Question about Acer AL1912 19" LCD Monitor
My acer AL1912 monitor keeps going fuzzy. It kind
My acer AL1912 monitor keeps going fuzzy. It kind of goes fuzzy then back to normal? Got any suggestions. I checked all the settings and everything is set at default.
  • Acer Master
  • 5,568 Answers
An unusual problem for a flat screen monitor.
I suggest you connect the monitor to another PC to see if the problem persists since it could also be caused by the video card (or circuit, if on board).
Check your cables making sure they are solidly connected and wiggle them to see if you can cause the problem to come or go away; this would crudely check the shielding of them.
This kind of aberration could easily happen with a conventional CRT monitor if power supply filtering was failing but as mentioned, uncommon in a monitor that is essentially digital.
Posted on May 12, 2009
I have an acer AL1912 and a (auto config please wait) gray box keeps popping up,how do i stop it
If it gives you message about the resolution, set the computer to use native resolution of the monitor. You can change the resolution by right clicking on desktop and choosing "screen resolution".
Dec 27, 2013 | Acer AL1912 19" LCD Monitor
Acer AL1912 19" LCD Monitor goes black after power up
With the screen connected to the pc (which is running and putting out a signal) hold a bright light to the front of the lcd - a led flashlight works well. Do you see an image? If so then circuitry driving the inverter backlights may be at fault. I had this happen with a Dell Flat Screen, and found one of a pair of transistors which drives the backlight had developed a short.
Aug 01, 2009 | Acer AL1912 19" LCD Monitor
Any Drivers for ACER AL1912
With very few exceptions, LCD monitors do not require a driver. Almost always, and display setting issue is an issue with the Display adapter (Video Card) driver. The plug and Play monitor driver that is native to Windows should work just fine.
Jun 13, 2009 | Acer AL1912 19" LCD Monitor
No display
Your minitors power supply is now damaged, probably from the power outage. I t will need to be repaired or replaced. Check the cost and benifits of both options and make a discision.
NSSMS
Jul 30, 2008 | Acer AL1912 19" LCD Monitor
Acer al1912
You havn't so much lost a colour as you have a damaged video cable from the PC to the monitor.
The wires inside the cable can break very easily, and will make contact (and look normal) if the cable is moved into the right position.
Grab the cable about 4" from the back of the PC and push it towards the PC (while it's all plugged in and running).
Then move the cable in a circle while it's sort of crunched up like that.
The signal should go good (maybe only for a second) and if you can find something to keep the cable in that position until you get a new one it will be fine.
If you have a spare cable, then just swap it over.
Jul 12, 2008 | Acer AL1912 19" LCD Monitor
Acer al1912 19" black
See if the problem happends in safe mode ( while booting hit F8 and aboot menu wil come up) if everything works fine then your issue will be the driver or a resulition that the display does not support or a refresh rate. Frist try to change the Res to a lower one and common (1024X768 or 800X600) also change the refresh to somewhere 70 to 75 and reboot if this dosent fix the problem try updating your video driver in safe mode
Jan 09, 2008 | Acer AL1912 19" LCD Monitor
Picture too big
Assuming that it is not a hardware problem, in Windows XP (or in most Windows version), you need to increase your display screen resolution. To do this, pls click on any clear area of your desktop. Click on Properties, click on the Settings tab, move the Screen resolution slider towards the right. Tha maximum resolution of your Acer LCD is 1280 x 1024. Set it to your preference/allowable. Click on Apply button, click on Yes button, OK.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 07, 2007 | Acer AL1912 19" LCD Monitor
Monitor keeps saying self test everything working check plugs
The self test thinks nothing is connected to it
it might be the cable or the input circuit.
not an easy issue to verify if you only have one input.
most often its is the internal board with a failed input circuit.
you can only open the unit and test the vga cable continuity.
as most have a 1 year warranty you might want to check on yours.
Nov 13, 2007 | Acer AL1912 19" LCD Monitor
Acer al1912 with S3inc trio 32/64 card
start with a 1024x788 60hz refresh , connect lcd
and then try any higher freq/refresh as it will ask you to verify.
Nov 02, 2007 | Acer AL1912 19" LCD Monitor
Acer AL1912 19" LCD Monitor Logo
787 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
