Question about Kenmore Dryers
Automatic shut off does not work
DRYER AUTOMATIC SHUT DOES NOT WORK
  • vernita15 May 15, 2009
    Clothes dryer-- AUTOMATIC SHUT DOES NOT WORK
    Kenmore:
    serial# MC0733514
    Model/Stock # 96273800
This just happened to us right before it stopped heating all together. Turns out there are 4 thermostats on this dryer and it was a fuse for one of them that was the problem. The true model number is 11096273800. After we replaced the faulty thermostat, everything was back to normal.
Posted on Jun 06, 2009
  • 460 Answers
I need the model and serial# to assist you better
please
Thank you for trust fixya.com
Posted on May 14, 2009
  • VIRGINIA MARTINEZ
    VIRGINIA MARTINEZ May 15, 2009
    I suggest you to check your timer to see it is working proparly.
    some times if the DRYER is not AUTOMATIC SHUTING off is fue to the TIMER.
    1.- the timer will advances when the thermostat is satisfied the heat.
    2.- the timer would advance quickly to the end of the cycle and the clothes would dry properly.
    I recommend checking your lint screen and the exhaust vent system to the outside of your house first. Make sure that the flexible vent behind the dryer is not kinked or clogged. Make sure that the exhaust duct to the outside is not restricted or clogged.
    Was this helpful?
DRYER WILL NOT SHUT OFF ON AUTOMATIC SETTING
Most of the time when a dryer won't shut of in automatic, it is because the sensors inside the drum are bad and cannot sense when the clothes are dry. If your dryer works good on a timed dry then is probably the moisture sensors.
Oct 08, 2014 | Kenmore Dryers
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
I have a whirlpool electric dryer and the automatic sensor mode is not working. In the automatic sensor mode it drys the clothes but will run forever. The timed mode works by drying the clothes and...
I wonder if maybe your wire is attached to the sensors? If it vibrated off the connection that could be the problem. Here is a video I made which shows how to connect the wire:
Oct 16, 2013 | Dryers
Automatic dry cycles do not shut off
its poassable that the dryer is not drying well.check your house venting.if your clothes are drying well before it shuts down.your sensor bars may have a wax buildup on them.use a rag and a mild cleaner and clean the surface of the sensor bars.good luck!
Jan 17, 2010 | Maytag Dryers
I have a whirlpool dryer that will spin but will not heat or shut off automatically?
some dryer 's have belt sw on them if belt breaks dryer stopes ( no spin ) if dryer stops no heat . replace the belt and it should work .. other problems / ck the power if 220 you may have lost 1 leg . dryer will go but heat and will not shut of auto . mm
Dec 09, 2009 | Dishwashers
It will not automatically turn off when running, the knob does not turn while running.
Miss Stephanie you must replace the timer.
If you have a timed dry setting. Run timed dry. If it does not shut off timer is bad.
If it does shut off you have a sensor problem.
Apr 14, 2009 | Kenmore Dryers
Newer Kenmore dryer automatic sensor not working.
I dont understand your problem?
Jan 19, 2009 | Dryers
Dryers Logo
133 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
