Question about Canon SmartBase MP390 All-In-One InkJet Printer
Printer ink jets or head appear to be blocked how do I . clear Brian
  • 32 Answers
Brian, take nail polish remover and pour it into a saucer about the depth +- 2 to 3mm and leave it there till you notice the ink disolving into the solution, if that fails to work remove the cartridge and add boiling hot water about 5mm into a saucer, when you notice the ink flowing from the cartridge then remove it from the saucer, dry it properly and place it back into the printer. Then do a cleaning nozzle from the maintenance tab. Hope this helps, it helped me quite frequently
Posted on May 12, 2009
  • Ricky Hempel
    Ricky Hempel May 12, 2009
    Remove the cartridges from their casing, use a saucer filled with boiling hot water and submerge the printing head or metal lining at the bottom of the cartridge, and only that part (Depth of water not more than +- 3mm) You will notice that the ink will flow from the cartridge when the nozzles are clear and free from the dried ink, If that wont help use nail polish remover to desolve the old or hardened ink.
No red color appear when i print pictures
The Magenta print head nozzle maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 08, 2013 | Canon Pixma iP2700 InkJet Photo Printer
I just inserted new ink jets into my Canon MP 490. When I request a print test page, it goes through the motions but the page is blank.
Mar 08, 2013 | Office Equipment & Supplies
My canon mp280 ink jet printer is not good in printing
Some of the inkjet nozzles maybe be blocked.
Feb 15, 2013 | Toshiba Computers & Internet
Epson SX515W black ink jet blocked. Anyway to clear it myself?
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, thenprint head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jul 20, 2011 | Epson Stylus Multifunction Inkjet Printer/...
When I print a photo, vertical lines appear throughout the photo. The ink cartridges are new. No error message appears on screen.
Please state the model of your printer.
Vertical lines appears on prints because the nozzles on your print head are blocked, it doesn't means all nozzles but some of your nozzles are blocked. A print head of an inkjet consists of many tiny little pores or nozzles, through which jets of inks are sprayed on the photo paper to create an image, if some of this tiny pores are blocked print outs deteriorates, so cleaning the print head is an option if your printer has print head inside the printer you can first clean it through the head cleaning option present in the maintainence tab of your printer software, for printers that have print head on the cartridges, you can add a few drops of isopropryl alcohol on the print head and leave it for a minute and put it back on the printer and run the head cleaning utility of your printer software.
Hope this helps you.
Apr 28, 2011 | Office Equipment & Supplies
Xerox Phaser 8550 is printing green and yellow with some gray color on all the print job, even after I replaced the ink loader, the black color came back but still getting only green and yellow. The ink...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you have loads of missing jets, run a couple of head cleans, if you see improvement, it is worth running some more, if not, try switching off overnight and rebooting next day. If it still won't clear, you may have a faulty printhead.
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
Hope this helps.
Dec 25, 2010 | Xerox Phaser 8500/DN Printer
It keeps printing red I clean the heads and it prints part of a photo then back to red
Your printer jets are blocked! try using a solution like electrical switch cleaner onto the print heads and clean using cotton bids then run clean process on printer and this should clear excess blocked ink and then hopefully your printing will then be fine
Nov 10, 2009 | Kodak ESP 5 Printer
How can you clean the printer but clicking on
Hi
If yourPSC 1210v printer has been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Assuming your HP 56 57 still has ink? Empty they are about 30g Each 1g over that is 1ml of unused ink.
Provided it worked OK before a period of non-use? Then you just need to use a PRINT HEAD CLEANING KIT to unclog the tiny jets.
Magic Inkjet Flush usually works a treat on those!
Magic is ideal for unclogging the tiny jets on any Canon,Epson HP and removing those horrible white lines which usually appear in prints when dried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use a littleMagic Inkjet Flush to soak the print head and you should be printing again like new.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
John P Bradley
Tinteiros (Ebay)
Nov 02, 2009 | HP PSC 1210v All-In-One InkJet Printer
CARTRIDGE PROBLEM TRI COLOR WONT PRINT
HTML clipboardHi
If your printer has been left unused for some time? You probably have an ink clog and the standard cleaning is not enough to clear the clogged ink.
Assuming your tri colour still has ink? (Empty they are about 30g Each 1g over that is 1ml of unused ink.)
Magic is ideal for unclogging the tiny jets on any Canon, Epson HP and removing those horrible white lines which usually appear in prints when dried ink clogs several jets...
So if yours appears to be a clog? all you should need to do is to use a little Magic Inkjet Flush to soak the print head and you should be printing again like new.
HTML clipboard HTML clipboard HTML clipboardYou can read more here: How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
HTML clipboard
John P Bradley
Tinteiros (Ebay)
Tinteiros (Ebay)
Nov 02, 2009 | HP OfficeJet J4580 All-In-One Laser...
Printer prints blank paper. I have cleaned and changed all ink. It was suggested to remove the print head and wash it. Where is the head? Please help. Need this for my home office. Thanks
It appears that the print head nozzles are blocked, it is difficult to clean, it may be cleaned with a ultrasonic cleaner. Most likely you will need to buy a new print head, these are not cheap and you may find it better to buy a new ink jet prnter.
Inkjet printer heads tend to block up if used infrequently, inkjet printers should be run/used every several days to prevent nozzels blocking. If this is your case and you only want to print black & white, I suggest you get a laser printer. It is cheaper to run and don't suffer from infrequent use.
Nov 18, 2008 | Canon i80 InkJet Printer
Canon SmartBase MP390 All-In-One InkJet Printer Logo
127 people viewed this question
old marine
old marine
