Question about GE Profile Arctica 25.4 Cubic Feet Side-By-Side Refrigerator With Dispenser PSS25MGMWW
Ge profile artica side by side flooded my kitchen floor,seemed to come from freezer. Help please.
  • 6 more comments
  • erasnoel May 12, 2009
    looked at icemaker and water is continously running ,had to shut down water source.is my icemaker the problem are that valve which connects to water source?
    I turned on the water source and could see the water running into the ice maker until it over flowed and continue to run down my freezer.hd to shut down water to stop it.not stopping automatically.
    that sounds like the problem,is it replaceable and how do i shut down icemaker and contnue drinking filter water until i fix this problem?
    how do i remove it ? just a do it your selfer.
    water level sensing mechanism,does it control water valve therefore shutting water supply at proper level?
    what can i use to plug that hole at the valve?
    disconnected electrical to icemaker side of solenoid, so far so good.drinking cold water w/o icemaker runneth over. will not use icemaker. also,my front doors where they touch to make a seal are very hot at the center where they meet,is this normal?
  • Samuel Charles Spriggs May 11, 2010
    Sounds like your icemaker is leaking. Have you looked at it to see if you can see water running down?
    President:
  • 1,489 Answers
It's most likely a leak in the line feeding the icemaker -- or it may just be loose. Could be the valve, but less likely. It'll have to be removed to find out.
Posted on May 12, 2009
  • 4 more comments
  • Samuel Charles Spriggs May 12, 2009
    Okay, so it sounds like the water level sensing/cutoff mechanism is not working. It'll have to be removed to troubleshoot.
    Yes, it's replaceable -- may only need cleaning/adjusting.
    Most likely the only way to shut off water to the icemaker is to remove it and cap off the line. Unless, you see on the back of the fridge where a branch line goes into the back of the freezer. If you have this, you can cut the line and plug it there. I doubt there is a separate cutoff for the icemaker on the back, but there may be -- check it out...
    Charlie
    If you're what's called, "somewhat handy", you'll see how it comes out -- just start peeling back / uncovering stuff... screws, clips, etc.
    Yes, but it has to get a signal from the level sensor to do this?
    (This could be a simple float switch -- don't know about this model).
    That would be the solenoid valve, I believe. If you can just disconnet the wires from it, that will probably keep the valve from opening. Try that and let me know.
    Heat should dissipate shotly after fridge reaches normal temp.
    This sounds lke a "problem solved". Please rate me a "FIXYA" as they say -- there should be icons at the bottom here.
Ge profile artica profile freezer on top -- refrigerator clicking and not cooling
Check compressor is working. If not, replace relay and check. If still compressor not working, you have to replace compressor.
Feb 12, 2011 | GE Profile Arctica 25.4 Cubic Feet...
I have a GE Profile refrigerator Model # PSC23MGTC it has an Artica Water & Ice dispenser on the freezer door, the ice will not come out, and noew the water works only when it wants to, I think I need...
Cut and paste this Factory Service manual for your refrigerator.
The troubleshooting guide will help locate the bad part.
http://appliancejunk.com/ge/refrigerator/31-9072.pdf
Aug 08, 2010 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
I want to have a lay-out
You can download one at most of my wesites, listed as Profile Artica Service Manual. That will be about all you need there and all GE seems to alow the public to have. Click Here=> GE Artica Profile Technical Information If you need help or assistance feel free to tell me. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Mar 19, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Making a clicking noise and not cooling
This could be a relay on the control board or the compressor is short cycling or both. You can use my assistance to help you resolve this or call a technician, this depends on you. I am very familiar with the Artica/Profile and know that if you can follow instructions and use a test meter we can get this fixed. I would like your complete model number so I can refer to the exact model you have. I will leave you contact information and a service manual and a web page to use with the diagnostics. This problem will not get better, Sea Breeze
Jan 26, 2010 | GE Profile Arctica Stainless Steel Top...
Frig gets too cold freezer works good
I had the same problem. I have the side by side Profile Artica. The problem was a broken damper. It allows the cold air in from the freezer side. With it broken, there was a steady flow of freezer air coming into the frig side. It was easy to fix. I ordered the part (damper/fan assemble) for around $100. While searching for a solution, it seems that this is a common problem. Unfortunately, I received a wide range of incorrect solutions to the problem which could have cost me a lot of money. I hope this helps!
Jun 19, 2009 | GE Profile PFS22 33" Artica French Door...
GE Profile Artica side by side stainless steel wont get cold
The Profile and Artica are good refrigerators. the problem may be the defrost element, defrost thermostat or the mother board. Let me know if you want help on this one. Thanks Sea Breeze
Jun 18, 2009 | GE Profile Arctica Stainless Steel Top...
GE Profile Artica won't drop temp past 52 degrees
Dear FRIEND,
ngfam1 here for you!
I am happy to be of assistance!
YOU NEED SERVICE FOR THIS PROBLEM!! SORRY!!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505 -(IN U.S.A.)
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS.PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OUT!
Aug 26, 2008 | GE Profile PFS22 33" Artica French Door...
Ge profile artica side by side refrig
is it the type of doors with the plastic snap on caps that cover the hinges, if so pop them off and unscrew, if it has an ice maker on the door its more complex, good luck
Mar 13, 2008 | GE Profile PFS22 33" Artica French Door...
Refrigerators Logo
280 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
