Question about Panasonic PT-53WX54 53" Rear Projection HDTV
Comvergence Problem I have a Panasonic pt-53wx54 projection Tv. from all the postings I have read , I understand If the colors will not line up in one corners and causing double imaging, in my case Blue is off and is arced of a standard projection set, it usually means that one of the convergence output IC's ,on convergence board has burned out and needs to be replaced. if Is possible to give me the Ic's Part# I would appriciate it. please email me, Thank you. Email: info@arrowproductionsusa.com
  • 87 Answers
Panasonic part #C5AA00000203.  Type #STK392-110.  You can also use stk392-120 or STK394-160.  I recommend you replace both IC's as the one that is not now bad will likely fail shortly.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 23, 2007
I have a panasonic pt-53wx54 picture went black with a view vertical color lines then they went and it's now just black. sound is good no picture.. what do i need to do? thanks so much
This is one of several models that had a common problem.
If set comes on with sound and you after a minute or two see a faint odd band of noise top to bottom on the screen to the right side C509 which is a .047 cap at 200 volts is bad.
Cap is seen in attached photo(location marked and cap here gone).
The cap when you locate it from the C509 number which is on top and bottom of board may have a crack or not---it is the cause of this problem.
There is a hard way and a easy way to get at it--let me know and I will explain.
3.00 part....................
Pencil is point to location on Right side board seen from right side.
There are several brown caps here and some plugs here are removed.
I would not try operation of the set in this condition too long.
Apr 20, 2012 | Panasonic PT-53WX54 53" Rear Projection...
Picture looks 3d colors not lining up
The tv have a problems known as a convergence picture problems.That why ur tv colors lines R,G,B are mis alignments,have colors shadow pictures or have 3D pictures look alike?The tv convergence board it is dead.Tv Convergence board must have it parts like 2 STK convergence ICS and some or all of resistors to be replace too.To fixed the tv convergence board to solved tv picture convergence problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 09, 2011 | Panasonic PT-53WX54 53" Rear Projection...
Keeps turning off and red light is blinking 3 time
If it is Panasonic PT-53WX54 rear projection tv then 3 times red light blinking indicates problem of convergence output chips failure in tv that need to be replaced to solve its problem.
Let me know if you are handy with electronics stuff repair and can replace/ solder parts in circuit board to provide you more helpful info OR call local tv repairman to replace convergence output chips tin tv.
Thanks.
Dec 30, 2010 | Panasonic PT-53WX54 53" Rear Projection...
My color is not perfect. It looks like it is missing the green aspect
This tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows picture or 3D picture look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,require replacing to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 03, 2010 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic PT-53WX54 curved bottom
its the problem of convergence in the unit that needs to be repaired
for how to repair please click the above link
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Oct 06, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic pt-53wx54 53inc
Circuit problems, -- consult pro/tech
Apr 21, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Please Help!!
convergence amp, but you will need to replace return resistors also. And maybe fuses in the same area.
Dec 06, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic PT-53WX54
you have defective convergence amps and should be replaced by qualified tech....john
Sep 10, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Convergence
covergence amp ic"S need to be replaced.
Aug 16, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
73 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
