Question about Tomtom ONE GPS Receiver
Tom Tom I tried to update my TomTom speed cameras but I have lost everything. when I connect all I get is"Please Wait" and an hour glass that doesn't move. I am confused about TomTom Home and installed the updated version as I now have a new one that I am trying to connect to speed cameras as well. I am so confused. Will be grateful for any suggestions you have. I have always found the TomTom update to be difficult.
I have a similar problem also. I bought a new unit with speed cams installed, the software advised to update the unit, on completion of the update it removed all the speed cams!!! tom tom said it was a bug in the update and to wait till now 26/10/07 for the fix. I have tried to download the fix, but this crashes at 99% install. and advises an error on my E drive which is the tom tom. suggest you try as my card may also be faulty, this may correct your fault
Cheers
Posted on Oct 26, 2007
Renault Koleos with the built navigation system. System was reset to factory settings. I switched on now the hour glass, then blank, then system not configured, please connect diagnostic tool.
Hi is it going past the renault log to menu etc but just hanging with the hour glass ? if its just hanging on the nav and nothing else it could be a faulty sd card that has the tomtom software on. the sd card is usually blue, and will be in the main controller unit, on yours i think its under the back seat but not sure as some have been fitted in the rear side compartments. you can test the sd card on a card reader for a pc, some times it can be fixed by the pc. there are updates on renault site but i think you need to pat for them.
May 30, 2017 | GPS
One unable to restart
Software is corrupted. See if Tom Tom has software for you to recover your system.
Sep 11, 2017 | Tomtom ONE XL GPS
How can I make my tomtom find local places I want?
I hope you have TomTom home installed on your computer. If you already have it, then it is pretty simple. Else, follow this procedure. 1. Connect the USB cable to the TomTom. (connecting this end is difficult, so connect this end before you power on. In fact, this is the only part I hate about a TomTom) 2. Switch on the TomTom. 3. Turn your computer on. Once the booting of the computer is finished, 4. Connect the other end of the USB cable to your computer (note Tom should be on at this point of time) 5. wait a few seconds. 6. You computer will first install Tom and then ask you whether you want to install TomTom home software. say yes and complete installation. (just follow the screen prompts) 7. Create a login (register) and password. If you have already have all this done earlier. follow this procedure. Connect tom to your computer open TomTom home software. wait till it update and settle to the Tomtom home home interface page. It will say manage your Tom the easy way here on top. And you will see a few buttons with: Add map, Add traffic, voices, safety camera etc. click on Add traffic, voices, safety camera button. On the page that opens, Click on Point of interest button. On the next page that opens, you will see a list of POIs. The easy way to find what you want here is to use the box next to search. Type in Home depot and click on search. You will see list of Home depot locations. I guess you are looking for Canada home depot locations. If yes, scroll down to Home depot Canada. select it and click add. Wait till that information is added to your Tom. once finished close Tom home software and safely remove your Tom from computer. Switch off Tom. switch on Tom. Search for Home depot in your POI list. This time around you will see you get one that is closer to you provided the latitude / longitude information is there in the list you downloaded. Most chances are that it will be there.
May 03, 2010 | Tomtom XL 330S GPS Receiver
Tried to update my Tom Tom One by connecting to my
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
Right click on it and select format select FAT32 as the files system
Update your device without the SD card.
Make sure your GPS runs OK without the SD card
Now re-connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options.
Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card and re-boot
It should now work again
Sep 14, 2009 | Tomtom ONE GPS Receiver
Poor gps reception on tom tom one
my tom tom one third edition connects in less than 40 seconds from ca cold start.
first reset everything then connect it to your computer and upload all the needed updates to it( especially the QUICKGPSFIX feature that speeds up the time it takes to connect to satellites.
after that. go outside and wait for the signal to be acquired ( less than 2 minutes)
Jun 20, 2009 | Tomtom One XL GPS Receiver
My tomtom not finding any gps signal
did you save a backup of your original settings/software via tom tom home?
Jan 07, 2009 | Tomtom ONE GPS Receiver
Tom Tom One XL
HAD TO DO A SOFTWARE UPDATE AND CLEAR FLASH UTILITY FROM TOMTOM TO FIX THIS MYSELF. CAN DO BOTH FROM TOMTOM HOME AND/OR TECH SUPPORT. BE PREPARED FOR A WAIT. TOOK 1-1/2 HOURS TO GET TO THIS FIX.
GOOD LUCK!
May 21, 2008 | Tomtom One XL GPS Receiver
Tomtom ONE GPS Receiver Logo
185 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
