Question about Standard (CRT) Televisions
Samsung Hitron TV 488S - All features are locked, cant operate it at all.
 All the Television functions are locked. We cant access the menu, sound etc manually  or via its remote control.  How can one "unlock" the functions?  The TV was locked accidentally with its remote.  We have referred to the manual but nothing.  In the meantime the sound is running via our stereo speakers. Any help would be appreciated.
Re: Samsung Hitron TV 488S - All features are locked,...
I also accidently locked my Samsung TV. I unplugged the power cord and powered up after a minute or so. Set was un-locked after after power up.
Posted on Jul 03, 2010
I have a dark band at the base , doesn't go even when we do zoom in all mode
Posted on Feb 28, 2009
If your remote has a Function button.....ususally it is marked with an f then press this and at the same time press another button on the remote......they are all different but it shouldn't take long to find the other button
Posted on Oct 14, 2007
0 characters
3 Points
Hi the child has put a lock on my tv and now I cant manually change channels or volume how do I manually take lock of thomson tv
You'll probably need to use the remote control to access the TV's settings menu to deactivate the child lock feature.
Oct 15, 2014 | Standard (CRT) Televisions
Hi, All functionsof my westpoint television are locked(lock symbol on screen) Cannot access the menu,sound etc. Set can only be switched on manually or via remote control
All sets with the lock feature have a way to unlock either with or without the remote--called a default code or method.
Look first to the owner manual as it may be there, failing there contact the maker with the model number for assistance.
Dec 21, 2012 | Standard (CRT) Televisions
My ECCO tv is locked<
Toshiba's Panel Lock feature allows you to save your settings on your television so that no one else may change them and only the On/Off switch may be utilized from the TV's front panel. Parents may find this option useful to prevent children from accessing programs containing violence and other inappropriate content. Once you turn this feature on, certain steps must be followed to turn it off again.
1. Press the "Menu" button on the remote control, and scroll until you come to the "Preferences" menu. Select "Parental Control and Locks," then press "OK." If your TV does not have a "Preferences" menu, go directly to the "Locks" menu.
2. Enter the four-digit PIN that you selected when you turned the Panel Lock feature on. You may have to scroll up or down to access this area.
3. Press the "Up" or "Down" buttons on the remote until you reach the Panel Lock feature. Move the cursor to select "Off," and press "OK."
Feb 17, 2011 | Toshiba 32A33 32" TV
I hit the FPA and now i am screwed how do i fix this it I cant get into my tv
Child Lock allows you to lock the buttons on the front of the TV.
Press MENU to see the main menu.
Press CH+ or CH- to highlight
Press OK to enter the Preferences
Press CH+ or CH- to highlight FPA
(Front Panel) Lock.
Press VOL+ or VOL- to turn on or off
FPA Lock. Choose On to disable all the
buttons on the front of the TV. FPA Lock
On will appear on the TV screen each
time you press buttons on the front of
the TV. You can still operate the TV with
the remote control. You can still use the
POWER button on the front of the TV, but
only to turn off the TV (not on). Set FPA
Lock to Off to cancel this feature so you
can use the buttons on the front of the TV
Press MENU repeatedly to exit the
menu or the menu will automatically
disappear within a few seconds if no
buttons are pressed on the remote
I hope this helps and good luck!
Nov 15, 2009 | RCA TruFlat 27F520T 27" TV
There is a purple key displayed on the upper left hand corner of the screen all the time. Im not sure how it got there, or why its there. It came up all of a sudden Any ideas? Cheers!
I would think this shows the child lock has been activated therefore the manual buttons will not work. There will either be a "key" symbo; button on the remote control to turn it off or you will have to go into the on screen menu to toggle off the lock. Without knowing the specfic make & model of TV, then I can't be more precise to let you know exactly where the child lock function will be.
Nov 02, 2009 | Standard (CRT) Televisions
32 inch R.C.A T.V
FPA lock stands for Front Panel Access lock similar to Parental Control/Child lock - it indicates that the buttons on the front of the TV are locked so that it cannot be operated accidentally by young children.
You would need to use the remote to deactivate this security feature. Normally, you would go into the Parental Controls menu and turn off the FPA lock.
If for some reason a password was used, then you would have to enter that password since without it you can't get into the Parental Controls menu.
On some versions, you can press "Menu" on the front panel and "Vol -" on the remote simultaneously for 3 seconds to clear the password. in others, it would require that you press and hold at the same time the Vol < button on the front panel and CLEAR button of the remote control for about 5sec. You would need to enter a new password the next time you access the Parental Control Menu.
Usually, steps involve are explained better in the user's manual which is available at the RCA (Support) website. You would need to enter the exact model number of your RCA TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 25, 2008 | Standard (CRT) Televisions
Zenith h32h38dt 32
The "H" model Zenith TVs are hotel/motel sets designed that
a roomer cannot access the menu feature. Your best bet would
be to purchase a name brand universal remote which has the
menu button feature or order an original Zenith master remote
which would not require programming. Once you have a workable
remote which will allow you to access the on-screen menus you
should be able to program the channels.
Hope this helps,
Feb 27, 2008 | Standard (CRT) Televisions
Lg television du-27fb32c reset to factory settings
mute on the remote and menu on tv
service mode and go to factory reset
Dec 09, 2007 | LG DU-27FB32C TV
Standard (CRT) Televisions Logo
3,397 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
