Question about HP OfficeJet 4215 All-In-One InkJet Printer
Hp officejet 4215 all in one -how do I turn off the ringer
  • ttt7 May 12, 2009
    same problem
  • 241 Answers
Taken from page 61 of here:
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
adjust the ring volume
The HP Officejet provides four levels for adjusting how loud it will ring when there
is an incoming fax or phone call. You can select Off, Low, Medium, or High. The
default setting is Medium.
1 Press Setup.
2 Press 3, then press 6.
This selects Basic Fax Setup and then selects the Ring Volume.
3 Press ! to select an option, and then press OK.
Posted on May 28, 2009
Hp officejet 4215 all in one, upgrated from windows vista to windows 7 and also upgrated from 32 bit to 64 bit, need installation driver for this hp officejet 4215 printer scanner.
Brows the link.This Windows 7 patch fixes some printer functionality after upgrading Vista to Windows 7. Link:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4063&lc=en&cc=us&dlc=en&sw_lang=&product=351106#N221
Sep 29, 2011 | HP OfficeJet 4215 All-In-One InkJet...
Need to uninstall 4215 officejet 4215
Click START
CONTROL PANEL
double click
ADD or REMOVE PROGRAMS
When the list populates locate the software I'm suer it will start with HP
click it to highlight then select REMOVE
Nov 17, 2010 | HP OfficeJet 4215 All-In-One InkJet...
I have a hp officejet 4215. It has a scanner, but
For some reason the scan button on allot of HP printers doesn't seem to work.You can go thru "printers and faxes" on your "start" menu.After opening Printers look in the left column for "scanners and cameras",click it.Then your printer will come up,highlight it.Left column again,click "get pictures" and it will walk you thru the scanning process.
Jan 11, 2010 | HP OfficeJet 4215 All-In-One InkJet...
HP officejet 4215 to print instead of fax
if you are using windows then go to control panel and go to printers(windows vista) or printers and faxes (windows xp) and then select the correct printer icon out of the two icons.. there will be two icons (for eg . officejet 4215 and officejet 4215 fax.. ) choose the one which doesnt says fax .
Oct 20, 2009 | HP OfficeJet 4215 All-In-One InkJet...
I lost the Cd to instal my hp printer to my computer
Here is a link for the 4215. Links are on this page for software downloads, manuals, etc.
4215 Support Page
Nov 17, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Office jet all in one printer 4215
If you are using speed dial to dial the fax number, the HP Officejet
might be dialing too fast or too soon. To solve this problem, try one
of the following:
Try manually dialing the fax number from the HP Officejet front
panel, or from an attached phone. For information, see send a
fax using monitor dialing
on page 43 or send a fax manually
from a telephone
on page 43.
Re-create the speed dial setting and insert some pauses. For
information, see create individual speed-dial entries on
page 56.
If your telephone line has a PBX system, make sure you are dialing
the number for an outside line before dialing the fax number.
The receiving fax machine might be having problems. To check this,
try calling the fax number from a telephone and listen for fax tones.
If you cannot hear fax tones, the receiving fax might not be turned
on or connected, or a voice mail service could be interfering with
the recipient’s phone line.
May 07, 2008 | HP Officejet 4215v All-in-One Printer
Download
my hp 4215 all inone printer is not taking paper
Apr 14, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Hp officejet 4215
Hello sonyamac,
You can download the software directly from the manufacturer and install it without the CD. Go to www.hp.com/, find and click Software & Driver Downloads, select Download drivers and software, type officejet 4215 in the box and press enter. Select which officejet matches yours: 4215, 4215v or 4215xi (you can find that info on a label attached around your printer. Sometimes the model is only described as CXXXXA format. If that is all you got, go back to the prior page and type that model instead of officejet 4215. You should reach a page where you select which operating system you are using, click on it and on the next page you can select which software you want to download. After saving your download, just open the program, follow the installation instructions and you should be ready to print in no time. Hope this helps.
cancerags
Dec 26, 2007 | HP Officejet 4215 All-in-One Color Photo...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
281 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
