Question about Maytag EPIC MFW9600S
Where is the filter?
The f2 error is showing up. I have checked the hose and drain and they seem to be fine. Is there a filter that could be clogged? If so, where is it?
The filter is in the front on this one. Under the door, there is another panel. There are 3 screws that a 1/4" nut driver takes off pretty easily. Get a bowl and bucket. There is a white screw cap that you should easily see. Open it slowly with the bowl underneath. Close it again when the bowl is filled and dump the bowl into the bucket. Repeat until no more water comes out then unscrew it completely. Clean out the trap and replace. There is a stop that prevents you from overtightening. See if that works. A six dollar nutdriver is easier and cheaper than any repairman.
Posted on Jul 20, 2009
  • 6,784 Answers
The filter is located inside the unit. it is directly connected to the drainage hose(external). its inside the unit on the back, left side. i would also check the following as well to combat this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on Jun 17, 2009
I have a Kenmore HE3t washer than continues to stop during the cycle and flash the F2 error code even after cleaning out lines, hoses, trap, boot and replacing the drain pump.
It is possible that the brushes on the motor that spins the drum are worn down. The drum will start and stop when this happens. Check the brushes.
Nov 07, 2013 | Kenmore Washing Machines
F2 error code shows up on the panel with 2 Min's left on spin cycle, have difficulty to reset machine for restart
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
(courtesy JSRock)
Thanks for using FixYa!!
Dec 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Shows f2 and will not drain got ti too drain but
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 16, 2010 | Kenmore Front Load Washer
My washer, model number GHW9100LW2, is stopping when it gets to the drain/rinse cycle and showing an error message F2 on the display. What does the F2 error message mean?
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Oasis HE washer error code F2
The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test.
Diagnostic Test Mode Procedure
  1. Close the door.
  2. Select the DRAIN/SPIN.
  3. Select NO SPIN by pressing the SPIN SELECT button.
  4. Press RINSE/HOLD or PREWASH OPTION button four times within five seconds.
  5. "C:00" will show on the display indicating that the door is locked and the diagnostic test starts.
  6. Press the button you pressed in step 4 above two times. "C:01" will show on the display and the machine starts to fill.
  7. Press PAUSE/CANCEL button two times when there's enough water inside the tub to stop the test.
  8. Observe the water level falls as the pump starts draining the water. Replace the pump if the water inside the tub does not drain. You have removed and cleaned the pump so you can easily replace it too.
Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
Jan 20, 2010 | Washing Machines
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Whirlpool duet washer GHW9100LW1 getting f2 error. removed panel, filter, pump and hose not clog, ran diagnostic and came up with sud error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F2 error
Apr 21, 2009 | Kenmore Elite 45986 Front Load Washer
F2 error code
check your drain hose for kink,,when you cleaned filter did you check for coins in the impeller..also check drain pipe for slow drain problem,,check the pump connection and make sure its not slipping off..onthejob
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Maytag EPIC MFW9600S Logo
129 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
