotating. If it is, there are two more fans, one mounted right above the lamp and another on the optical block itself. You will have to pull the optical block to check those.
Oct 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
TV Sony KV-29F1E turn-on failure, red standby LED flashes (starts after 10-20 attempts)
When the set ends up flashing the LED, it should be a repeatable count. Can you please report that count here? Also, since the set eventually works, I'd suspect a bad connection or a part that has changed value over time. The blink code will help to narrow down the offending circuit.
Dan
May 12, 2008 | Televison & Video
PFM-42b1e LEd flashing 6 times... 1 sec. picture with green stripes... and then it turned to standby
I have a sony tv PFM-42B1 when I turn it on it go to standby an a red light flash I count count 14 time but I heard that it only support to flash 1 to 6 time how do count the flash
May 06, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony Wega kv27FV310 standby flashes 2 times with no picture or sound
standby button blinks no picture no sound have tried to reset and restart nothing has worked to get tv to back on
Mar 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Unit will not turn on from standby
I had a similar problem and it was caused by my cable box being in scart 1 as soon as I changed over to scart 2 the problems went away,
Nov 04, 2007 | Hitachi 42HDS69 42 in. Plasma Television
Televison & Video Logo
170 people viewed this question
Top Televison & Video Experts
Electro Med Services...
