Question about Acer Aspire 5100 Notebook
Power jack needs replacing aspire 5050 model zr3 laptop
I have removed all the screws from the case that i can see but i am unable to open the case to get inside to repair or renew the power jack. are there hidden screws on the case somewere
    Sniper:
  • 79 Answers
Hi I will help you. Under the screen and above the keyboard is the power button panel. take a small flat tip screwdriver and carefully use it to pry up one side of the power button panel. you may even need to pry up on the part of the panel that covers the hinges. Once it start to release, grab the panel and kind of wigggle it back and forth, while lifting it. it should start to release all the way. Once removed, the top of the keyboard is exposed, remove the keyboard being careful of the short ribbon cable connector underneath the keyboard.
once keyboard and panel are removed, you'll need to remove the screen via the screws on the hinges. make sure to disconnect ANY of the cables to the screen (usually video cable and wireless cables. And disconnect one small ribbon cable that looks like it comes from the touchpad mouse.
Now check where you removed the keyboard, you should see several sscrews that you need to remove.
At this point, if all the screws are removed, you should be able to disassemble thelower chassis of the laptop. Be very careful not to break anything. You will need to also remove several screws in order to get the motherboard out of the laptop.
I will give you the web link of where I buy ALL my power jacks for my repair shop. A guy named Gary Shaftsall runs DC PowerJacks, and is a great guy to do business with, not to mention he sells the jacks @ wholesale price.
His website address is:
http://dcpowerjacks.net/catalog/index.php
I urge you to be soooo careful in putting it all back to gether, I would hate to see you put a long screw into a shallow hole. this could result in a MAJOR short of the motherboard. Just keep track where all screws go and how the parts go together.
Hope this helps, please rate my solution.
Posted on May 12, 2009
    Scholar:
  • 45 Answers
There are TONS of screws in laptops, mainly hidden.  I just took apart a laptop today, and it took me a couple of hours to get the screws out.  There are so many screws!  They are usually under the panels in the back as well.  Here is a link for your computer model Acer Aspire 5100 http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Laptop will not power on at all-no lights nothing.
Hello, Scott.
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Oct 16, 2011 | Acer Aspire 5535-5050 Notebook
How can i replace a power jack on an acer aspire 7738 laptop
I actually just did this. I took some pictures while I was at it.
Problem in my case was a bad contact, leading to flickering of the power light, and me having to twist the power cable until it powered again.
I mostly followed this youtube post: https://www.youtube.com/watch?v=aL59O7h0GOk
However, there was no need to remove the lower screws on the back, or to detach the keyboard or anything else. Just have to take off the "tuba" cover, unplug the power, unscrew the screen, screw open the screen (really the hard part!! Takes alot of force to get it open (dangerous)), and then finally the power jack replacement.
I ordered a new one from ebay for 5 bucks.
Hope this helps
Arnout
replace-power-jack-acer-aspire-wdmmfzxzfm2h3uclb0t1k4uq-5-1.jpg replace-power-jack-acer-aspire-wdmmfzxzfm2h3uclb0t1k4uq-5-3.jpg replace-power-jack-acer-aspire-wdmmfzxzfm2h3uclb0t1k4uq-5-6.jpg replace-power-jack-acer-aspire-wdmmfzxzfm2h3uclb0t1k4uq-5-10.jpg
Oct 05, 2011 | Computers & Internet
The power jack is broken. how do i open & repair/replace?
Here is the service and repair manual for that model, be sure to make a copy for yourself....it is free to copy and use.
http://tim.id.au/laptops/acer/aspire%205050%203050.pdf
Oct 11, 2009 | Acer Aspire 5050-3242 Notebook
ACER 5050 NOTEBOOK CAMERA NOT FOUND WHAT DRIVER
You can get the drivers from here:
http://www.acerdriver.org/?gclid=CJiUzdTt5ZwCFVhB5godijRJHA
Might cost you a few dollars but will save you the agpravation.
Sep 10, 2009 | Acer Aspire 5050-3242 Notebook
Opening acer aspire 5050
The top and bottom covers are also held together with plactic catches.
After you remove the battery, CD/DVD drive and hard drive etc.
start near an openning and gently pull apart the top and bottom cases, you should hear a click as a catch releases, then continue to work around the edge fron this point.
Mar 05, 2009 | Acer Aspire 5050-3242 Notebook
Power problem
You need to remove the screws on the bottom of the laptop. Once the right screws are removed the case will seperate exposing the MOBO and that and you should see the dc jack (power jack) as forwarning, almost ALL dc jacks are sodered to the motherboard..and not easy to successfully replace.
Jul 24, 2008 | Averatec 3200 Notebook
Removal of cooling fan
You need to disable your laptop.
follow this step:
Remove harddrive.
1. on the back of laptop, there are 2 doors. open it all. 1 of them is harddrive.
2. remove harddrive.
Remove wireless cable.
1. open 2nd door on the back, you can see rams and wireless card. unplug wireless cable from wireless card.
Remove chassis
1. Remove 2 screws on the hinge cover, so you can remove the power cover (power cover is cover that have power button).
2. after you removed power cover, removed keyboard.
3. remove 4 screws that hold lcd from chasiss. you can remove lcd now.
4. remove 3 screws under keyboard.
5. remove all screw on the back of your laptop.
6. remove upperchassis.
7. remove 2 screw that hold motherboard from lowerchasis.
8. take motherboard out from lowerchasiss.
9. now you can see the thermal fan.
Jun 19, 2008 | Acer Aspire 5050-3242 Notebook
Audio and modem problem
May be this problem is due to your os so first u check your service pack... if u r using xp it needs to install winxp service pack 2 then try again you will get result...
Jan 15, 2008 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5100 Notebook Logo
872 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
