Question about Nikon Speedlight SB-22S TTL Flash
Where can i got Nikon SB 22 flash ?
Where can i got Nikon SB 22 flash in india ?
jackboy
  • 2985 Answers
SOURCE: sb 600
Switch camera off and remove batteries. Leave for half an hour. Re insert batteries switch on set to flask and hold to ear. Can hear a whistling [This is the Flash charging up] If you cannot -assume the flash unit has failed. Now go to the Manual - A full version is in a PDF file on the Disc. Check through that you are doing every thing correctly. If still no lick Nikon customer support will advise your next move. The likely hood will be that if the camera is over a year old they may offer a discount on a replacement. A repair is not likely or very pricey.
Posted on Aug 03, 2007
  • 48 Answers
SOURCE: NIKON D200 RELATED
lick my arse. lots. and lots and lots.
Posted on Jun 25, 2008
  • 48 Answers
SOURCE: Speedlight SB-80DX TTL Flash ideal for NIKON D60?
It works but it's not ideal. The SB-80DX won't support TTL flash on the D60, only non-TTL Auto and Manual. The SB-800 is the most capable flash unit for the D60, but you can get full TTL operation with the less expensive SB-600 or SB-400.
Posted on Feb 07, 2009
WHICH FLASH I CAN USE FOR MY NIKON D60
Posted on Mar 03, 2009
  • 8 Answers
SOURCE: flash is not working for a nikon sb-600 speedlight
zoom the flash all the way in so you can see if the flash bulb is broke
Posted on Mar 20, 2009
Can I use Nikon SB-22s speed light with my Nikon digital SLR D5000? Is that compatible? I bought SB-22s for my previous Nikon film camera. Thank you.
You should be able to use your SB-22 with your D5000, however you can only use it in the manual mode since it is not a TTL speed light. That means you will need to manually set both the camera and the flash unit. I have done that successfully with an SB-25 on both my D800 and D90 in a pinch, but you should consider investing in either an SB-700 or SB-910. They are allot more versatile.
Oct 26, 2013 | Nikon Speedlight SB-22S TTL Flash
Nikon d90 and spidlight sb 22 TTL not working can that spidlight be yuset on d90 or not
this flash will not work on the newer digital nikon cameras, the flash for d90 needs to be ittl compatible.
Jan 12, 2011 | Nikon Speedlight SB-22S TTL Flash
Speedlight SB-22S TTL Flash: i have a Nikon Speedlight SB 22 that was used on m...
sorry ,you will have to get a flash for digital.nikon dx type.film flash not compatible with digital.
May 17, 2010 | Nikon Speedlight SB-22S TTL Flash
Can not flashing
Its triger circuit might be out of order. Or the main tube also could be at fault. Needs to be opened any way. If you are in India contact me.
Jul 17, 2009 | Nikon Speedlight SB-800 TTL Flash
Sync speend
1/125 of a second, according to Nikon, but I've found on my N8008 that using 1/60 is more reliable.
if you use one of Nikon's dedicated Speedlights (SB-24, SB-23, SB-22, SB-20, SB-18, and SB-16B) then they set the synch speed automatically.
Jul 01, 2009 | Nikon N6006 35mm SLR Camera
Nikon SB-800 flash won't rotate any more
Your flash needs to be opened.There is a small pin which must have got stuck. In SB 800 we need to open both upper and lower portions of the flash. If you are good at opening gadgets, just try with proper tools. Careful not to touch the main Condenser terminals. If you are in India, I can help you out. 09341932677
Jun 19, 2009 | Nikon Speedlight SB-800 TTL Flash
Sb-22 flash fires but d60 still opens the bilt in fash
I think you will need to upgrade to the 22s. It sounds like the newer model provides the D60 with a 'handshake' signal that the older 22 model does not have.
Sep 01, 2017 | Nikon Speedlight SB-22S TTL Flash
Using a speedlight
the SB-22 has a voltage of around 4.5v this means that it will not fry you D60 SLR so the answer is YES you can use you old flash gun with your D60
Feb 21, 2009 | Nikon Speedlight SB-22S TTL Flash
Shoe moung of sb 28
http://www.sdcamerasolution.com/index.php?p=product&id=240&parent=22
Buy it from there and replace it..
May 15, 2008 | Nikon SB-28DX TTL Flash
Nikon Speedlight SB-22S TTL Flash Logo
419 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
