Question about Uniden EXI 2926 Cordless Phone (EXI-2926)
Blank screen I can use the phone, ie dial and receive calls but the screen that used to show  what number I dialed etc. is blank.  Should I order some food for the wake or can it be saved?
4 Suggested Answers
  • 1113 Answers
SOURCE: uniden tru448-2 rotary dial
You can download the manual from the link below: To set tone dialing see picture below: Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 12, 2007
SOURCE: Phone problems
I'm unable to get a connection on my phone when i press the talk button is says connecting and then it states unavailable.
Posted on Sep 29, 2008
SOURCE: Dial Tone but won't call out.
I just had the same problem. Try unplugging the plug from the electrical outlet for the home(base) unit and plugging back in. Fixed my problem right away.
Posted on Jan 06, 2009
  • 1124 Answers
SOURCE: Can receive calls but cannot dial out on Verizon landline phone
Try punching in the number to call first THEN hit talk.. It should dial and call at that point..
Just like when making a call from your cell phn - dial the # first..
good luck ;o)
Posted on Sep 17, 2009
0 characters
1 Points
Hello. I have a M7310 Nortel office phone. All of a sudden, the Speed Dial button will not work. In checking the phone, all the speed dial numbers are still programed in the phone, but again the speed dial...
What? They are either programmed or not programmed. If the button is blank, I'm voting for NOT programmed.
If your system is old enough, it's probably lost the backup battery. Ugly things, like pulse dial and only 2 lines are what usually happens, along with losing all of the button mapping but your 2 lines and the default programs of LNR, CONF, etc.
If it's just one phone, there's no magic recall. You'll just have to reprogram it. Same with the system if you've lost everything, but I"d call a repair tech first to fix the battery on the software cartridge.
Apr 14, 2011 | NorStar Meridian M7310 Phone
How do I insert a pause when dialing a number? For instance, when using a calling card with PIN-less dialing for international calls, I first dial a local access number, wait for a response (details of...
Look carefully on your phone's keypad. You should find one of the multi-purpose buttons labelled "Pause" possibly in white text on the body of the phone. It may be the same button marked redial. If you push this button while programing a phone number into the phone book, it will show a "P" on the screen. This will insert a pause when your number is being dialed.
Oct 09, 2010 | Uniden DECT 6.0 Cordless Phone ID
How do I enter numbers/use the speed dial? Any Manuals available?
when you want to enter a number on a speed dial you first want to go on the page with your contacts (where its has all the options : groups, contacts, new contact, etc...) look down the list and you will find "SPEED DIALS" click on that then numbers will apear 1-*lets say* 999 click on the first empty one and it will let you add a number or contact that you type in or choose. Then when you want to use the speed dial to call lets say "George" and he is your speed dial 1 just type in the number 1 as if you were typing in a phone number and his name will come up on the top of the screen or such and you just have to press call, or you can hold the one down and it will imidietly call "George"
Apr 27, 2010 | Phones
How do i forward a call to a cell phone?
I believe your landline carrier just needs to have the capability of call forwarding (ie we utilize Verizon for our business). We also use the call forward feature by: picking up line, (hear dial tone) dial *72 [ then phone number you want calls to forward to, even a cell]. To discontinue: pick up line (hear dial tone) dial *73
Mar 02, 2010 | NEC Dterm DTP 16D-1 Corded Phone
When a received call comes in the number shows 1-402 then the number.on call back the phone dials all 11 numbers,then i get a recording from windstream that says i dont need to dial the 1 and area code....
The caller ID in your area is set up to show the 1 plus the area code although not every area has yet to require you to dial the 1 before the number. In the near future it's possible you will have to dial the 1 even if you're calling a local number. I know of no way to change the phone settings in order to remove the 1 in the caller id. Unfortunately it looks like your only option will be to dial the number directly without the 1. Good luck!
Dec 10, 2009 | Panasonic Phones
Panasonic kx-TG2352 can not dial ,phone works for
Believe it or not, I accidentally discovered you have to really press hard on the numbers to dial !!! I guess this happened as one is used to a light touch working on a cell etc
Nov 30, 2009 | Panasonic KX-TG2352 Cordless Phone
good luck ;o)
Sep 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
Conference call when connected to other internal lines
First dial a number,while talking to that person dial another number, after dialing the another number press redial button,than you can talk to another person but the the first line i.e. the the person you are talking at first will have to wait, he will not be able to hear waht you are talking with the order have a conference than again press re-dial button than you will be able to have a conference.....
Jul 21, 2008 | Panasonic KX-T7730 Corded Phone
Uniden EXI 2926 Cordless Phone (EXI-2926) Logo
18 people viewed this question
Top Uniden Phones Experts
Dave Ellis
Are you an Uniden Phone Expert? Answer questions, earn points and help others
